How to Read Text Messages on iCloud
How to read text messages on iCloud? Here we provide you an easy and quick way to read messages on iCloud. Just keep reading to get the solution in minutes.
Apr 28, 2017
AnyTrans - Helps You Read Text Messages on iCloud
AnyTrans - Best iPhone Content Manager
AnyTrans gives you fully support on data-transfer, device-backup and iCloud-management. Download and install AnyTrans on your computer before reading this guide on how to read text messages on iCloud.
iCloud automatically saves your iPhone text messages and other types of data, such as, device settings, app data, ringtones, and visual voicemails. You may get your messages lost by mistaken deletion, iOS update, failed jailbreak etc.
Unfortunately, there is no easy way to retrieve only messages from an iCloud backup - you must restore the entire backup to your iPhone or another iOS device. This requires erasing your device and setting which may cause the data loss on your existed content. If you just want to read these messages on iCloud, or simply want to export them to the PC, AnyTrans is the very way to go.
Can't Miss: How to Remove Saved Messages from iPhone Easily >
AnyTrans Highlights
1. AnyTrans is professionally designed to directly transfer any types of data from your iPhone, iPad or iPod touch to iTunes, computer or another Apple device.
2. AnyTrans supports transferring music with play counts and ratings, playlists, photos, videos, podcasts, app, contacts, messages, notes, etc.
3. AnyTrans is capable of exporting the text messages to the standard text, or html on your computer, and you can view them on your computer anytime you like, or print them out for forever preservation.
You May Like: How to Export Text Messages from iPhone >
How to Read Text Messages on iCloud with AnyTrans
1. Download and install AnyTrans on your computer and click the iCloud icon on the bottom to sign in your iCloud with your Apple ID and password.
How to Read Text Messages on iCloud with AnyTrans - Step 1
2. After logging iCloud, click “iCloud Backup”.
How to Read Text Messages on iCloud with AnyTrans - Step 2
3. Download the backup you need.
How to Read Text Messages on iCloud with AnyTrans - Step 3
4. Select a backup and choose Messages. Now you can read the messages, and even export them to your computer by clicking the "To Computer" button on the top right corner.
How to Read Text Messages on iCloud with AnyTrans - Step 4
Related Reading: Backup Text Messages on iPhone >
Note:If you want to backup your iPhone content, such as, photos, music, videos, contacts, messages and more by transferring them to your computer, AnyTrans could also be a great helper.
After reading this article, you can easily and quickly read messages on iCloud, as well as contacts, notes, calendar, call history with AnyTrans. Any questions on this article or AnyTrans is welcomed, please be free to let us know. Hava a free trial on AnyTrans now >
