This guide will teach you how to fix the second monitor flickering with simple and clear steps. Follow each step to stop flickering and enjoy a smooth display.
Try AnyMiro to mirror iPhone to PC for free via USB and WiFi.
Watching games or working while viewing videos on your second monitor can suddenly become disrupted by random screen flickering. Your monitor will blink while simultaneously flashing between lines, obstructing your ability to see clearly. This can be very annoying and even hurt your eyes. Don’t worry—this problem is common and usually easy to fix.
This guide will show you simple and clear steps to stop second monitor flickering. You can manage your Mac system even without technical knowledge. The solution is simple: check cables, update drivers, and modify screen settings. With a few quick fixes, your second monitor will work smoothly again, and you can enjoy a better viewing experience without any screen problems.
Sometimes, your second monitor may start flickering, and it can be hard to understand why. There are a few common reasons behind this issue. Knowing these causes will help you fix the problem faster. Below are the most usual reasons explained.
Let’s have a detailed look at the best fixes for this issue:
Checking your monitor’s cables with ports can solve the issue straightforwardly. You should verify that your HDMI, VGA, or DisplayPort cables maintain secure connections throughout both device ends. Swap to a different cable and check another available port when possible. The primary cause of screen flickering appears in loose or defective wires, which can be repaired easily. Look for physical damage along the cable length. If the cable feels hot or looks worn out, replace it immediately.
Check and Secure Monitor Connections
Your second monitor may flicker due to mismatched display settings. Fixing the resolution, refresh rate, and layout can help the screen work properly. Here’s how to adjust these settings:
Step 1. Click on the “Start” button and open “Settings.”
Step 2. Go to “System” and then select “Display.”
Step 3. Under “Display resolution,” choose the one marked “(Recommended).”
Choose Recommended Resolution
An outdated graphics driver can cause screen flickering on your second monitor. Updating the driver helps your computer and monitor work better together. Follow these simple steps to update your graphics driver easily:
Step 1. Click the “Start” button and open “Settings.”
Step 2. Go to “Windows Update” and click “Check for updates.”
Click Check For Updates
Step 3. Click “Download and install” to get the latest drivers if updates are available.
Sometimes, a wrong or unsupported refresh rate can cause your second monitor to flicker. Setting it to the correct value can make the screen stable. For this:
Step 1. Click the “Apple” logo in the top left corner and select “System Preferences.”
Step 2. Click on “Displays” to open display settings.
Click Displays
Step 3. Hold the “Option” key and click on the “Scaled” option to reveal the “Refresh Rate” dropdown.
Step 4. Select “60Hz” (or another available rate) from the list.
Excessive brightness adjustments and True Tone can cause flickering on your monitor. Turning off these features might fix the issue. To use this fix:
Step 1. Click the “Apple” logo in the top left corner and choose “System Preferences.”
Step 2. Select “Displays” from the options.
Step 3. Uncheck “Automatically adjust brightness” and “True Tone” on the right panel.
Disable Auto Brightness and True Tone Settings
Using the wrong color profile can make your second monitor flicker. Changing the display profile setting to “Color LCD” serves as a solution to fix screen problems. You can modify your Mac’s color profile using the following steps:
Step 1. Access “System Preferences” by clicking the “Apple” logo on your screen.
Step 2. From the system preferences, select “Displays” and click “Display Settings.”
Step 3. Select your monitor from the left-hand panel, then navigate to “Color Profile” on the right side, where you should choose “Color LCD” from the options list.
Select Color LCD
Imagine using your PC as a second screen for your phone. With AnyMiro, you can easily mirror your phone to your computer. It works smoothly and gives you high-quality video with no delay. You can enjoy clear and stable screen sharing, perfect for gaming, drawing, teaching, or church services. The 4K screen quality makes everything look sharp and bright.
AnyMiro maintains the synchronization between sound and video content, preventing all streaming delays. This application enables real-time streaming across YouTube, Twitch, Facebook, and other platforms while maintaining high-quality video transmission. The system provides options to record videos and screenshots when mirroring occurs directly.
Key Features:
Below are the simple steps to use AnyMiro:
Step 1. Open AnyMiro on your computer and choose “iOS/iPadOS.”
Mirror iPhone to Computer
Step 2. Click on the “Wi-Fi connection” option.
Mirror iOS to a Computer via WiFi
Step 3. Connect both your iPhone/iPad and computer to the same Wi-Fi network.
Step 4. Swipe to open Control Center, tap “Screen Mirroring,” and choose “AnyMiro_Computer Name.”
Step 5. Your iPhone screen will now appear on your computer screen.
Step 1. Free download AnyMiro on your computer and open the program.
Step 2. Click on “Android” to start the process.
Mirror Android to Computer
Step 3. Select “USB” and connect your phone with a USB cable.
Select the USB Option for Screen Mirroring Android to PC
Step 4. If necessary, turn on “USB debugging” on your phone and set it to “MTP Mode.”
Enable USB Debugging and MTP Mode for a USB Connection
Step 5. Your phone screen will now be shown on your computer.
Can refresh rate cause my second screen to flicker?
Monitor flickering happens when refresh rates mismatch between the screen and computer system or when the system cannot detect the refresh rate properly. Within your display settings you must choose one of the refresh rate options supported by your monitor among 60Hz or 75Hz.
Do flickers on your screen mean that your monitor needs repairs?
If other fixes fail and flickering continues on all devices, it may be a failing screen or backlight issue. Consider testing with another monitor to confirm.
Can software like AnyMiro help reduce screen issues?
Yes, AnyMiro offers stable screen mirroring from phones to PCs without flickering. It’s great for smooth, high-quality screen sharing—ideal for gamers, creators, and presenters.
You can solve second monitor flickering by performing several basic steps that handle this specific issue. Several simple modifications, such as brightness adjustments, driver updates, and display profile modifications, will significantly improve the situation. For a better screen experience, try AnyMiro. It gives stable mirroring, HD quality, and real-time audio sync.
