Caller ID not working is one of the critical issues you would likely encounter on your iPhone. So when you experience it, you should be devastated. Rather you source for solutions to fix it. In this post, we’ve decided to create a simple guide that you can follow to fix iPhone caller ID not working conveniently.
Hello, Lately, my iPhone started displaying “No Caller ID” each time I receive a call from my contacts. I can’t fathom the reason for this and it’s really bothering me. Is there anyone that has encountered such an issue in the past and fixed it? Kindly share your advice if you’ve got solutions.
Receiving phone calls with no caller ID displayed on your screen could be frightening, as you can’t tell whether or not it’s a legitimate person that you are about to connect with. What if we tell you that the call host is someone you know or might have shared your contact with in the past and the “No Caller ID” error is just a minor system glitch?
Well, the caller ID not working error you are experiencing on your iPhone could be attributed to system glitch and other technical issues which are fixable if you’ve got the right guide at hand. This post will demonstrate how to fix iPhone caller ID not working easily. Let’s get started.
iPhone caller ID not working doesn’t just appear all of a sudden. There must be something wrong with your device that could stem up the issue:
Have you tampered with the call settings on your iPhone in the past? If so, then there’s a possibility that your device can display iPhone caller ID not working issues because of this. You need to make adjustments to your phone call settings to fix this issue.
Another reason you may experience caller ID not working problems on your iPhone is OS/system related issues. When you operate your iPhone on an outdated OS or installed a beta version software on it, the device will surely malfunction. You can encounter a wide variety of issues, from unresponsive buttons, system crashes and even caller ID not working.
Sometimes the host of a call conceals their identity for reasons best known to them. If that is the case for caller ID not showing on your iPhone, there is nothing that could be done on your end to rectify the issue. The host must deactivate the hide contact feature for you to see who exactly it is that’s calling you.
Here is another reason your iPhone won’t display your caller ID. Poor network or weak signal interference disrupts the operations of a network and can cause it not to show your caller ID. Changing your location or better yet contacting the customer team can help you resolve the issue.
To solve caller ID not working on your iPhone, you should apply any of the 9 tricks demonstrated below:
AnyFix is one of the top-rated iOS repair tools suitable for fixing any system-related issue you may encounter on your iPhone. It clears a wide variety of problems from a frozen screen to the green line of death and 50+ more. It also comes in handy for resolving iPhone not showing caller ID.
Key Features
Step 1. Download AnyFix and run it on your computer > connect your iPhone to the computer > choose the System Repair.
Choose System Reapir
Step 2. Click on the 50+ iPhone Problems and then tap on the Start Now to go on.
Choose Fix 50+ iPhone Problems
Step 3. Here will list 3 modes for you to fix the iPhone issue. Click on the Standard Repair which won’t risk any data loss.
Step 4. Minutes later, you will see the Repair Completed page on the screen.
System Repair Completed
Another noteworthy solution to resolve iPhone caller ID not working is the activation of the Show My Caller ID feature on your device. This is very important since an alteration in call settings can cause your iPhone to malfunction and display the underlying problem. It works for all iPhone models, from the older ones down to the latest.
Activating the Show My Caller ID feature on your iPhone is super simple and can be done directly from the device itself. Here’s how you can do this on your iPhone:
Show My Caller ID in iPhone Settings
Outdated carrier setting is among the reasons why your device displays the no caller ID error when you receive a call from your contact. Updating the corresponding carrier settings on your iPhone is a great solution you can employ from the comfort of your house to fix the issue.
Here’s the simple procedure to follow if you are looking to fix iPhone not showing caller ID using the update carrier settings option:
Check Carrier Settings Update
Should you still experience the iPhone not showing caller ID problems after using the solution above, then you have to contact your network provider for help. Sometimes the issue can be from your network provider’s end, as some carriers often require customers to subscribe premium for caller ID to be displayed. Kindly connect with your carrier to seek assistance.
When you notice that the caller ID isn’t showing on your iPhone, the date and time on your device are worth checking for you to fix the issue. A date and time could sometimes be the chief reason why your iPhone won’t show your caller ID. You need to check and make the necessary adjustments to rectify the issue.
Here’s the direction to follow for you to check and change your iPhone’s date and time:
Check the Date & Time Settings
A simple network reset can fix the iPhone not showing caller ID on your device. This solution helps you restore the operations of your network provider without compromising your system. Here’s how to do this on your iPhone:
Have you for any reason enabled call blocking and identification on your iPhone in the past? If true, then you may experience caller ID not showing on your device. It’s time to deactivate the feature so your phone can go back to normal and start displaying caller ID immediately.
This solution fixes iPhone caller ID not showing issues for all models and it’s super easy to use. You can follow the step-by-step instructional guide shared down here to check whether or not call blocking and identification is enabled on your iPhone:
Now, we’ve demonstrated the 7 ways to fix the iPhone not showing caller ID for any iPhone model. All solutions have been tested and confirmed to offer positive results. However, AnyFix offers the ultimate solution from the options provided. The software clears caller ID not showing on your iPhone and other issues without damaging your system. It’s simple to use and offers excellent results within the shortest possible time.
