How to Fix iOS 10 Installation Problems
Confused about annoying issues when installing iOS 10 on your iPhone/iPad? This guide will tell you how to fix the most common iOS 10 installation problems.
Sep. 27, 2016
PhoneRescue – Help You Fix iOS 10 Installation Problems
PhoneRescue – Excellent iOS System Repair Tool
PhoneRescue could help you fix some problems with iOS 10 installation problems like stuck in recovery mode, stuck in Apple logo, iTunes error 14. Download it now and have a seven-day free trial.
It has been a few days since the public release of iOS 10. Some users updated to the new operating system the first time, while some users tend to wait for a period because they want to avoid some update problems. However, although you have made full preparation before the upgrade, you may still meet issues when downloading and installing iOS 10. We have already talked about iOS 10 download problems in the past, and here we will help you fix iOS 10 installation problems.
Also Read: The Most Common iOS 10 Problems and Solutions >
Part 1. Fix Stuck in Recovery Mode
During the update process, your iPhone or iPad accidentally get an error and the screen show an arrow pointing to iTunes, the device is stuck in recovery mode apparently. If you meet such iOS 10 installation problem, try the following methods to fix it.
Solution 1: Reset your device. Press and hold down the Home button and the wake/sleep button until your iPhone/iPad restart with Apple logo.
Solution 2: Restore from iTunes. First update the iTunes to the latest version.
Solution 3: Fix it with PhoneRescue – iOS data recovery. PhoneRescue is developed to recover data for both Android and iOS users. PhoneRescue – iOS data recovery aims at recovering lost data from iOS devices, with new functions added, it can also be used as an iOS recovery tool that can fix many normal problems, including fix iPhone/iPad stuck in Recovery Mode.
Related post: How to Fix iPhone Stuck in Recovery Mode >
Part 2. Fix Stuck on Apple Logo
Many users have reported this problem when they try to update device to iOS 10. As for this iOS 10 installation problem, you can try the methods that list in Part 1, and PhoneRescue – iOS data recovery can also help you fix the issue.
For more info, please visit: How to Fix iPhone iPad Stuck on Apple Logo >
Part 3. Fix iTunes Error 14
When you are trying to install iOS 10 as well as restore your device from backup, a window appears and says: The iPad/iPhone could not be restored. An unknown error occurred (14). Read the following part to see how to fix this iOS 10 installation problem.
Solution 1: Check your USB cable. It may happen when you have a connection issue.
Solution 2: Restart your iPhone/iPad and computer to have a try.
Solution 3: First backup your device and then preform a clean restore. Then restore your device from the backup you created after you have installed iOS 10 successfully.
For more details, please visit: How to Fix iTunes Error 14 When Installing iOS 10 >
Hope this guide can help you fix iOS 10 installation problems successfully. If you meet other problems installing iOS 10 or have any new methods to fix the issues, please share it in Comment Section. It may help other users. Take A Tour with PhoneRescue – iOS Data Recovery >
