Many Pokémon GO players search for ways to increase shiny odds after spending hours catching, raiding, and walking without finding a single shiny. The frustrating part is that the game does not clearly explain which methods actually improve your chances and which ones only feel like they should work.
Quick Answer: You cannot directly change the base shiny odds in Pokémon GO. However, you can improve your real results by hunting during boosted events, choosing encounters with better shiny rates, and increasing the number of Pokémon you check per hour. Community Day, Raid Day, Legendary Raids, and high-spawn routes are the most effective ways to find more shinies.
This guide explains how shiny odds work, which events offer better rates, how to increase your total encounters, and which shiny hunting myths do not actually help.
The most important thing to understand is that shiny odds are not the same for every Pokémon. Some encounters use the standard wild shiny rate, while others have boosted rates during special events, raids, or limited-time features.
Knowing the approximate shiny rates helps you decide where to spend your time. If you only check random wild spawns, your odds may feel painfully low. If you focus on Community Day, Raid Day, or certain boosted species, your chances can be much better.
| Encounter Type | Approximate Shiny Rate | What It Means |
| Standard Wild Spawn | ~1 in 500 | The default rate for many common wild Pokémon. |
| Permaboosted Species | ~1 in 64 | Some species have a permanently boosted shiny rate, such as Onix, Scyther, or Bronzor. |
| Legendary & Mythical Raids | ~1 in 20 | Most shiny-eligible 5-Star Raid Bosses use this rate. |
| Mega Legendary Raids | ~1 in 64 | Some Mega Legendary encounters use lower boosted odds. |
| Community Day | ~1 in 25 | The featured Pokémon usually has heavily boosted shiny odds during the event window. |
| Raid Day | ~1 in 10 | One of the strongest shiny boosts available for selected raid Pokémon. |
| Egg Hatches | Varies | Shiny odds depend on the Pokémon and event pool. |
Key point: You cannot force a normal wild Pokémon to have better shiny odds. What you can do is target encounters that already have boosted rates and increase the number of encounters you check.
There are two different ideas that players often mix together: changing shiny odds and increasing shiny chances. Pokémon GO does not let players directly change the base shiny rate for a species, but you can still increase your practical chance of finding a shiny by making better choices.
| Method | Does It Change Base Shiny Odds? | Can It Help You Find More Shinies? | Why |
| Community Day | No, but the event itself has boosted odds | Yes | The featured Pokémon usually appears everywhere with a much better shiny rate. |
| Raid Day | No, but the event uses boosted odds | Yes | Selected raid bosses often have very strong shiny rates during the event. |
| Fast Catch Technique | No | Yes | It lets you check more Pokémon per hour. |
| High-Spawn Routes | No | Yes | More spawns mean more shiny rolls. |
| Lures and Incense | No | Sometimes | They add more encounters, but do not improve the shiny rate per Pokémon. |
| Re-tapping the Same Pokémon | No | No | A Pokémon’s shiny status is already determined for that encounter. |
The best strategy is not looking for a secret shiny trick. It is combining boosted events, high encounter volume, and efficient catching so you create more chances within the same amount of time.
To get more shinies in Pokémon GO, you need to increase your total number of shiny checks. The goal is simple: instead of checking 100 Pokémon in an hour, try to check 200, 300, or more during high-spawn events.
Cutting down the time spent on each encounter is the most important part of this strategy. The more Pokémon you check, the more shiny rolls you create.
The fast catch technique is one of the most useful methods for active shiny hunting. It lets you skip the catch animation and return to the map faster, saving several seconds per encounter.
Here is the basic process:
The game will still process the catch in the background, but you can immediately move on to the next Pokémon. During events like Community Day or Spotlight Hour, this can dramatically increase your total checks.
Location matters because shiny hunting is based on total encounters. Parks, downtown walking routes, campuses, shopping areas, and dense PokéStop clusters usually produce more spawn checks than random walking.
Related Guide: Shiny Eevee Evolutions in Pokémon GO: All Forms & How to Get Them >
Playing during the right event is the most reliable way to improve shiny results. Events do not let you manually change shiny odds, but some events are designed with boosted shiny rates or much higher spawn volume.
Community Day is usually the best event for targeting one specific shiny Pokémon. The featured Pokémon appears in large numbers for a limited time and usually has a much better shiny rate than standard wild spawns.
Raid Day events often provide some of the strongest shiny odds in Pokémon GO. If the featured Pokémon is shiny-eligible, this can be one of the fastest ways to hunt that specific shiny.
Many shiny-eligible Legendary Raid Bosses have an approximate shiny rate around 1 in 20. This is much better than standard wild odds, but it usually requires Raid Passes and enough nearby or remote players.
Spotlight Hour does not always boost shiny odds, but it can greatly increase spawn volume for the featured Pokémon. If that Pokémon can be shiny, the event can still be useful because you can check many more encounters in one hour.
Some seasonal events, research events, hatch events, or special celebrations include boosted shiny rates for selected species. Always check the in-game News section before planning a shiny hunt.
Route planning can help you find more shinies because it increases encounter volume. It does not change Pokémon GO shiny odds directly. The goal is simply to move through more active spawn points during the time you have available.
Some players use GPS route planning tools to review locations, plan movement, or manage location-based gameplay more flexibly. One option is Fonelora Location Changer, which supports route simulation and joystick-style movement on iPhone and Android without jailbreak or root.
Fonelora Location Changer does not increase the base shiny rate in Pokémon GO. It can only help with route planning or location-based movement efficiency. Shiny results still depend on encounter volume, event rates, and chance.
For most players, the safer starting point is still simple: choose a high-spawn walking route, play during boosted events, use fast catching, and check as many eligible Pokémon as possible.
Many shiny hunting tips sound convincing but do not actually increase shiny odds. Avoiding these myths helps you focus on methods that create more real opportunities.
Related Guide: How Much Stardust to Trade a Shiny in Pokémon GO? Cost Chart >
Here are direct answers to the most common questions about how to increase shiny odds in Pokémon GO.
You cannot directly change the base shiny rate for a Pokémon. However, you can improve your real chance of finding shinies by hunting during boosted events and checking more Pokémon per hour.
Yes, but only when the game itself provides boosted odds through events or specific encounter types. Community Day, Raid Day, and shiny-eligible Legendary Raids are examples where shiny rates may be better than standard wild spawns.
Focus on encounter volume. Play during shiny-boosted events, use fast catching, hunt in high-spawn areas, and prioritize Pokémon or events with better shiny rates.
No. Lures and Incense do not improve the shiny rate itself. They can still help because they create more encounters, which gives you more chances to find a shiny.
Raid Day events often provide some of the strongest shiny odds, sometimes around 1 in 10 for the featured Pokémon. Community Day is also strong, often around 1 in 25 for the featured spawn.
No. Fast catching does not change the shiny rate. It helps because it lets you check and catch more Pokémon in less time.
Finding more shiny Pokémon in Pokémon GO is not about forcing the game to give you better luck. It is about understanding shiny rates, choosing the right events, and increasing the number of Pokémon you check.
For the best results, prioritize Community Day, Raid Day, shiny-eligible Legendary Raids, and high-spawn routes. Use fast catching to reduce wasted time, and avoid myths that promise guaranteed shiny results.
Tools like Fonelora Location Changer may help with route planning and location-based movement flexibility, but they do not change shiny odds directly. The real strategy is simple: target better shiny rates, create more encounters, and use your event time efficiently.
More Related Articles
