In this guide, we will explore the reasons why Wireless Display sound not working and provide effective solutions to help you resolve sound problems and ensure seamless wireless display usage. Whether you’re using wireless displays for work, entertainment, or education, this guide is your go-to resource for troubleshooting and resolving sound-related complications.
Use screen mirroring tool AnyMiro as an alternative to Wireless Display.
Available for both Win & Mac
Wireless Display on Windows has become an integral part of our daily lives. It provides a remarkable level of convenience, allowing for the effortless sharing of both screen content and audio. This means that you can easily connect your Windows device to a larger screen without the fuss of dealing with tangled cables.
However, many people will encounter the issue that the Wireless Display sound not working. Such issues not only disrupt the smooth flow of work but can also make our entertainment and learning experiences less enjoyable. In this detailed guide, we’ll explore Windows wireless display technology. We’ll uncover the reasons for wireless display sound not working on Windows issues and provide practical fixes.
Windows Wireless Display, also known as Miracast, is a built-in feature of the Windows operating system. It allows users to mirror Android to PC onto other screens or devices that support Miracast or wireless display standards, such as smart TVs, projectors, monitors, or Miracast-compatible wireless display adapters. This feature provides a convenient way for users to interact with and share content on larger screens without the need for any wired connections.
The benefits of Windows Wireless Display are as follows:
It’s not uncommon for users to encounter issues that Wireless Display sound not working. Here are several common reasons for sound issues specifically related to the Microsoft Wireless Display.
After knowing some possible reasons for the Wireless Display sound not working, please don’t worry. In the following article, we will assist you in resolving this issue.
On your Windows device, make sure the Microsoft Wireless Display Adapter is selected as the audio output source. Right-click the volume icon in the taskbar and select “Sound” or “Sound settings” to verify the output device.
Visit the official Microsoft website or the manufacturer’s website for the Microsoft Wireless Display Adapter. Download and install the latest drivers and firmware updates. This can resolve sound issues related to outdated or incompatible drivers.
Ensure that both the Microsoft Wireless Display Adapter and your Windows device’s volume settings are not muted or set to a very low level. Adjust the volume to an appropriate level.
Make sure that your Windows device and the Microsoft Wireless Display Adapter are connected to a stable Wi-Fi network. Interference or a weak network connection can disrupt audio transmission.
Try reconnecting the Microsoft Wireless Display Adapter to your Windows device. Sometimes, a simple reconnection can resolve temporary audio problems.
The various methods mentioned above are all about helping you solve wireless display sound not working issues internally. However, there’s an even better solution, which is to use a third-party screen mirroring software called AnyMiro. Since wireless display often encounters problems, we recommend using AnyMiro for a superior screen mirroring experience.
AnyMiro supports screen mirroring in both WiFi and USB modes, making it suitable for various locations and situations. You can opt for a USB data cable for screen mirroring when WiFi isn’t available. It also offers cross-platform connectivity, working seamlessly across Windows, Apple, and Android devices, ensuring high compatibility without any latency or lag.
When using AnyMiro, you will experience the following outstanding features:
Here are the steps of how to mirror Android to PC using Anymiro:
Step 1: Click the download button here or go to the official website to download AnyMiro.
Step 2: Choose the “Android” option to connect your device.
Mirror Android to Computer
Step 3: Click the WiFi icon to link your Android device to WiFi.
Mirror Android to Computer via WiFi
Step 4: Download the AnyMiro app on your phone. You can download it through Google Play or by scanning the QR code.
Download AnyMiro App on Your Phone
Step 5: Tap WiFi Connection and choose your computer to connect.
Tap WiFi Connection
Wait for a few seconds, you’ll see your Android screen mirrored on your computer’s display.
1. How do I use a Wireless Display on my PC?
To use a Wireless Display on your PC, go to “Settings,” select “System,” then “Display,” and click on “Connect to a wireless display.” Choose the target device to project your PC’s screen wirelessly.
2. Where is the Wireless Display settings?
The Wireless Display settings can be found in the “Settings” app on your PC. Navigate to “System,” then “Display,” and look for the “Connect to a wireless display” option to access the settings.
3. How do I activate Miracast on Windows?
To activate Miracast on your Windows PC, ensure your device supports Miracast, open the “Action Center” from the taskbar, click “Connect,” and choose your desired Miracast-enabled display or adapter from the list that appears. Your PC will then establish a wireless Miracast connection, allowing you to project your screen onto the selected display.
This article discusses the common reasons for Wireless Display sound not working and provides solutions to address this issue. However, for a more effective solution, we recommend using AnyMiro as an alternative to Wireless Display for both wireless and wired screen mirroring. AnyMiro offers the advantages of enhanced convenience, stable connections with minimal disconnections, and superior screen mirroring quality.
