[Solved] Fix: iPhone not Sending Messages or iMessage
When sending a message on your iPhone only to find that you’ve encountered the problem of iMessage not sending or iPhone not sending texts? We’ll be taking a look at the reasons behind the problem and offer you the top solutions.
By Bella Miller | Posted on: Aug. 03, 2018, Last Updated: Mar. 06, 2019
Home > PhoneRescue > Best Messages/iMessages Recovery Tool > [Solved] How to Fix: iPhone not Sending Messages/iMessage
iPhone not Sending Messages/iMessages
We rely on our iPhones every day to communicate with friends, family, and work colleagues, so when a problem arises, it can very quickly become a big issue. This is certainly the case with problems like iPhone not sending messages – which many people have been stuck with in the past!
If you’ve encountered this problem first-hand, or are currently struggling with iMessage not sending, then we have the solution… multiple solutions in fact. In the article, we’ll guide you through just what to do with an iPhone that’s not sending messages/iMessage.
Hot Topic: Top 5 iPhone iPad Wi-Fi Problems and Potential Fixes >
Why is My iPhone not Sending Messages/iMessage
A few reasons could be to blame for an iPhone not sending messages or iMessage. Commonly, the issue will either revolve around your phone connection or the recipient’s phone connection – as sending a text relies on both. Problems can also arise with Apple, where the service is down; and with your iPhone, where a fault or temporary malfunction is preventing the text from sending. Further issues include.
While there is a lot that can cause the problem of an iPhone not sending messages, there are also plenty of solutions to the problem. Here are some of the most effective solutions to fixing the problem of text or iMessage not sending properly.
Solution 1. Turn Your iPhone Off and On Again
Step 1 Hold the power button on your phone (located on the side of the phone for most models) until the power-off slider appears > Slide the power-off button.
Step 2 Wait for the screen on your phone to go black and then hold the power button again until the Apple logo appears.
Solution 2. Make Sure You Have Signal
Step 1 Swipe up on your screen to open the control panel (for iPhone X, swipe from the top right).
Step 2 Select the aeroplane symbol in the top left and wait a few seconds before unselecting it.
Step 3 Close the control panel and reconnect to your network by going to Settings and then selecting “Wi-Fi”. Alternatively, for a 4G connection, go to Settings and then select “Cellular” option.
Solution 3. Check Your Phone Settings
Step 1 Open the Settings on your iPhone > Tap General > Select the option that says “Date & Time”.
Step 2 Make sure that the Date & Time is set to automatic (the bar will be green). If it already is, swipe the slider left and then right again to reset it.
Fix iPhone not Sending Messages/iMessage – Check Phone Settings
Solution 4. Reboot iMessage
Step 1 Open the Settings tab on your iPhone and go to Messages.
Step 2 Swipe the bar that says “iMessage” to the off position; then turn off your phone (using the method shown in solution 1).
Step 3 Turn your phone back on and swipe the iMessage bar into the on position (it will be highlighted green).
Solution 5. Update Your iPhone
Step 1 Open the Settings tab on your iPhone and go to General Settings.
Step 2 Select the option that reads “Software Update”.
Step 3 Check to see if you have any outstanding software updates, and if you do, select “Install Now”.
If solutions 1-5 haven’t solved the problem of iPhone not sending messages, and you’re certain that the number you’re using is correct and there no issues with the Apple system, then you may need to enlist professional assistance, as the fault with your iPhone could be more serious.
Bonus Tip: How to Recover Permanently Deleted Messages on iPhone/iPad
To recover permanently deleted messages or iMessages, you have two choices: Restore from iTunes or iCloud backup, or ask help from reliable third-party software like PhoneRescue for iOS.
Since the first choice has lots of limitations: have to erasing all existing data and settings before restoring, the backup must contains your lost messages, can’t check the backup details, can’t restore only messages, etc. most of the users are prefer to use the second way – PhoneRescue for iOS to do the messages/iMessages recovery.
With PhoneRescue for iOS, you can not only check the iTunes or iCloud backup details, but also can select the messages you want to recover, no blind full restore, no current data erasing needs. It provides 3 different recovery modes to ensure the highest success rate: from iDevice directly (without any backup), from iTunes backup and from iCloud backup. That’s to say, no matter you have backup or not, you can get your lost messages back. Now, let’s check its steps to recover deleted messages easily.
Step 1 Free Download PhoneRescue for iOS on your Mac or PC computer firstly > Install and open it.
Step 2 Connect your device to the computer via a USB cable > Click Recover from iOS Device mode > Click Right Arrow on the bottom right to proceed.
How to Recover Deleted Messages on iPhone iPad – Step 2
Step 3 Check Messages option > Click OK to start the scanning process.
How to Recover Deleted Messages on iPhone iPad – Step 3
Step 4 Preview and select the messages you want to undelete > Click To iPhone button to undelete them to your iPhone/iPad directly for instant use. Or you can click To PC/Mac Computer button to store them on your Mac/PC computer.
How to Recover Deleted Messages on iPhone iPad – Step 4
Five more methods to retrieve lost or deleted messages on iPhone iPad are introduced in this page. Head to have a check.
Many of the common iPhone problems with messages not sending are just due to small faults and malfunctions, with a reset often doing the trick and restoring full function to your iPhone. If you like this article, just share it with your friends or other people.
Bella Miller
A senior editor, an Apple fan at iMobie Inc.. I love both dancing and helping users to solve iOS & Android related issues by writing various types of tutorials.
PhoneRescue ® for iOS
Recover your deleted iPhone iPad files with the highest success rate, no matter whether you have backups or not!
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
