[Guide] Where Does iTunes Store Backups
Want to know where does iTunes store backups on your Mac/PC computer? Read on this guide to find the iTunes backup location and get your elusive files easily.
AnyTrans – iTunes Alternative Tool to Manage iOS Data
AnyTrans – #1 iTunes Alternative Tool
AnyTrans is the best iOS data manager for it manages your data on iPhone/iPad/iPod and iTunes library in a much labor-saving way. Just have a try on this #1 iTunes alternative now.
If you own an iPhone, iPad or iPod touch, then it’s quite accessible to backup your data on those devices, as Apple offers you two efficient ways to do you a favor, and iTunes is one of the two. When you make a backup with iTunes on your Mac/PC computer, you may want to know the iTunes backup location exactly so that you can make a full control over your files. And in this article, we will lead you to quickly find out where does iTunes store backups on your Mac/PC computer. Keep on!
Don’t Miss: How to Fix iTunes Error 9 >
Where Does iTunes Store Backups on Mac
If you are Mac users, you can find your iTunes backup location by clicking menu bar, then enter ~/Library/Application Support/MobileSync/Backup/
Mac users can also locate a specific backup:
Step 1. Open iTunes and click iTunes in the menu bar > Choose Preferences > Click Devices.
Step 2. Control-click the backup that you want > Choose Show in Finder.
If you want to delete some of those backups on Mac, go to iTunes > Preferences and Select Devices > Choose the backup(s) that you would prefer to delete > Click Delete Backup.
Where Does iTunes Store Backups on PC (Windows 7/8/10)
If you are windows users, just go to:
\Users\(username)\AppData\Roaming\Apple Computer\MobileSync\Backup\
To find your iTunes backup location on Windows PC, you can also follow below steps:
Step 1. Find the Search bar:
1. In Windows 7, click Start.
2. In Windows 8, click the magnifying glass in the upper-right corner.
3. In Windows 10, click the Search bar next to the Start button.
Step 2. Enter %appdata% in the search bar > Double-click on Apple Computer > MobileSync > Backup.
How to Transfer Data from Computer to iPhone/iPad/iPod without Data Erase
You may know that when transferring data from computer to iDevice with iTunes, all your existing media data like photos, videos, ringtones, music, etc. on your iPhone/iPad/iPod will be removed. To keep all your files safe, here in the following, we would like to share you the #1 iTunes alternative – AnyTrans to transfer data from computer to iDevices with no previous data erase.
It supports transferring up to 24 kinds of iOS data, like photos, videos, messages, contacts, notes, etc. It also enables you to extract files from iCloud or iTunes backup without restoring iDevice. More than anything, the whole transferring process just takes you a few minutes. Let’s start with it now.
Step 1. Download and install AnyTrans on your computer, launch it > Connect your iPhone/iPad/iPod touch to the computer with its USB cable > Click Add Content.
How to Transfer Files from Computer to iPhone/iPad/iPod – Step 1
Step 2. Choose the files you want to transfer (here we take photos for example) > click the "Open" button to start transferring the selected photos to your iPhone.
How to Transfer Photos from Computer to iPhone/iPad/iPod – Step 2
Also Read: How to Backup iPhone without iTunes >
With above detailed tutorial about where does iTunes store backups on Mac/PC, you may have successfully found your iTunes backup location. And it is worth to say at the end, with AnyTrans, you can also transfer data from your iPhone/iPad/iPod to computer and between iDevices. So, why not give it a try now >
