How to Show Battery Percentage on iPhone X
How to show battery percentage on iPhone X? Read this guide to see how to check iPhone X battery percentage quickly.
Nov. 9, 2017
AnyTrans – Always Put Your iPhone Data in the Right Place
AnyTrans – Best iPhone Data Transfer
This all-sided iOS data transfer tool can help you transfer data from old iPhone/computer to new iPhone X easily, as well as transfer iPhone data to computer as backup. Just give it a try.
The new iPhone X are different from all the previous iPhones, and the edge-to-edge display is the most intuitive one. However, for anyone who likes to check the battery percentage may feel a little disappointed, because there is no longer enough room to show it thanks to the notch. The good news is that, you can view the battery percentage in other methods. Just keep reading to see how to show battery percentage on iPhone X.
Method 1. Check the battery percentage in the Control Center. Swipe down from the right hand corner of the display to access Control Center, and then you will see the battery percentage at the right top. After you have checked out, swipe up to dismiss Control Center.
Method 2. Ask Siri. You can use Hey Siri, or press and hold the Side button to ask Siri “What’s my battery life”. It will respond with the battery percentage.
Method 3. Charge your iPhone X. When you charge your iPhone, you will see the battery percentage on the lock screen.
Bonus Tip: Easy Way to Transfer iPhone X Data
If you just switch from Android to iPhone X, you may feel confused about transferring data to new iPhone or exporting iPhone data. If you are always an iPhone user, you may feel tried of iTunes sync. Well, everything will get easier with the help of AnyTrans.
It lets you transfer data from Android to iPhone X directly. Just select the contents you want to transfer and it will not erase any existed iPhone data. You can transfer all the data at once, or just the selected one as per your needs.
Transfer Data from Android to iPhone X via AnyTrans
It lets you transfer data from old iPhone to iPhone X directly. Or add data to iPhone from computer without effort.
Transfer Data to iPhone X via AnyTrans
In addition, it lets you easily manage iPhone X photos, videos, contacts, messages, and more. Ringtones and apps are also included, which now the iTunes 12.7 cannot handle. You can transfer any kinds of data from iPhone to computer/iTunes/iCloud, or delete multiple items at once. Always put your data in the right place. Get AnyTrans Now >
That’s all for how to turn on battery percentage on iPhone X and an easier way to transfer iPhone data. If you have any question, just leave a comment and we will help you out soon.
Submit Your Question to Us, Get an Answer within 24 hoursAsk Your Question
