Pros & Cons of 2018 Top 6 Best iPad Backup Extractor [Mac and PC]
Searching for the best iPad backup extractor tool to restore photos, messages, notes, videos and more other data from iCloud/iTunes backup, or from your iPad directly? This top 6 best iPad backup data extractor software review will give you detailed references to help you make a wise decision.
By iMobie | Posted: Jun. 28, 2018, Last Updated: Jun. 28, 2018
Home > Phonerescue > iOS Data Recovery > Top 6 Best iPad Backup Extractor in 2018
To avoid accidentally data loss, you must be regularly backup your iPad to iTunes or iCloud, but you’re not be allowed to access the content of the backup you made, let alone view the data details. However, in some cases, you may indeed need to access or extract some data from iPad backup. Then, how to extract data from iPad backup?
To extract data like photos, messages, contacts, notes or other more iPad data from backup, you need professional iPad backup data extractor to help you make it. The following text will share top 6 best iPad backup extract tools with its pros and cons.
Pros & Cons of Top 5 Best iPad Backup Data Extractor in 2018
Since iTunes and iCloud doesn’t allow you to access and extract data from backup, so, professional iOS backup extraction tools been developed to help you pull it off. That’s why most iPad backup data extractor is paid software. But there are also free ones. This article lists top 6 iPad data extractors for you, let’s check one by one.
1. iPad Backup Extractor – PhoneRescue
As an award-winning professional mobile device data recovery, PhoneRescue dedicated to helping iOS & Android users recover lost or deleted phone data like contacts, messages, photos, videos, calendar, etc. PhoneRescue for iOS is mainly designed for iOS users, applying for all iPhones, iPads and iPod touch to do data recovery. Besides, it is also be regarded as a useful iPad backup data extractor since it brings you following benefits:
Besides above benefits it brings to you, PhoneRescue for iOS also has its pros and cons:
Pros:
Cons:
How to Extract iPad Data from iTunes/iCloud Backup with PhoneRescue for iOS
Now, let’s see how PhoneRescue for iOS to help you access and extract data from backup within 3 steps.
Step 1 Download PhoneRescue (choose Download for iOS) on your PC or Mac. Install and launch it. Choose Recover from iTunes Backup or Recover from iCloud. Here take Recover from iTunes Backup for an example. Then, click the arrow button.
How to Extract iPad Data from iTunes Backup without Erasing - Step 1
How to Extract iPad Data from iTunes Backup without Erasing – Step 1
To extract data from iCloud, you can refer to this guide: How to Extract Data from iCloud Backup >
Step 2 Select a backup and tick the types of data you want to scan or just tick Select all and click on OK.
How to Extract iPad Data from iTunes Backup without Erasing - Step 2
How to Extract iPad Data from iTunes Backup without Erasing – Step 2
Step 3 Preview and select data you want to extract. If you connect your device in advance, you can click Recover to Device button to extract them directly to iPad, or click Recover to Computer button to save them on your PC/Mac.
How to Extract iPad Data from iTunes Backup without Erasing - Step 3
How to Extract iPad Data from iTunes Backup without Erasing – Step 3
2. iPad Backup Extractor – AnyTrans
AnyTrans for iOS is another recommended iPad backup extractor to help you extract iPad data from iPad/iTunes or Cloud backup. It also won’t cause data loss and give you the option to selectively extract iPad backup files and preview data details ahead of time.
Top 2 iPad Backup Data Extractor - AnyTrans for iOS
Top 2 iPad Backup Data Extractor – AnyTrans for iOS
Pros:
Cons:
AnyTrans is acknowledged as an all-in-one iPhone content manager, you must-have Apple device companion software. Besides its iOS backup extractor options, it also has a wide range of other iOS content management features like:
  1.  Save iPhone, iPad and iPod music to computer, view details >
  2.  Add songs, movies, books and more to iDevice, without iTunes, view details >
  3.  Add songs, voice memos or other types of sound files as iPhone ringtones directly, view details >
  4.  Transfer your photos to reclaim more free space on your iPhone, view details >
  5.  Copy your messages, contacts, notes, and other data to the computer, view details >
  6.  Clone all your data and files from one iPhone to another one, view details >
  7.  Extract files from iPhone / iTunes / iCloud backup, view details >
3. iPad Backup Extractor – Primo iPhone Data Recovery
This is another easy-to-use iPad data extract tool supports detecting all iTunes backups on a computer and lets you easily access and extract data from local backups. And for extracting data from iCloud backup, you can still make it with simple steps.
Top 3 iPad Backup Data Extractor - Primo iPhone Data Recovery
Top 3 iPad Backup Data Extractor – Primo iPhone Data Recovery
Pros:
Cons:
4. iPad Backup Extractor – dr.fone – Recover (iOS)
dr.fone – Recover (iOS) is a desktop software which tailored to help users extract data from iOS devices and iTunes or iCloud backup to computer without any issue. Not only that, it also supports iOS data recover no matter you have a backup or not. The attractive and simple UI design makes it easy to use.
Top 4 iPad Backup Data Extractor - dr.fone - Recover (iOS)
Top 4 iPad Backup Data Extractor – dr.fone – Recover (iOS)
Pros:
Cons:
5. iPad Backup Extractor – Cisdem iPhone Recovery
Cisdem iPhone Recovery is a secure & fast iPad backup extractor for Mac OS users to extract data from iTunes backup and from iPad directly. It can recover photos, contacts, messages, videos and more.
Top 5 iPad Backup Data Extractor - Cisdem iPhone Recovery
Top 5 iPad Backup Data Extractor – Cisdem iPhone Recovery
Pros:
Cons:
6. iPad Backup Extractor – PhoneBrowse
Top 6 iPad Backup Data Extractor - PhoneBrowse
Top 6 iPad Backup Data Extractor – PhoneBrowse
PhoneBrowse is the only free iPad backup data extract software, which is designed to access and manage your iOS devices data without jailbreaking. It is also a free iPhone backup extractor that allows you to extract files from iTunes backup. It gives you a hand to load iPad backup data so that you can freely browse and manage all the files within.
Pros:
Cons:
Comparison Chart of 2018 Top 5 iPad Backup Extractor
PhoneRescue AnyTrans Primo iPhone Data Recovery dr.fone – Recover (iOS) Cisdem iPhone Recovery PhoneBrowse
iCloud Backup
iTunes Backup
iDevice Data Recovery
Supported Platforms PC & Mac PC & Mac PC & Mac PC & Mac Only Mac PC & Mac
Price $49.99 for lifetime license $39.99 for lifetime license $39.99 for lifetime license $69.95 for one year license $49.99 for lifetime license FREE
Backing up iPad with iTunes or iCloud is easy to do, but extracting from the backup you made is not really simple. That’s why you need to find an iPad backup data extractor. Each person may have their own choice because everyone considers different factors. Hope this review can help you make a good and right choice among multiple iPad backup data extractors.
PhoneRescue ® for iOS
Recover your deleted iPhone iPad files with the highest success rate, no matter whether you have backups or not!
  • * 100% Clean & Safe
5,716,299
Users Served
Mentioned in Top Tech Sites:
Highly Rated by Users:
Rated 4.8/5
