Having trouble with the phone mirroring connection? Check out this article and explore six effective ways to troubleshoot phone mirroring connectivity issues.
Screen mirroring your iPhone and Android to the computer with ease.
Available for both Win & Mac
Struggling with the frustrating problem of the mirror not connecting to your phone successfully? Don’t worry, you’re not alone. Many people face connectivity issues when trying to mirror their screen or stream content.
In this article, we will explore six effective ways to fix this problem, allowing you to enjoy a smooth and hassle-free mirroring experience.
Let’s dive in and start the screen mirror in no time!
The first step in troubleshooting mirror-phone connectivity is to ensure compatibility between your two devices.
For Miracast Users:
If you’re a Miracast user, you should make sure your computer is compatible with Miracast.
Here’s how to check if your computer is Miracast-compatible.
Step 1. Press the Windows logo key + R to open Run.
Step 2. Type dxdiag on the text box and click OK to open the Settings menu.
Type “dxdiag” on the Text Box
Step 3. Click on the Save all information button.
Step 4. Select a folder to save the text file and click OK.
Step 5. Press the Windows logo key + Q and search for Notepad in Cortana.
Step 6. In Notepad, click on File > Open. Then open DxDiag.txt.
Step 7. Now you know whether it’s compatible or not. If Miracast says “Available, with HDCP”, it’s available. If not, then your PC doesn’t support Miracast.
The DxDiag Document
For AirPlay Users:
If you’re an AirPlay user, you should make sure your iPhone/PC/TV is compatible with AirPlay, otherwise AirPlay will not work.
AirPlay video (left) and AirPlay audio (right)
Apple has published a list of compatible airplay devices, which includes the following:
Devices You Can Stream Video From Using AirPlay
Devices You Can Stream Audio From Using AirPlay
Sometimes, a simple restart is all it takes to resolve connectivity issues. Begin by turning off both your devices. Wait for a few seconds and then turn them back on. This can reset any temporary glitches or conflicts that might be causing the connection problem.
Outdated software or systems on either of your devices can create connection issues, preventing them from establishing a successful connection.
The Software Update
To address this, check for any available updates for both devices and install them if necessary.
Software updates frequently include bug fixes and improved compatibility, which can effectively resolve connectivity problems.
By keeping your phone software and system up to date with the latest software versions, you can ensure optimal performance and seamless connection between the two devices.
Forgetting and reconnecting to a network is a troubleshooting technique that can help resolve connectivity issues with your devices. This method involves removing the saved network settings from your device and then reconnecting to the network, essentially starting fresh in establishing a connection.
Removing the background apps can be another way to solve screen mirroring not connecting to the phone issues.
In some cases, existing applications on your mobile device can interfere with the connection, particularly if you have VPNs enabled while browsing the internet. While there is no doubt that using a VPN is crucial for ensuring online security, it is advisable to disable it temporarily when attempting to establish a connection with smart devices.
By disabling these applications, you can eliminate any potential conflicts and proceed with the setup process. As a result, you’ll have a higher chance of achieving a decent response from the connection routine. Remember to re-enable or enable your VPN once the connection is successfully established to maintain your online security.
AnyMiro is a powerful screen mirroring app that supports both iOS and Android devices, making it suitable for a wide range of users. Whether you’re an iPhone user or an Android enthusiast, you can take advantage of the app’s extensive compatibility and enjoy a seamless mirroring experience without worrying about the mirror not connecting to your phone.
Features of AnyMiro
How to Mirror iPhone to PC Using AnyMiro
Mirror iPhone to PC via USB
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
Mirror iPhone to PC wirelessly
Step 2. Go to the iPhone/iPad mirror section.
Step 3. Switch to the WiFi connection part. Connect your iPhone and PC to the same WiFi.
Connect to the Same WiFi
Step 4. Follow the on-screen steps, select your PC from the list, and start mirroring your iPhone.
Mobile Screen Mirrored on the Computer with AnyMiro
1. Can I screen mirror without WiFi?
Yes, you can screen mirror without WiFi by using USB connection. By connecting your phone to a computer or a compatible device using a USB cable, you can establish a direct connection for screen mirroring. This method allows for a stable and reliable mirroring experience, particularly useful in situations where WiFi is unavailable or not preferred.
2. Why is mirror not working on iPhone?
There are many reasons about the mirror not working on iPhones. You should make sure your AirPlay-compatible devices are turned on and near each other; check the devices are updated to the latest software and are on the same Wi-Fi network; restart the devices you want to use with AirPlay or screen mirroring, etc.
3. How do I mirror my iPhone to my smart TV?
You should first connect your device to the same Wi-Fi network as your Apple TV, AirPlay-compatible smart TV, or Mac. Then find the video that you want to mirror. Tap AirPlay and choose your TV or Mac from the list. Now you can mirror your iPhone to your smart TV.
Mirror not connecting to phone issues can be frustrating, but the solutions provided in this article will help you overcome connectivity issues when mirroring your screen.
By checking compatibility, restarting devices, updating software, forgetting and reconnecting to networks, removing background apps, and using a stable mirroring app like AnyMiro, you can fix the problem effectively and enjoy a seamless mirroring experience.
Say goodbye to frustrations and interruptions and embrace the convenience of screen mirroring.
