How to Send iMessages with Bubble or Screen Effects in iOS 11/12
Want to send iMessages with bubble or screen effects in iOS 11/12 but do not know how? Read to learn how it works.
By | Last Updated: May. 15, 2019
Home > PhoneRescue for iOS > iPhone Messages Recovery > How to Send iMessages with Bubble or Screen Effects in iOS 11/12
Since Apple released its newest iOS 12, many users have updated their iOS device to the latest version of iOS 12. Though the iOS 12 has many fixes, there are still some questions that upset users very much. In this guide, we are going to talk about how to send iMessages with bubble or screen effects in iOS 11/12. To update to iOS 12 smoothly, don’t forget to check The Most Common iOS 12 Problems and Solutions.
iOS 10 was a HUGE release of Apple last fall. One of the biggest new features is the significant improvement of iMessage. As of now, Apple has introduced four bubble effects in its developer version: Slam, Loud, Gentle, and Invisible ink.
Slam: Stamp the bubble down and makes your device screen ripple.
Loud: Send a huge bubble that shakes before settling down.
Gentle: Send a small bubble that gently slips into place.
Invisible ink: Cover the bubble and make it blur until you swipe it out.
And also with the 9 screen effects: Send with Echo, Send with Spotlight, Send with Balloons, Send with Confetti, Send with Love, Send with Laser, Send with Fireworks, Send with Shooting Star, Send with Celebration. And now iOS 11/12 still have them all.
Also Read: 10 Best iOS 12 New Features: What’s New in the Update >
Part 1. How to Send an iMessage with Bubble Effect in iOS 11/12
1) How to Send Invisible/Hidden iMessage on iOS 11/12
Step 1 Tap on Message app to run it on your iPhone.
Step 2 Select the contact you want to send a message to.
Step 3 Input content you want to send and then long press the Up Arrow (↑) to activate Message effect.
Step 4 Select “Invisible Ink”, and then click Up Arrow again to send it.
2) How to Send Gentle Effect iMessage on iOS 11/12
Step 1 Open Message app on your device.
Step 2 Choose an old thread or create a new message, and type in with the content you need to send.
Step 3 Long press the Up Arrow (↑) next to the content you just put in to activate Message effect.
Step 4 Tap on GENTLE effect and click the Up Arrow again to send it.
3) How to Send Loud Effect iMessage on iOS 11/12
Step 2 Choose an old thread or create a new message, and type in with content.
Step 4 Tap on LOUD effect and click the Up Arrow to send it.
4) How to Send Slam Effect iMessage on iOS 11/12
Step 2 Choose an old thread or create a new message, and type in the content you want to send.
Step 4 Tap on SLAM effect and click the Up Arrow to send it.
Only when sending iMessage, you can long press Up Arrow to activate Message effect. When sending text messages, a long press will send this message. If you don’t want to send a bubble effect, tap the Cancel button at the bottom of the effects list, which looks like an X.
Also Read: How to Fix: iOS 12 Overheating Problem >
Part 2. How to Send Screen Effect in Message on iOS 11/12
Besides bubble effect in messages, you can also send Screen Effect messages in iOS 11/12, which is kind of full-screen animations including Balloons, Confetti, Lasers, Fireworks, and Star. Here is how to send Screen effects/animations in iMessage on iOS 11/12 and iOS 10 devices:
Step 1 Open your Messages app and select the contact or enter an old message.
Step 2 Type your text message in the iMessage bar.
Step 3 Tap and hold down on the blue arrow (↑) until the “Send with effect” appears.
Step 4 Tap Screen (next to Bubbles).
Step 5 The first one is Balloons effect and you can swipe left to choose Confetti, Lasers, Fireworks, or Star effect.
Step 6 Tap the blue arrow to send your text message with the selected screen effect.
How to Send Screen Effect/Animations Message on iOS 11/12
If the Screen effect option does not appear in your Messages app, you may need to enable Reduce Motion: Settings > General > Accessibility > Reduce Motion > Enable it.
Part 3. How to Send Handwritten Message on iOS 11/12
Except sending the hidden message with invisible ink, you also can send handwriting messages on iOS 11/12. About how to do it, you can follow the steps below:
Step 1 Tap on Message App on the homepage to run it.
Step 2 Scroll up by swiping from bottom to top to rotate iPhone to landscape mode.
How to Send Handwritten Messages on iOS 11/12 - Step 2
How to Send Handwritten Messages on iOS 11/12 – Step 2
Step 3 Then back to Message App, you will see the handwriting canvas.
Step 4 Tap on Handwriting canvas and enter input box.
How to Send Handwritten Message on iOS 11/12 - Step 4
How to Send Handwritten Message on iOS 11/12 – Step 4
Step 5 Hand write the words you want to send and tap on Done to back when finish.
How to Write Messages on iOS 11/12 - Step 5
How to Write Messages on iOS 11/12 – Step 5
Step 6 Tap on Up Arrow to send this handwriting iMessage.
How to Send Hand Writing Messages on iOS 11/12 - Step 6
How to Send Hand Writing Messages on iOS 11/12 – Step 6
Bonus Tip: How to Recover Deleted or Lost iMessages/SMS Messages
For those who accidentally deleted some important iMessages or text messages and want to get them back, one professional iOS data recovery tool – PhoneRescue for iOS is highly recommended. It has just been updated and becomes more powerful. A full guide that tells how you can use it to recover the deleted or lost messages on iPhone is offered. Go and get 6 ways to get back your missing memory.
  • Recover iMessages and text messages from iPhone iPad directly, or from iTunes/iCloud backup without restore.
  • Recover iMessage/Message as well as its attachments.
  • Get the deleted messages back to iPhone or to the computer in HTML or text format.
  • It also supports recovering notes, contacts, call history, photos and more.
Recover Deleted or Lost iMessages/SMS Messages with PhoneRescue
Download PhoneRescue for iOS Now to Take a Tour >
By nature, an iPhone is always in danger of getting damaged, lost or stolen. How about your important iOS data? To help you recover your lost or mistakenly deleted photos, messages and other data on your iPhone, we collected 5 top best iPhone Data Recovery Software and evaluate them carefully to provide valuable references for you.
Joy Taylor
Member of iMobie team as well as an Apple fan, love to help more users solve various types of iPhone related issues.
PhoneRescue ® for iOS
Recover your deleted iPhone iPad files with the highest success rate, no matter whether you have backups or not!
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
