The hard drive-based iPod classic doesn’t use Apple Mobile Device USB Driver to connect with iTunes. If your iPod classic won’t connect to iTunes, follow below iPod guide to have a try.
Take a tour of this awarded software so that you can fix iPod classic won’t connect to iTunes, and other iPod errors like iPod error 1415 and iPod error 1430.
iPod classic is a drive-based MP3 player. Differing from other iPod models, this series doesn’t require Apple Mobile Device USB Driver to connect to your computer. So when you found somehow your iPod classic won’t connect to the iTunes, uninstalling and reinstalling iTunes probably cannot solve the problem. Below are some suggestions for you.
Don’t Miss: How to Copy Music from Computer to iPod without iTunes>
Connect iPod classic to iTunes
Most problems with iPod will be solved by resetting it. To reset an iPod, you can:
Click Wheel iPod classic Won’t Connect to iTunes
4. Connect the iPod to your computer; the screen on the iPod will say “Do not disconnect”.
If you are having difficulty putting your iPod into Disk Mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center. If you are still unable to put your iPod into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If the above tips didn’t work for you, then you can try AnyFix – iOS system recovery to repair iTunes. It is designed to help iOS/iPadOS/tvOS/iTunes users to get out issues in minutes. With AnyFix, 130+ iOS/iPadOS/tvOS problems can be fixed, including device stuck issue, won’t restart/open, etc. Also, if you’re meeting iOS device won’t connect to iTunes, iPod error 1415, and other 200+ iTunes errors, use AnyFix anyway.
Now, follow the steps below to try to fix the iPod classic won’t connect to iTunes:
Step 1. Download AnyFix – iOS system recovery on your computer (Mac & Windows). Launch it and click iTunes Repair.
Click iTunes Repair
Step 2. Choose Other iTunes Error from the repair list below. And tap on Scan Now button.
Choose Other iTunes Errors and Scan Now
Step 3. Next, the iTunes component error will be detected and listed below. Head to Fix Now to continue.
iTunes Component Errors will be Detected
Step 4. Then, give AnyFix permission and the repairing process will begin immediately. Wait a minute and you will see a Repair Completed page. Open iTunes to check if the problem is resolved.
If you want to manage your iPod music and other content with ease, then AnyTrans is the best iPod data manager. As an all-in-one manager for your iPhone, iPad, iPod, iTunes, and iCloud content. AnyTrans lets you transfer, manage, and back up iOS data in a way easy, fast, and you like. With AnyTrans, you can easily view your iPod data and sync them to computer/iTunes/iPhone/iPad.
Now, get the latest version of AnyTrans to manage your iPod.
Manage Files in AnyTrans
That’s all about how to fix iPod classic (Click Wheel) won’t connect to iTunes. Try AnyFix – iOS system recovery to solve system problems of your Apple devices, and fix iTunes errors with ease. If you have any questions about the article, feel free to leave your comments below.
