Home Voice Changer Top 5 Voxal Voice Changer Alternatives: Best Voice Changers
Voxal is a well-known software for voice modulation and transformation. However, are you searching for a suprior one? Follow us to find more exciting alternatives.
Joy Taylor | Last Updated: Apr. 24, 2024
1858 words|6minute
  • 180+ lifelike VST and AI voice effects.
  • Compatible with 13 popular third-party platforms.
Available for both Win & Mac
Are you looking to add a touch of whimsy to your social media posts to create more engaging content? Are you eager to attract more attention with higher entertainment value in live streaming? AI voice changers are here to help you!
In the world of AI voice changing, Voxal has been a familiar name. However,  you may continue to look for a superior voice changer beyond Voxal. If you encounter this case, you’re at the right place now. Here, you can explore new options, unlock more features, and finally find a suitable Voxal voice changer alternative.
This blog unveils the Top 5 Voxal voice changer alternatives. We’ll discuss their features and strengths, revealing our top pick. Are you ready to elevate your voice-changing experience? We will uncover the best fit for you. Join us now!
Voxal Voice Changer Review
Imagine a magic tool that turns your voice into a robot, a chipmunk, or even an alien! That’s what Voxal Voice Changer is. It’s a desktop program for Windows and Mac that allows you to change your voice in real time. You can use it while chatting with friends online, playing games, or making videos.
Voxal Voice Changer
Key Features
What Do People Think?
Voxal is a popular choice for many reasons. Since it’s easy to use, Voxal is a great solution for beginners to voice-changing software. Some users find the voice effects realistic, while others say they can sound a bit distorted or artificial.
Overall, Voxal Voice Changer is a funny way to disguise your voice.
If you’re interested in exploring other voice changer programs, here are some Voxal voice changer alternatives:
  1. Vozard Voice Changer
  2. Clownfish Voice Changer
  3. AV Voice Changer
  4. MorphVox Voice Changer
  5. Voice Changer With Effects
Let’s have a look at them in detail.
The top one on our list is Vozard! It is the best Voxal voice changer alternative.
Vozard is a cool program that lets you change your voice in various ways. Like Voxal voice changer, it is a desktop software available for both Windows and Mac.
Free Download for all windows & 100% safe Free Download for all mac & 100% safe
Vozard is like Voxal but with some extra features. Vozard gives you the freedom to change your voice in multiple ways. You can speak directly into your microphone and have your voice transformed with effects in real time. Alternatively, you can upload pre-recorded audio or video files and apply voice effects afterward.
There is no recording? Don’t worry! Vozard also enables you to record your voice using the software. Then, you can apply different effects to find the perfect transformation.
While both Vozard and Voxal voice changers can alter your voice, Vozard might be a better alternative for specific reasons. Here’s what makes it interesting.
Key Features of Vozard voice changer:
Why Choose Vozard?
Vozard is an excellent choice for a Voxal voice changer alternative because its free version has many features. Moreover, the voice effects Vozard offers sound good compared to other free programs.
Clownfish is a popular application on Windows and works with many programs, like Steam, Skype, Hangouts, ooVoo, Viber, Ekiga, Jitsi, Ventrilo, TeamSpeak, Mumble, Discord, etc. Once you set it up, your voice will be automatically transformed with funny effects in whatever app you use.
It works in real time. This means you speak into your microphone, and the program instantly changes your voice with the chosen effect. However, there are only 14 voice effects. It may limit your entertainment.
Key Features of Clownfish Voice Changer:
Why Choose Clownfish?
Ultimately, the best choice for a voice changer depends on your needs. If you want to change your voice in games and chats seamlessly, you should try Clownfish Voice Changer.
AV Voice Changer
AV Voice Changer is a powerful desktop tool. This software lets you edit and modify your voice in many ways, especially modifying every voice characteristic. Your voice can sound deeper, higher, younger, or older. This tool enables you to change your voice in real time or edit pre-recorded audio files.
AV Voice Changer
AV Voice Changer
Key Features of AV Voice Changer:
Why Choose AV Voice Changer?
You can do amazing age and gender transformations using AV voice changer. Moreover, its diamond version does not change your voice in real time. It creates a complete home audio workstation with all the tools you need to create your masterpiece recordings.
MorphVox Pro Voice Changer
MorphVOX Pro is a desktop program for both Windows and Mac. It is a user-friendly tool that lets you transform your voice for online games, chat apps, or just for fun. It focuses on real-time voice changing. Its new features of voice comparison analysis and tuning, as well as voice parsing detection, make it more professional in voice work.
MorphVOX Pro Voice Changer
Key Features of MorphVOX Pro Voice Changer:
Why Choose MorphVox Pro?
MorphVox offers jocular effects and a user-friendly interface. If you want voice-changing software with smoother results and many features, MorphVox should be within your consideration.
Voice Changer With Effects is a mobile application you can use as a Voxal voice changer alternative.
This application is perfect for quick voice transformation. It’s easy to have fun with your voice on a mobile device. However, it doesn’t offer real-time voice changing.
Voice Changer With Effects Application
Key Features of Voice Changer With Effects:
Why Choose Voice Changer with Effects?
If you want to change your voice simply just by using your phone, then the Voice Changer With Effects is your ideal match. This application is easy to use, convenient, and perfect for portable fun.
That’s everything from our side. Before the ending, look at some FAQs about Voxal voice changer alternatives.
FAQs
Voxal voice changer has a free version but is a freemium model, so some features are limited. You need to buy plus plans for additional features and removal of limitations. The plus plans are as follows:
Normal Price Discount Price
Voxal Voice Changer Plus – Commercial License $60 $29.99
Voxal Voice Changer Plus – Home use only $50 $24.99
Yes, several good free voice changers are available, and we have already discussed those in this article. Vozard voice changer is a strong recommendation! It stands out for its versatility and ease of use, offering a good selection of features in its free version. This allows you to change your voice in different ways.
Take Vozard as an example. First, check your microphone input. Then, choose your voice-changing mode and select one AI voice effect. Speak and you can hear your changing voice.
Final Words
The world of voice-changing is full of entertainment and innovation! This guide explores several Voxal voice changer alternatives. They all have their own strengths and the best Voxal alternative depends on your specific needs.
There is no doubt that Vozard voice changer is a special free alternative to Voxal. It lets you change your voice in three convenient ways. And the best part is, you can enjoy all these features for free!
Vozard – AI-Powered Voice Changer
Free download Vozard voice changer software to change your voice into anyone you want to enhance online chatting, gaming, live streaming, and content creation experiences.
Joy Taylor
