How to Fix Process System Isn’t Responding on Android
How to fix process system isn’t responding? Read the post to find the key to the process system isn’t responding problem.
By Faye Clarke | Posted on: Apr. 26, 2018, Last Updated: Feb. 14, 2019
Home > AnyTrans for Android > Android Process System Error > How to Fix Process System Isn’t Responding on Android
Android device sometimes will run into the “process system isn’t responding” error especially after user installing a new app from a source other than Google Play Store, or after a bad update of Android version. It seems to be a common error happened on almost all Android models, including Samsung Galaxy Note 8, S8, Sony Xperia, Google Pixel, Android emulator, etc. And in fact, the process system isn’t responding error is subject to Android OS bug. But don’t worry. In this post, you’ll get the key to the process system isn’t responding problem.
Tip 1. Free Up Internal Space on Android
To free up the internal space on Android device, you can go to Settings > Storage > Cache Data or Saved Data and tapping on Clear Cache. Or uninstall some apps that you use rarely.
Tip 2. Force Restart Android Phone
Press and hold the Power button on your Android device until the system boot window pops up. Then choose to Restart or Reboot the device and wait until the process ends.
Tip 3. Update Installed Android Apps
Step 1 Open Google Play Store, swipe from left to right and tap on My apps & games.
Step 2 You should see a list with all the apps that need to be updated. Update every app to the latest version or tap on the Update All to schedule them all for updating.
Tip 4. Check for System Update
Go to Settings, tap on System update and hit Check for Updates. Wait for the query to be completed. If there are any OS updates, install them and wait for your device to reboot.
Tip 5. Unroot Android Device
If you once rooted your Android device, this is a way to go. But before you proceed to unroot your Android device, make sure you have all of your important data backed up.
Step 1 Go to Settings > Backup & reset > Factory data reset.
Step 2 Confirm your action by selecting the Reset Phone button.
Step 3 Your phone will begin the process during which it will reboot a couple of times.
Step 4 Once your device reboots, you can set it up and the root access, along with super-user apps will be detected by the device.
In order to avoid any uncertainty like the “process system isn’t responding” error, you’d better back up Android content to computer. A super easy-to-use Android files manager – AnyTrans for Android can easily help you make it. Get it to have a free trial >
How to Backup Android Phone
That’s all for fixing the “process system isn’t responding” problem on Android. If you find other useful solutions, welcome to share with us in the comments below. Any doubts about the problem are also welcomed.
Faye Clarke
Member of iMobie_Inc, an enthusiastic fan of Apple and Jazz music, always ready to offer advice and solutions to any iOS & Android related issues.
AnyTrans ® for Android
The best tool to transfer, back up and manage your Android data: to computer, to another Android device, add from computer.
  • * 100% Clean & Safe
