If your iPhone Back Tap does not work, first check if your device supports this feature. Then make sure Back Tap is turned on in settings. Restart the phone if the problem continues. Finally, update iOS or use AnyFix to repair all system issues in minutes and restore Back Tap to its normal function.
Back Tap on iPhone makes it effortless to perform quick actions. You can take screenshots or open apps – all with a double or triple-tap on the back of your device. But sometimes, this feature doesn’t respond to the touch. And if you’ve been using it regularly to perform tasks, this can be frustrating. But don’t worry. This guide explains the reasons behind the iPhone Back Tap not working issue and how to fix it using 7 effective ways.
Also read: How to fix iPhone screen not responding to touch
The main reason why back tap isn’t working is that your device simply cannot sense your fingers tapping. Here are more specific reasons behind it:
Below, we’ve listed the most helpful solutions to help you restore BackTap. Go through each to find the one that works for you.
The first thing to do is to make sure your device supports the Back Tap feature. The function was introduced with iOS 14. While iOS 14 is available on iPhone 6s and later, be aware that only devices from iPhone 8 and later can use Back Tap. So, make sure your device fits these criteria for this function to work.
Your phone’s case can also cause the iPhone Back Tap not working issue. This is because BackTap uses gyroscope and accelerometer sensors. These help your phone recognize pressure or touch sensitivity. A thick or rugged case will block these signals.
To confirm it, remove your case. Then, test the feature again. If it’s working, switch to a thinner case or discard it altogether to resolve the issue.
The next thing you can do is to make sure the back tap feature is turned on in settings. If it is already active, switch it off once. Then turn it on again to refresh the function. This will help remove any glitches interfering with back tap. Here are the steps:
Back Tap can also stop working due to random glitches with your device’s system. A restart can help fix the problem if there’s no complicated issue.
The steps vary for different iPhone models:
For iPhone 8 and SE (2nd/3rd gen):
Hold the Side button > Slide to power off > Press the Side button again.
For iPhone X or later:
Press and hold the Side + Volume buttons > Slide to power off > Hold the Side button to restart.
You may also like: iPhone force restart not working
If the issue of iPhone Back Tap not working persists even after a restart, try resetting your device’s settings. This will restore all customized settings. But it will not affect your stored data.
Sometimes the problem comes from outdated software. Older iOS versions contain bugs and cause compatibility issues. Newer updates can fix these bugs and improve your device’s performance.
To update your device:
If the methods above do not work, there might be something wrong with your iPhone’s system. Finding the exact cause on your own takes time. In this case, you can use AnyFix to repair the problem. It is an iOS system repair tool that can fix common system issues without data loss. With 3 flexible repair modes from AnyFix, you can pick the right level based on the complexity of your problem.
AnyFix does more than fix Back Tap issues. It also resolves serious iTunes errors with ease. You can upgrade or downgrade iOS, reset a locked iPhone without a password, and more. It’s a complete toolkit to keep your device in the best condition.
Key Features of AnyFix:
Download AnyFix now and fix iPhone back tap not working issue in just clicks!
Steps to Fix iPhone System With AnyFix:
Step 1. Open AnyFix and select the System Repair mode.
Step 2. Connect your device to your PC with a USB cable. Then choose Device Bug from the given list.
Step 3. Select Standard Repair mode, which won’t cause data loss.
Step 4. Follow the on-screen instructions to finish downloading firmware for your iPhone. Then, click Start Standard Repair to start the repair process.
Step 5. AnyFix will repair any system issues on your device. Once done, your iPhone will update to the latest version and the back tap issue should have been fixed.
iPhone back tap not working is a common issue. But you can take simple steps like checking settings or removing the case to resolve it effectively. When there is a deeper system issue involved, AnyFix can help you tackle it quickly. It provides diverse repair modes, each with a high success rate. It also supports many iPhone models, including iOS 26. If you want to fix Back Tap issues without any lengthy steps and keep your device running flawlessly, download and try AnyFix today.
