By Bella Miller on
How to Print Messages/Contacts/Call History on iPhone 7 (Plus)
How to save, backup and print text messages, contacts and call log on your iPhone 7? There is one iOS manager that helps you easily make it in a few clicks, to print texts info on your iOS devices.
AnyTrans - Help You Quickly Print Text Messages on iPhone 7
Download AnyTrans and follow this tutorial to save and backup your contacts, messages or other text info on your iPhone 7, and to print them in a simple way.Download AnyTrans Now >
The Phone and Messages are definitely two of the most basic and important apps on an iPhone, to help you keep in touch with your family, friends and other mates. And that’s why so many new iPhone 7 users urgently search methods to put messages and contacts data to their new iPhone from old device once they got the iPhone 7.
Don’t Miss: How to Transfer Data to New iPhone
On the other hand, Phone and Messages are two of the most frequently used apps. After being used for a period of time, they could create so many history and junk files. So most of you would consider removing some useless messages or junk files to free up space. However, in the process of deleting, you probably lose some important info by accident. Therefore, you are recommended to save and backup your important contacts, call history and messages conversations.
In this post, we offer one advanced tool with tutorial to help you save, back and even print messages, contacts and call history on your iPhone 7. Now let’s begin!
Tool We Will Use
What we’ll use to help you print iPhone 7 messages, call history and contacts is a professional iPhone manager - AnyTrans. With this tool, you can easily export only your selected messages, call history, contacts and some other items from your iPhone 7 to computer for backup. In addition, by saving this kind of data to some printable and readable formats, you can quickly print them with printer.
How to Print Messages, Contacts and Call History on iPhone 7/7 Plus
After downloading and installing AnyTrans on computer, now you can follow the steps we list below to print data on your iPhone 7.
Step 1: Firstly, create an iPhone 7 backup with AnyTrans. Just run AnyTrans on your computer, and click “Backup” icon to create a new iPhone 7 backup.
Create an iPhone 7 Backup
Step 2: After backing up your iPhone 7, you can find the backup in the backup list, click “View” to access messages, call history and contacts on your iPhone 7.
Select backup and view contents on iPhone 7 backup
Step 3: Now you can preview messages, contacts, call history and other info on your iPhone 7. Just select the items you want to print and click "To computer" button to save them as printable format.
Save selected messages as printable files with AnyTrans
Note: By click “Settings” button on the top right corner, you can set output format and export path.
Step 4: Go to export path, open exported files on computer and print them with printer.
Preview Exported Files and Print Messages on iPhone 7
Whether you want to print all contacts, call history and messages or just several items, AnyTrans could be a good helper. In addition, it can do more things than this to manage your iPhone 7. Download AnyTrans and know more about AnyTrans >>
Bella Miller A senior editor, an Apple fan at iMobie Inc.. I love both dancing and helping users to solve iOS & Android related issues by writing various types of tutorials.
Product-related questions? Click here to get quick solution from our Support Team >>
Home iPhone Manager How to Print Messages Contacts and Call History on iPhone 7
