When using images from stock photo websites like Alamy, you may encounter watermarks that can obstruct the visual appeal and usability of the image. Fortunately, there are several methods available to remove watermarks from Alamy images and enhance their professional appearance. In this blog post, we will explore three effective methods: using Aiseesoft Free Watermark Remover Online, Inpaint, and Cutout pro. Read on to learn how to remove the Alamy watermark and make your images look polished and watermark-free.
How to Remove the Alamy Watermark on Images
Can I Use Alamy’s Photos with a Watermark?
Remove Alamy Stock Photo Watermark with Wipit
How to Erase Alamy Stock Photo Watermark Online with Inpaint
Alamy provides users with a vast library of high-quality stock photos. However, these
images often come with a watermark to protect the copyright and prevent unauthorized use.
While you can use Alamy’s photos with the watermark for personal purposes, it is
essential to
remove the watermark
if you want to use them professionally or for commercial use. Let’s explore the
methods to remove the Alamy watermark.
Wipit , as the Alamy watermark remover, allows you to remove watermarks from images effortlessly. With its user-friendly interface and powerful AI algorithms, you can easily get rid of the Alamy watermark and make your images look professional.
Wipit’s Awesome Features
Follow the steps below to remove the Alamy watermark using Wipit:
Step 1: Begin by free downloading and installing Wipit at no cost and opening it on your desktop. Import your images by dragging and dropping them directly into the program.
Remove Watermark from Images or Videos
Step 2: Select the ‘Select Area’ feature. Highlight the areas with Alamy watermarks you wish to remove and then release the mouse. Wipit’s AI will take over to automatically detect the edges of the watermarks.
Select and Remove Alamy Watermarks
Step 3: Use the ‘Preview’ function to assess the effectiveness of the watermark removal. If satisfied, proceed to click the ‘Export’ button located in the top-right corner to save a clean version of your image.
Preview the Effect
Wipit only removes watermarks and elements from user-owned or authorized content. Users must avoid infringing on others’ intellectual property rights. Unauthorized use of copyrighted material is illegal, and Wipit and iMobie strictly condemn such software usage..
Inpaint is a powerful online tool that enables you to remove unwanted elements, including watermarks, from your Alamy stock photos seamlessly. With its advanced algorithms and intuitive interface, Inpaint makes the process of erasing watermarks quick and efficient. Follow the steps below to erase the Alamy stock photo watermark online using Inpaint.
Step 1: Visit the Inpaint website.
Step 2: Click the “Upload Image” button and select the image containing the Alamy watermark you want to remove.
Click Upload Image
Step 3: Once the image is uploaded, use the brush tool to mark the watermark area you want to erase.
Step 4: Adjust the brush size as needed to accurately mark the watermark area.
Step 5: After marking the watermark area, click the “Erase” button.
Also read: How to Remove Watermark from Placeit >
Cutout.pro is an AI-powered visual content generation platform that offers a wide range of tools for image and video design. With its advanced algorithms and user-friendly interface, Cutout.pro provides an efficient solution for removing watermarks from Alamy stock photos. Follow the steps below to remove the Alamy watermark using Cutout. pro:
Step 1: Click on the “Upload image” button and select the Alamy image from your device that you want to remove the watermark from.
Click Upload Image
Step 2: Use the smear repair brush tool provided by Cutout.pro to highlight the area of the watermark. You can adjust the brush size to 100 pixels and use thick repair to quickly highlight the area.
Remove the Watermark with Cutout.pro
Step 3:
After you have finished removing the watermark, click on the
“Done”
button to preview the result. If you are satisfied with the outcome, click on the download
button to save your Alamy image without the watermark.
1. Can I remove the Alamy watermark without permission?
Removing the Alamy watermark without proper authorization is a violation of copyright laws. Make sure to obtain the necessary permissions before editing or using copyrighted images.
2. Are there any online tools to remove the Alamy watermark for free?
Yes, Aiseesoft Free Watermark Remover Online and Inpaint offer free options to remove watermarks from images. However, they may have certain limitations and paid versions with advanced features.
3. Can I use the removed Alamy images for commercial purposes?
It is crucial to review Alamy’s terms and conditions regarding the use of their images, even after removing the watermark. Some images may have additional licensing requirements for commercial use.
The article provides a comprehensive guide on removing watermarks from Alamy stock photos, which is essential for enhancing the professional appearance of images used for commercial or professional purposes.
In conclusion, while watermarks serve a protective purpose for copyright holders, there are legal and effective ways to remove them for authorized use. Each method presented offers a different approach, catering to various user preferences and requirements. It is crucial to respect copyright laws and use these tools responsibly.
