How to Transfer iTunes Library to a Flash Drive
How can I copy my iTunes Library to a flash drive? Here’s a quick guide that tells you how to finish that.
Sept. 30, 2016
AnyTrans – Helps Copy iTunes Library to a Flash Drive
AnyTrans – All-around iOS File Manager
You can have a try on the free trial of AnyTrans to manage your iOS content and iTunes Library. Now read on this guide on how to transfer your iTunes Library to a flash drive.
Through our survey, over 79% iPhone users rely iPhone / iTunes / iCloud to store their important personal data. In order to help you extract useful photos, messages, notes and more from your backup, we composed this 2016 iPhone Backup Extractor Software Review for your reference.
We keep songs, playlists, movies and more in the iTunes Library, and no one wants to lose the precious content. Backing up the Tunes library to a flash drive is a good way to protect the data. If bad things happen to your computer and you need to rebuild the iTunes Library, the copy in the flash drive will be your last straw.
In this detailed tutorial, we will offer you the quickest way to transfer iTunes Library to a flash drive. Keep reading on to get the answer.
Also Read: How to Move Pictures from iPhone to Flash Drive >
The Tool We Need
AnyTrans is an iOS file management tool made for all iOS devices, which is capable of organizing content on your iPhone or iTunes Library. Check its main features:
  • Extract the files in iTunes library like music, playlists, movies, ringtones, audiobooks, apps, etc.
  • Copy the files in iTunes Library to a flash drive or computer directly.
  • Transfer iOS data between iPhone and iTunes/computer, and between any two iDevcies.
  • Import files from iTunes Library to your iPhone without wiping data.
See Also: How to Share iTunes Library >
How to Copy iTunes Library to a Flash Drive with AnyTrans
AnyTrans makes it easy to transfer iTunes Library to flash drive in few steps. Please follow the detailed steps below to learn how to finish that.
Step 1. First, plug in with your flash drive. Download AnyTrans and install it on your computer, connect your iPhone to computer if you want to manage the files on your device. AnyTrans will load your iPhone data as well as extract the iTunes Library.
Step 2. Go to the manage page of iTunes Library in AnyTrans. Select songs, playlists, ringtones, movies, or audiobooks, and then click the To PC/Mac button. Choose your flash drive, and then click Open to start transferring.
How Can You Copy iTunes Library to a Flash Drive with AnyTrans
Note: AnyTrans does a great job on transferring data from iPhone to iTunes, to PC/Mac, and vice versa, and here are some tutorials you may like:
How to Copy Music from iPhone to iTunes >
How to Transfer Playlist from iTunes to iPhone >
How to Get Songs from Old iPhone to New iPhone >
How to Transfer Music from iPod to Computer >
To manage data in iTunes Library or in an iDevice, AnyTrans would be a good helper with its powerful features. It also gives you chance to transfer music, videos, and photos from your iPhone to a flash drive directly, with no limits. Now it’s time to have a free trial on it.
