How to Restore Phone Contacts for iOS & Android
Accidentally deleted important contacts on your phone and looking for a way to restore phone contacts? This guide will separately show you how to restore phone contacts for iOS devices and Android phones.
By iMobie | Posted: Apr. 12, 2018, Last Updated: May. 14, 2018
Home > #1 Phone Contacts Recovery Tool > How to Restore Phone Contacts for iOS & Android Devices
Data loss is a major issue these days for every Smartphone user. If the phone is lost or stolen then the user can buy another one but it is very hard to retrieve lost data like contacts, messages, pictures etc. People save hundreds of contacts in their Smartphone’s which make it easy to get in touch with their friends and families. Situations become stressful when the phone contacts are erased while you reset the factory settings, format your SIM card or accidentally delete your data. Are there any solutions to restore phone contacts after one loses them?
Yes, there are various tricks and methods which can help to retrieve phone contacts when they are lost due to above-mentioned reasons. Restoring data like phone contacts is possible and there are special recovery tools like PhoneRescue which will retrieve all your lost data in minutes. This article will provide you various steps and techniques to restore phone contacts.
Part 1: How to Restore Phone Contacts for Apple iPhone
There are various reasons which configure contacts loss in iPhone such as Upgrade failure of the iPhone, accidental deletion, and damage brought to your iPhone and if your iPhone gets stolen.iPhone users who have created a backup through iTunes can easily restore phone contacts.
Solution 1: Restore iPhone Contacts from iTunes Backup
Step 1 Launch iTunes and connect your iOS device to the computer using USB cable.
Step 2 Using mouse press the Right Click button on your iOS device from the devices list and select “Restore Backup”
Step 3 Select the newest backup entry appearing on the screen and tap “Restore”.
While you restore phone contacts from the iTunes Backup, it will erase all existing data on your iOS device.
Solution 2: Restore iPhone Contacts from iCloud Backup
You can also recover deleted contacts from phone via iCloud backup if you have made one before lost contacts. If you do have made an available iCloud backup, you can follow the below-written steps to restore phone contacts.
Step 1 Initially, you need to erase all the content and settings from the new iPhone. For this you have to Go for Settings > General > Reset > Erase the Content & Settings.
How to Restore iPhone Contacts from iCloud Backup – Step 1
Step 2 Reach the Apps & Data screen and select Restore from iCloud backup > Log in to your iCloud Account > Simply select the iCloud backup that contains the contacts you want to restore.
Solution 3: If You Can’t Restore Phone Contacts from Backups
If you are unable to restore phone contacts from the above-given methods, then Data recovery Software like PhoneRescue – iOS Data Recovery can assist you in recovering the contacts from any iOS device, even without any backup.
Free Download PhoneRescue – iOS Data Recovery on your computer now, and then follow the steps to restore phone contacts easily.
Step 1 Install and open PhoneRescue – iOS Data Recovery on your computer > Connect your iOS device to the computer via a USB cable > Select Recover from iOS Device mode > Click Right Arrow.
How to Recover Deleted iPhone Contacts without Backup – Step 1
Step 2 Check Contacts only if you just want to recover deleted contacts > Click OK button to proceed.
How to Recover Deleted iPhone Contacts without Backup – Step 2
Step 3 Preview and select the contacts you want to recover > Click To iDevice button to recover them to iPhone’s Contacts app directly, or click To Computer button to store them on your computer for a backup.
How to Recover Deleted iPhone Contacts without Backup – Step 3
Part 2. How to Restore Phone Contacts – Android
To restore phone contacts in Android you need to configure some important methods as discussed below.
Solution 1. Restore Android Phone Contacts from Gmail
To recover phone contacts from your Android phone, it is vital to sync the contacts with your Google Account. Through this feature, you can easily restore deleted contacts from your Gmail account.
Step 1 Open your Gmail account and click on Gmail icon and then select “Contacts”. This is to be done to restore the backup with Google contacts.
Step 2 The time you see the contact list, Tab on “More” to get the drop-down menu. Here, you have to select the “Restore contacts”. On the screen “Restore” option will pop-up, where you can select the back up for up to 30 days and re-sync the Gmail Account with Android device.
Solution 2: Restore Phone Contacts from Android – Android Contacts Recovery Tool
To restore phone contacts, if you face any difficulty with respect to the above method, then download PhoneRescue – Android Data Recovery, a trusted android data recovery tool.
Free Download PhoneRescue – Android Data Recovery on your computer prior, and then easily recover your deleted but important contacts with the simple steps below.
Step 1 Install and run PhoneRescue for Android on your PC/Mac > Connect your Android phone to the computer.
How to Recover Deleted Phone Contacts from Android – Step 1
Step 2 Check Contacts option > Click Next to scan your Android device.
How to Recover Deleted Phone Contacts from Android – Step 2
Step 3 After scanning, all lost contacts will be displayed. Choose the contacts you want to recover to device directly with To Device button, or save them on computer by clicking on To Computer.
How to Recover Deleted Phone Contacts from Android – Step 3
Phone contacts serve to be an important data on which every person relies to be touch with their friends, families, and colleagues. Contact lost is a major issue these days and people are unable to restore phone contacts on their devices. PhoneRescue is an official data recovery tool which can assist you in restoring phone contacts both for iOS and Android devices. Have a free trial now >
PhoneRescue® for iOS
Recover your deleted iPhone iPad files with the highest success rate, no matter whether you have backups or not!
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
