Monster Hunter Now Best Gunlance Build: Master Defense and Damage
Switching from fast weapons to Gunlance feels frustrating at first because mobile dodge habits no longer work. By focusing on Guard and Artillery skills, controlled blocking, precise shelling combos, sharpness management, and reload timing, players can achieve consistent, rewarding high-star hunts.
Author Avatar Joy Taylor Last Updated: May. 07, 2026
Transitioning to heavy weapons in a mobile action game often brings an initial wave of frustration. The swift swipe-to-dodge reflex that saves you with Dual Blades or the Long Sword suddenly gets you locked into heavy animation frames, resulting in harsh damage from monster attacks.
Consider the experience of a fellow mobile hunter, Ryan. When he first forged a Gunlance, he struggled immensely with the mobile swipe controls. He found himself frantically tapping, getting caught mid-animation, and taking massive chip damage from high-star monsters. The weapon felt sluggish and punishing. However, after experimenting with different setups, he shifted to a loadout focused strictly on Guard and Artillery skills, while entirely rethinking how he interacted with his phone screen. Instead of swiping constantly to chase monsters, he adopted a controlled rhythm: holding the screen to block, waiting for the monster to strike, and executing precise screen taps for shelling combos. Over time, his hunts became vastly more consistent, and he found the weapon incredibly rewarding once he mastered its mobile rhythm.
Monster Hunter Now
Monster Hunter Now
If you are confused about which armor skills actually benefit the Gunlance, how to execute complex combos on a touch screen, or why your weapon sharpness seems to vanish in seconds, you are not alone. Gunlance performance relies heavily on balancing survivability with consistent damage output. Unlike fast weapons, its strength comes from controlled positioning and shelling bursts. Experts emphasize prioritizing artillery and guard-related skills to enhance both offense and defense. Maintaining sharpness and managing reload timing are critical for sustaining damage during longer encounters. A well-optimized build focuses less on raw attack stacking and more on synergy between shelling mechanics and defensive uptime. By mastering the physical screen inputs and understanding the reality of high-star monster encounters, you can assemble the best Gunlance build in Monster Hunter Now and command the battlefield.
Core Armor and Skills for Your Loadout
To maximize your combat efficiency, you need gear that directly modifies the Gunlance’s unique traits. Because shelling deals fixed damage—meaning it ignores monster weak points—your priority is boosting that baseline damage while ensuring you can survive heavy hits.
However, many generic guides recommend setups that completely ignore the necessity of targeting specific monster parts. On a mobile screen, precision targeting is difficult without assistance. Therefore, a truly optimized Gunlance armor setup must include Lock-On, alongside your core Artillery and Guard skills.
The Optimal Defensive and Targeting Loadout
Crafting the ideal armor set requires hunting specific monsters to extract synergistic gear. Below is the tested procedure for maximizing your damage while retaining the ability to break targeted parts:
Armor Slot Recommended Gear Primary Skill Benefit Strategic Purpose
Head Basarios Helm Artillery Lv. 1 Provides an immediate boost to baseline shelling damage.
Mail Basarios Mail Artillery Lv. 1 Stacks shelling damage bonuses.
Vambraces Rathian Vambraces Lock-On & Burst Lv. 1 Grants Lock-On. Vital for targeting breakable parts for extra rewards and monster staggers.
Coil Barroth Coil Guard Lv. 2 Creates critical guard skill synergy for impenetrable defense against early-to-mid game monsters.
Greaves Basarios Greaves Artillery Lv. 1 Completes the essential Artillery Level 3 requirement.
By securing this exact configuration, you achieve Artillery Level 3, Guard Level 2, and Lock-On. This combination minimizes the stamina drain and chip damage associated with blocking while allowing you to lock onto a monster’s head or tail to focus your explosive damage exactly where it is needed.
Mobile Combat Guide: Touch Inputs and Combos
Equipping the right gear is only the first step. Executing the correct combat rhythm on your smartphone dictates your success. Console terminology like “Slam” or “Full Burst” means nothing if you do not know the finger motions required to trigger them in the app.
Here is exactly how to perform the core Gunlance movements on your phone screen:
  • Standard Block: Hold your finger on the screen.
  • Upward Thrust: While blocking, Tap the screen once.
  • Overhead Slam: Swipe Up during a combo or after a dash.
  • Fire Shell: Tap the screen immediately after an upward thrust or slam.
  • Quick Reload: Swipe Down after firing a shell to quickly reload your magazine.
Shelling Types and Mobile Rhythms
Aligning your physical screen inputs with your specific weapon type is crucial for maximizing your damage output.
  1. Wide Shelling (The “Poke-Shell” Rhythm): Wide shells have the highest uncharged damage and are perfect for aggressive, close-range combat.
    • Mobile Input: Tap (Thrust) -> Tap (Fire Shell) -> Tap (Thrust) -> Swipe Down (Quick Reload).
  2. Long Shelling (The Charged Approach): Long shells offer superior range and are devastating when charged, providing a safer distance from the monster.
    • Mobile Input: Hold screen (Charge Shell until it glows) -> Release (Fire) -> Repeat.
  3. Normal Shelling (The “Full Burst” Combo): Normal shelling magazines hold the most ammo, making them perfect for firing every shell at once for massive damage.
    • Mobile Input: Swipe Up (Slam) -> Tap (Full Burst) -> Swipe Down (Quick Reload).
The Reality of High-Star Hunts: Perfect Dodging and Sharpness
If you are fighting 4-star or 5-star monsters, holding the screen to block and absorbing the impact works perfectly. However, transitioning into 8-star and 9-star hunts introduces a harsh reality: standing your ground against late-game monsters is a quick way to fail. Even with Guard Level 2 or 3, the sheer force of high-tier attacks will cause severe chip damage, draining your health potions rapidly.
To survive the endgame, you must master the Perfect Dodge.
Swiping left, right, or backward at the precise moment a monster’s attack connects triggers a slow-motion window. Unlike blocking, a Perfect Dodge entirely negates chip damage. More importantly for the Gunlance, executing a Perfect Dodge automatically reloads a shell. This is a game-changing mechanic that allows you to maintain continuous damage uptime without stopping to perform a manual Quick Reload.
Managing Your Sharpness Meter
A common misunderstanding is how the Gunlance handles weapon sharpness. Shelling consumes sharpness at an incredibly high rate. If you only spam shells without considering your gauge, your sharpness will drop into the red zone quickly. When this happens, your physical thrusts and slams will bounce off the monster, leaving you wide open to counterattacks.
Do not simply rely purely on shelling when your sharpness degrades. Instead, approach the hunt strategically:
Upgrade Your Weapon: Higher-grade weapons naturally have longer sharpness bars, allowing you to shell longer before degrading.
Use Perfect Dodges: By Perfect Dodging to reposition and automatically reload, you optimize your damage windows, ensuring that every shell counts rather than wasting them into a monster’s armored sections.
Target Weak Points: While shelling does fixed damage, your physical thrusts and slams still rely on raw damage and sharpness. Use your Lock-On skill to ensure your physical hits are striking soft spots, reducing the chance of your weapon bouncing as your sharpness drops.
Optional Resource Solutions: Location Simulation for Materials
Constructing an optimized Gunlance build requires a high volume of specific monster parts, particularly from Basarios and Barroth. Acquiring these materials manually exposes the inherent mobility limitations of augmented reality (AR) gaming, such as region-locked biomes and slow monster respawn rates. For players who live in rural areas or have limited physical mobility, farming the required nodes can cause progress to stall entirely.
If you are completely blocked from upgrading your gear due to a lack of local biomes, location simulation software is an alternative resource-gathering method.
Accelerate Material Gathering with Fonelora
Fonelora Location Changer is a premium software designed to streamline material gathering for players who cannot access necessary biomes. It functions as a GPS location management tool that operates without requiring a jailbroken or rooted device.
Please note: This tool is strictly for managing your GPS location to access varied biomes for material farming . It does not alter your combat mechanics, DPS, or shelling choices in-game.
Step 1: Download and Install
Download Fonelora Location Changer from the official website and install it on your computer.
Step 2: Connect Your Device
Connect your iPhone or Android device using a USB cable.
  • On iOS: Tap “Trust This Computer” when prompted
  • On Android: Enable USB Debugging
Change Your GPS Location
Step 3: Choose a Location
Open the map interface in the software:
  • Enter a specific location (such as an airport or busy area)
  • Or select a point directly on the map
Change Location instantly
What is the best Gunlance build in Monster Hunter Now?
The most effective setup is a hybrid defensive and artillery build featuring Lock-On. Using Basarios armor pieces to achieve Artillery Level 3, a Barroth Coil for Guard Level 2, and Rathian Vambraces for Lock-On provides a highly functional, target-focused combat experience.
Which shelling type is strongest for Gunlance?
No single type is universally superior. Normal is excellent for burst damage during knockdowns using the Swipe Up -> Tap combo. Long offers great range for safe charged shots (Hold and Release). Wide excels at quick, highly responsive poke-and-shell tactics (Tap -> Tap).
How do I stop my sharpness from dropping so fast?
Shelling naturally degrades sharpness faster than standard melee attacks. Ensure your weapon is upgraded to the highest possible grade for a longer sharpness gauge, and focus on weaving Perfect Dodges into your combat rhythm to maximize your damage efficiency without wasting ammo.
Reclaim Your Hunting Experience
Transitioning to a shield-based weapon on a mobile device is a unique challenge. By stepping away from panicked swiping and intentionally investing in Lock-On, Guard, and Artillery armor skills, you actively solve the core frustrations of the Gunlance. Translating theoretical combos into precise screen taps, swipes, and Perfect Dodges allows you to maintain your sharpness and control the flow of combat. Equip your artillery gear, lock onto your target, and dominate your next hunt.
