A Useful Micro SD Card Reader for Android Phone
Looking for a micro SD card reader for Android and then manage these data in SD card easily? Check on this article and get a useful memory card reader for Android.
By iMobie | Posted: Mar. 12, 2018, Last Updated: Apr. 18, 2018
Home > AnyTrans for Android > Android Transfer > Micro SD Card Reader for Android Phone
“How can I see what’s stored on SD card on my Android phone? Once I’ve moved a bunch of stuff to the SD card what if I want to check what is on that SD card? When I go to settings->storage->SD card all it allows me to do is ‘format’ or ‘unmount’ the card. But I want to see what’s on that card. I can’t see any way to do this. Can someone help?”
A user from Android Central Forums
Recently we’ve received a lot of emails and comments inquiring that how to check the files stored in SD card on Android phone in order to manage these files in a simple and quick way. For this purpose, there is a micro SD card reader for Android called AnyTrans for Android for you to view and access SD card files in the Android phone.
Also Read: 2 Quick Ways to Backup Android Phone >
The Tool We’ll Need – AnyTrans for Android
As a professional Android data-managing tool, AnyTrans for Android is also a useful micro SD card for Android. Here are some high features of it:
1. Allows you to read files in micro SD card on Android devices, and you can access and view these files in details.
2. With My Files feature, it presents an intuitive layout of the files on your Android device. And you can import, export and edit these files as you need.
3. Supports transferring files from iPhone to Android devices, between Android devices, and between computer and Android.
4. Supports managing all kinds of Android files like messages, photos, contacts, call log, music, videos, books, ringtones and etc.
Now just get this SD card reader for Android to your computer and follow the steps below to know how to use this micro SD card reader easily.
Step 1 Run it on your computer and connect your Android phone via a USB cable > click on My Files.
A Micro SD Card Reader for Android Phone – Step 1
Step 2 Then you’ll see all Android files on your SD card in Android as well as the files in phone memory. Then you can open any folder to manage your Android data: Refresh button to refresh the page, Settings button to set the export path, Add/Create Folder button to add files/folders, Send to Mac button to download files to computer, Rename button to rename the files or folders, Delete button to remove items.
A Micro SD Card Reader for Android Phone – Step 2
As you see, AnyTrans for Android is definitely a great micro SD card reader for Android phone, and you can also manage these Android files as you need. With so many useful features, why not give it a free trial >
AnyTrans® for Android
The best tool to transfer, back up and manage your Android data: to computer, to another Android device, add from computer.
  • * 100% Clean & Safe
