How to Recover Data from Water Damaged Samsung Phone Step By Step
Accidentally drop your Samsung Android phone into water place such as a swimming pool? Then, read the below article to know how to recover data from water damaged Samsung phone.
By iMobie | Posted: Aug. 13, 2018, Last Updated: Aug. 13, 2018
Home > PhoneRescue > Android Data Recovery > How to Recover Data from Water Damaged Samsung Phone
If your Samsung Android Phone is damaged because it got dropped into water, there are high chances that you have to face data loss situation with your Android device. However, technology has given some method you can try to rescue your data and recover data from water damaged Android. In this article, we provide you with some ways to recover your lost data from water damaged Android phone.
How to Rescue Android Data From Loss If Android Dropped into Water and Got Wet?
To prevent your Samsung phone from hard drive damaged, and rescue your data from loss, you should do the following things to dry your device.
Step 1. Remove Battery and SIM card. (Turn off your Smartphone and do not turn on it)
First of all, if your Samsung Android device got wet, then you should immediately turn off your device and removes the battery as well as SIM card.
Step 2. Don’t shake your Android phone. (Prevent the water from flowing around inside your Samsung smartphone device.)
Step 3. Clean the water on the surface of your device, and dry your Android by dropping it into Rice Bag for a few days. Do not place the wet-dry phone in the hot places. Otherwise, your wet device may get fired and it can also harm you.
Dry Water Damaged Android Phone with Rice
How to Recover Data from Water Damaged Samsung Smartphone
Once your Samsung phone got dried completely, then you can check if any data is lost from your device or not. Of course, if your Android is completely hard drive damaged, then you may not access the data in it unless you’ve ever backed up the data on the device.
If you are lucky that the data is lost but the device is in good condition, then the best way is to use some top Android data recovery software to get back your lost data. And below we take one nice Android recovery – PhoneRescue for Android for example, to tell you how to recover data form water damaged Samsung. And you can download PhoneRescue for Android first and follow us to have a try.
Step 1. Connect your water damaged Android device with the computer using a digital cable.
Recover Data from Android Internal Memory – Step 1
Recover Data from Water Damaged Samsung Phone – Step 1
Step 2. Then, Check those file types that you want to recover and click on the “Next”.
Recover Deleted Files from Android Internal Memory – Step 2
Recover Files from Water Damaged Samsung Phone – Step 2
Step 2. Finally, you can now recover your desired files either to your computer or directly to your water damage Android device.
Recover Deleted Files from Android Internal Memory – Step 3
Recover Data from Water Damaged Android Phone – Step 3
Due to advancement in technology, you have the chance to recover data from water damaged Android phone. However, Android users should be very careful while using the device as severe water damage can erase data permanently from your phone and there is a possibility that you might never get your lost data back.
PhoneRescue ® for Android
Recover deleted Android data and files with the highest success rate, and directly back to your Android phone or tablet.
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
based on 2243 Customer Reviews
