Is Facebook Marketplace showing the wrong location or listings from another city? This guide explains why it happens and how to fix your Marketplace location step by step.
Quick Answer: If your Facebook Marketplace location is wrong, the most common causes are disabled Precise Location, an incorrect Marketplace location filter, a VPN, outdated app cache, or a mismatch between your phone’s GPS and Facebook’s saved location. To fix it, enable Precise Location for Facebook, manually update your Marketplace city or ZIP code, adjust the search radius, clear cache, disable VPN, and restart the app.
If you are searching for my Facebook Marketplace location is wrong or Facebook Marketplace listing location wrong, you are likely seeing listings from another city, state, or even country. This usually does not mean your account is broken. It means Facebook is pulling location data from the wrong source or using an outdated location signal.
You open the Facebook app, ready to find local deals, only to be met with a frustrating reality: Marketplace is showing you items from a completely different city, state, or even country. It’s a common issue that can make the entire platform feel useless—the digital equivalent of trying to shop at your local market and finding yourself in a town hundreds of miles away.
For a long time, I used to get so frustrated manually changing my location every single day, not realizing my phone’s main settings were the real problem. If you’ve been stuck in a loop of manually correcting your location only to have it revert, you’re not alone.
This is not just a random glitch. It is usually a solvable settings mismatch between your phone, browser, VPN, and the Facebook app. This 2026 step-by-step guide provides tested ways to fix your Facebook Marketplace location, so you can see the local listings you actually want.
Before changing every setting on your phone, it helps to understand the most likely reason. Facebook Marketplace does not rely on one single location source. It may use your device GPS, Wi-Fi signal, IP address, profile city, app permissions, browser location, and saved Marketplace filters.
When one of these signals conflicts with another, Facebook Marketplace may show listings from the wrong city or keep switching back to an old location.
Most common causes include:
The most common reason for an incorrect Marketplace location is a specific operating system setting that only gives Facebook an approximate location. To fix this, you must adjust your Facebook location permissions to enable high Facebook GPS accuracy.
This single adjustment is the most important step and resolves the issue for many users on modern devices. Enabling Precise Location instructs your phone to provide the Facebook app with your exact coordinates, not just a generalized area.
If you’re using an older device, you may not see a Precise Location toggle. Don’t worry. You can still improve your location accuracy.
For these devices, manually setting your Marketplace location and clearing the cache become even more important, because the app may rely more heavily on saved location data.
After you have corrected your device’s permissions, the next essential step is to manually reset your location inside Marketplace. This action forces the app to sync with your updated device settings and ensures the Facebook Marketplace location filter is accurate.
Attempting to change location on Facebook Marketplace without first fixing permissions is the primary reason many users find their location keeps reverting back.
Understanding why the Facebook Marketplace location bug happens can help you prevent it. Marketplace does not use a single source to find you. It combines several data points, and a conflict between these signals is almost always the root of the problem.
Here are the primary location signals Facebook uses:
The conflict usually occurs on mobile devices when Facebook location permissions are set to approximate, which clashes with more precise Wi-Fi or GPS data. On desktop, a VPN is one of the most common reasons why Facebook Marketplace shows the wrong location.
If you’ve corrected permissions and manually set your location but still see the wrong nearby listings, a more persistent issue might be at play. These steps address stubborn problems, especially if your location resets every time you close the app.
On Android: Navigate to Settings > Apps > Facebook > Storage & cache > Clear cache.
On iPhone: The most effective way to clear the cache is to offload and reinstall the app.
A Virtual Private Network can make it look like you’re in a different location. Disable any active VPN on your device, fully close the Facebook app, and then reopen it.
If the problem continues after all these steps, it may be a temporary server-side error with Facebook itself, which often resolves within 24-48 hours.
To ensure this fix remains effective, periodically check your app permissions after major phone operating system updates, as these can sometimes reset location settings.
Seeing the wrong city in Facebook Marketplace is a barrier that prevents you from finding the local deals you’re looking for. By following the correct two-step procedure—first enabling Precise Location in your phone’s settings and then manually updating your location within the app—you directly address the root cause of this widespread issue.
This is not just a temporary workaround. It is the permanent solution that syncs your device with the app’s expectations. You can now regain control over your Marketplace experience, confidently browse for items in your actual area, and finally make the platform work for you.
If your Facebook Marketplace location keeps showing the wrong city and built-in settings do not fully solve the issue, using a desktop-based location changer can be a more reliable option.
Tools like Fonelora Location Changer let you modify your device’s GPS location directly, which can help ensure Marketplace displays listings from your desired area.
Compared to tweaking app settings or relying on unstable mobile apps, this method works at the system level and supports the official Facebook app, making it a practical solution for users who need more precise control over their location.
Follow these steps to fix your Marketplace location:
Step 1. Download and install Fonelora Location Changer on your Windows or Mac computer.
Step 2. Choose the mode on the main screen.
Step 3. Click Move to update your GPS location.
Your Marketplace location is most likely wrong because Facebook lacks Precise Location permission on your phone. Modern operating systems often default to an approximate location for privacy, which can place you in a nearby city or several miles away. Other causes include an outdated app, active VPN, broad search radius, corrupted cache, or incorrect saved Marketplace filters.
Your Facebook Marketplace listing location wrong issue usually happens when Facebook auto-fills the location from your device, profile city, or previously saved Marketplace settings. To fix it, edit the listing and manually enter the correct city, ZIP code, or pickup location before publishing.
If my Facebook Marketplace location is wrong, start by enabling Precise Location for Facebook in your phone settings. Then open Marketplace, manually update your city or ZIP code, adjust your radius, tap Apply, and restart the app.
The most effective solution is a two-part process. First, go into your phone’s main settings, find the permissions for the Facebook app, and enable Precise Location. Second, open Marketplace and manually set your desired location and search radius. This syncs the app with your correct device settings and prevents it from reverting.
Facebook Marketplace usually prioritizes your device’s live location data from GPS and Wi-Fi over the city listed in your public profile. Your profile city is typically only used as a fallback location if the app cannot get accurate real-time location information from your phone or computer.
This usually happens for three reasons:
Yes. A VPN can make Facebook think you are browsing from a different city, state, or country. Disable the VPN, fully close Facebook, reopen the app, and manually reset your Marketplace location.
Enable Precise Location, clear app cache, disable VPN, update the Facebook app, and manually save your Marketplace location with the correct radius. If the app still reverts, reinstall Facebook or wait 24-48 hours in case the issue is server-side.
Dealing with an incorrect Facebook Marketplace location can be frustrating, especially when it limits your ability to find relevant local deals. Fortunately, there are several effective ways to fix the issue, from adjusting app permissions to manually resetting your Marketplace location filter.
If built-in options do not work, tools like Fonelora Location Changer offer a flexible alternative by letting you precisely control your device’s GPS location. This method works with the official Facebook app and provides greater control over where your Marketplace listings appear.
By choosing the right approach, you can ensure more accurate local listings, fix wrong listing locations, and enjoy a smoother, more personalized Marketplace experience.
