How to Turn on the Dark Mode on Mac OS X Using Command Keys
Do you know how to enable the Dark Mode using command keys on Mac OS X? In this guide, we will show you how to make it.
July 23, 2015
MacClean – Clean Your Mac to Optimize the Running Speed
MacClean – Best Mac Cleaning Software
You can download this excellent Mac clean software to clean your Mac to manage the storage space after reading this guide about how to turn on the Dark Mode on Mac OS X using command keys.
After upgrading your Mac OS X to Yosemite, you can customize the your desktop look and feel. The ordinary way to make it is by going to System Preferences > Click on the General > Check "Use dark menu and Dock".
How to Enable The Dark Mode on Mac OS X
How to Enable the Dark Mode on Mac OS X
If you want to activate Dark Mode by using the key commands, in this guide, we will show you details to make it.
Can't Miss: How to Free Up Memory on Your Mac >
How to Turn on The Dark Mode on Mac Using Command Keys
Step 1. Make sure that you have saved all the documents in other apps and close other apps.
Step 2. Open Terminal from "Applications > Utilities (or by using Spotlight to search for it)".
How to Turn on The Dark Mode on Mac Using Command Keys – Step 2
How to Turn on the Dark Mode on Mac Using Command Keys – Step 2
Step 3. Type the below words:
sudo defaults write /Library/Preferences/.GlobalPreferences.plist _HIEnableThemeSwitchHotKey -bool true
How to Turn on The Dark Mode on Mac Using Command Keys – Step 3
How to Turn on the Dark Mode on Mac Using Command Keys – Step 3
Step 4. Press Return to activate the command. Because you have typed a "Sudo" command, OS X will ask you to enter your administrator password. Enter it and hit return.
Step 5. Quit the Terminal app.
Step 6. Restart Mac.
Step 7. Use the keyboard shortcut Control+Option+Command+T, and the Dark Mode will be enabled.
If you want to disable the Dark Mode, you just use the shortcut that mentioned above again. For disabling the Yosemite's Dark Mode shortcut, use the command showed above but replace true with false. More than anything, if you want to clear your mac to keep it response quickly all the time, you can use MacClean to help you clear your Mac from time to time to optimize it.
