Home Voice Changer Is Voxal Voice Changer Safe? All Details About Voice Changer
We may worry about the safety issue when we use the Voxal voice changer. Let’s find the answer today and search for more alternatives to Voxal.
Joy Taylor | Last Updated: May. 04, 2024
1727 words|5minute
  • 180+ lifelike VST and AI voice effects.
  • Compatible with 13 popular third-party platforms.
Available for both Win & Mac
In the world of online interactions, changing your voice can be an enjoyable way to add some mystery or just have a good laugh. The Voxal voice changer is a prevalent tool for this. It enables you to alter your voice in real time for different uses.
But before you start turning your voice into a robot or a chipmunk, you might wonder: “Is Voxal voice changer safe?”
In this guide, we’ll explore that question and provide the major information about Voxal. We will also review the top 5 alternatives to Voxal voice changer so you can have various options.
Whether you’re looking for specific features or something easy-to-use, this guide will help you find the perfect voice-altering tool for all your online adventures.
What Is Voxal Voice Changer?
Voxal voice changer is a free program available for both Windows and Mac that lets you have some fun with your voice in real time. It is a powerful voice changer with effects like Goblin, chipmunk, or even a deep demon voice.
It can simply change your voice live as you play or chat on programs like Skype or create hilarious voice messages. If that’s not enough, you can even add background noise to make you feel like you are in a busy office or a spooky forest.
Is Voxal Voice Changer safe?
We have explored the question, “Is Voice.ai safe?” How about Voxal voice changer?
According to the NCH Software privacy statement, Voxal voice changer respects users’ online privacy. The developers claim to protect users’ personal information no matter where that personal information is collected, transferred, or retained.
You may choose whether to provide personal information. Moreover, the server will encrypt your data using SSL security protection. Personal information will not be transferred to third parties without your approval.
Top 5 Alternatives to Voxal Voice Changer
If you still have second thoughts about using Voxal, many other safe and reliable voice changer apps exist. We have picked five alternatives to Voxal voice changer for you. Then, let’s have a look!
Vozard Voice Changer
The first voice changer on our list is Vozard. It is an AI-powered voice changer that allows you to modify your voice in real time, just like the Voxal voice changer. Therefore, it enhances performance in various scenarios like entertaining pranks, real-time communication, live streaming, and more. The features that might make it a better tool to be trusted with:
Vozard boasts over 180 lifelike voice effects, including impersonations of cartoon characters and celebrities and the usual voice effects. You can find hot icons to impress your friends or audience.
Advanced voice-changing algorithms provide a remarkable voice transformation operation and high-quality sound, creating an immediate and immersive audio environment.
Besides real-time mode, Vozard also enables you to process audio and video files you already have. You can also record the voice in Vozard and then apply the voice effect to the recording.
This tool supports various applications for online interactions. Vozard is compatible with Discord, Zoom, Twitch, Valorant, Fortnite, OBS, and more.
Select the Real-time Mode
Interface of Vozard
Free Download for all windows & 100% safe Free Download for all mac & 100% safe
Both Voxal voice changer and Vozard allow for real-time voice changing with various effects. However, Vozard offers more effects and the capability to refresh communication way by presenting creative sound expressions.
Voicemod Voice Changer
Voicemod is an influential real-time voice changer and soundboard software. Its popularity is attributed to its strong set of features and functionalities. Creating a distinctive acoustic identity is a piece of cake. Here are some noteworthy points:
The Soundboard is a Voicemod Desktop feature that allows you to play sounds or short voice messages in real time directly transferred from your microphone signal. You can choose to add the preloaded effects to your soundboards, as well as the option to create your own. Afterwards, you can also assign keybinds for your sound effects.
You can conduct voice experiments with the Voicelab feature to create custom voice changers by changing the pitch and frequency that cater to your style and preference.
Voicemod AI Voice Changer
Some users suggest Voicemod could be a perfect fit if you prioritize ease of use and soundboard feature. Users can also share their DIY voices in the community.
Clownfish Voice Changer
A strong contender in the search for a voice changer is a very famous software named Clownfish. It’s a voice changer tool for Windows that lets you alter your voice in real time. Clownfish offers some key advantages:
While Voxal might have a free version with limitations, Clownfish is completely free and known for being a smaller download, making it easier on your system resources.
Are you used to using Chrome? Clownfish offers a handy extension that lets you directly modify your voice within web applications like Discord or Skype.
While Voxal and Clownfish offer voice effects morphing, Clownfish goes further. It can be a music player and a text-to-speech tool, making it more versatile.
clownfish
The best choice depends on your needs. If you emphasize a free, lightweight program with Chrome compatibility and bonus features, then Clownfish Voice Changer is definitely worth exploring!
AV Voice Changer
The following safe and reliable voice changer that we recommend is AV Voice Changer. It is a comprehensive audio toolbox that is not only about changing the voice but also provides essential functions to edit, split, record, and alter the recorded voice. Undoubtedly, the AV voice changer works well with your favorite games and chat applications. Let’s learn about the AV voice changer key features in this section:
AV Voice Changer offers a broader range of effects for creative voice changing: 30 voice effects, 70 background effects, 17 non-human voices, 40 plug-in audio effects, and more.
Voice Morpher in the program offers advanced settings. You can even mix parody voices to create a whole new voice effortlessly. It leads to a studio-level experience.
The feature of the file morpher allows it to add effects and convert a batch of audio files at the same time. It’s one of the most popular points among voice-changing users.
av-voice-changer-main-panel
Main Panel of  AV Voice Changer
While Voxal is a good free option, AV voice changer offers a significant leap in features and flexibility and has more control over fine-tuning.
MorphVox Voice Changer
Are you looking for a safe voice changer that is optimized for online games? MorphVox Voice Changer can realize it! It offers a broader range of voice transformations than Voxal, with sound effects and a built-in equalizer. More highlights are listed:
MorphVox offers a free version, MorphVox Junior. You can sound like a man, woman, or little folk with it. You can also upgrade to MorphVox Pro, which unlocks all the features, including the equalizer and more voice effects.
MorphVox adopts ultimate background cancellation to remove distracting elements. It is one of the cleanest-sounding voice changers available on the market.
It supports a graphic equalizer for finely sculpted audio, stereo microphone, and voice parsing detection. The new features take the voice-changing to a new level.
In short, MorphVox is designed for users with a high demand for voice detail and who want to customize and refine those alterations for a more natural sound.
morphvox-screenshot
MorphVox Screenshot
How to Choose a Voice Changer?
With so many voice changer apps, choosing one may take time and effort. However, here are some tips and points to consider when picking the perfect voice changer:
Your Needs: Are you seeking functions for basic fun, online anonymity, or professional voice acting?  Pick a voice changer to meet your needs.
Voice Options: How much variety do you want in voice effects? Some voice changers offer just a few effects, while others have a vast library with over a hundred voices.
Sound Quality: Artificial-sounding voices can be distracting. You may look for a voice changer that is famous for natural-sounding voice modification.
Ease of Use: Do you want to accomplish your goal with one-click operation? Otherwise, do you need advanced settings to control vocal details? Choose a program to match your comfort level.
Good Compatibility: You must ensure the voice changer works with your operating system, chat applications, and games.
Budget: If you’re looking for a voice changer for single use, you can choose the free voice changer. A paid version is a good choice if you’re looking for advanced features and better sound quality.
After considering these tips, you’ll be on the right path to finding the perfect voice changer to change your voice like a professional vocal master!
Regarding voice changers, Voxal is the go-to option for most users. However, is Voxal voice changer safe? We cannot determine the safety and reliability of this tool, but we can offer you some alternative safe and reliable options.
It’s believed that, with this information, you can confidently choose the voice-altering software that suits you! By the way, you can try Vozard first!
Vozard – AI-Powered Voice Changer
Free download Vozard voice changer software to change your voice into anyone you want to enhance online chatting, gaming, live streaming, and content creation experiences.
Joy Taylor
