Joy Taylor
Joy Taylor | Last Updated: Jul. 10, 2026
Quick Answer: There are eight shiny Eevee evolutions in Pokémon GO: Vaporeon, Jolteon, Flareon, Espeon, Umbreon, Leafeon, Glaceon, and Sylveon. You can guarantee each one once with the nickname trick, but after that only Espeon, Umbreon, Leafeon, Glaceon, and Sylveon have repeatable control methods. Vaporeon, Jolteon, and Flareon become random after the nickname trick has been used.
If you have a shiny Eevee, do not tap the Evolve button too quickly. The wrong choice can waste a one-time nickname, give you a random Kanto evolution, or turn a rare shiny into a form you did not want. This guide shows every shiny Eevee evolution, the correct nickname, the repeatable method, and the safest way to choose before evolving.
All Shiny Eevee Evolutions in Pokémon GO
Before using candy or a nickname, check the full shiny Eevee evolution list. Each Eeveelution has a different shiny appearance and a different evolution method. Some can be controlled repeatedly, while others are random after the one-time nickname trick.
Shiny Eevee Evolution Shiny Look Nickname Trick Repeatable Method Can You Control It After Nickname?
Vaporeon Purple / magenta body Rainer Random evolution from Eevee No
Jolteon Bright green fur Sparky Random evolution from Eevee No
Flareon Muted tan / gold color Pyro Random evolution from Eevee No
Espeon Vivid green body Sakura Walk 10 km as buddy, then evolve during the day Yes
Umbreon Black body with blue rings Tamao Walk 10 km as buddy, then evolve at night Yes
Leafeon Slightly darker green accents Linnea Evolve near a Mossy Lure Module Yes
Glaceon Paler icy blue color Rea Evolve near a Glacial Lure Module Yes
Sylveon Blue accents instead of pink Kira Earn 70 hearts with Eevee as your buddy Yes
  • Vaporeon: Purple shiny look. Nickname: Rainer. Random after nickname.
  • Jolteon: Green shiny look. Nickname: Sparky. Random after nickname.
  • Flareon: Tan/gold shiny look. Nickname: Pyro. Random after nickname.
  • Espeon: Green shiny look. Nickname: Sakura. Walk 10 km as buddy and evolve during the day.
  • Umbreon: Black with blue rings. Nickname: Tamao. Walk 10 km as buddy and evolve at night.
  • Leafeon: Darker green accents. Nickname: Linnea. Evolve near a Mossy Lure.
  • Glaceon: Pale icy blue. Nickname: Rea. Evolve near a Glacial Lure.
  • Sylveon: Blue accents. Nickname: Kira. Earn 70 buddy hearts.
The most important difference is control. If you want shiny Espeon, Umbreon, Leafeon, Glaceon, or Sylveon, you can use repeatable requirements. If you want shiny Vaporeon, Jolteon, or Flareon after the nickname trick, the result is random.
Related Guide: How to Increase Shiny Odds in Pokémon GO >
Shiny Eevee Evolution Names: One-Time Nickname Trick
The nickname trick is the fastest way to control a shiny Eevee evolution in Pokémon GO. It works for shiny Eevee the same way it works for a normal Eevee, but it has one strict limitation: each nickname can only be used once per account.
Note
Important: The nickname trick is one-time only for each evolution. For example, if you use Kira to evolve a shiny Eevee into Sylveon, you cannot use Kira again later to guarantee another Sylveon on the same account.
Complete Shiny Eevee Nickname List
How to Use the Nickname Trick Safely
Follow these steps carefully before evolving your shiny Eevee:
Nickname trick process in Pokémon GO
Do not rely on the nickname alone. The silhouette check is the real confirmation. If the silhouette does not match the evolution you want, the nickname may have already been used, may be misspelled, or may not have synced yet.
Repeatable Methods After the Nickname Trick
After the nickname trick has been used, you still have repeatable ways to control five shiny Eevee evolutions. These methods are especially important if you want multiple shiny Umbreon, shiny Sylveon, shiny Glaceon, or other controlled forms.
Tips
For Vaporeon, Jolteon, and Flareon, there is no repeatable control method after the nickname trick. Evolving Eevee normally will randomly give one of the three Kanto evolutions.
How to Evolve Shiny Eevee into Espeon
To get shiny Espeon after using the Sakura nickname trick, use the buddy walking method.
How to Evolve Shiny Eevee into Umbreon
Shiny Umbreon uses the same buddy walking requirement as Espeon, but the evolution must happen at night.
Tips
For Espeon and Umbreon, always check the silhouette before evolving. If the silhouette is not correct, do not tap Evolve. Wait for GPS and time-of-day conditions to update correctly.
How to Evolve Shiny Eevee into Leafeon
Shiny Leafeon can be controlled with a Mossy Lure Module.
How to Evolve Shiny Eevee into Glaceon
Shiny Glaceon uses the same lure method, but requires a Glacial Lure Module.
How to Evolve Shiny Eevee into Sylveon
Shiny Sylveon requires the buddy heart method. This takes longer than the lure methods, but it is repeatable and reliable once the requirement is complete.
A Poffin can speed up the process because it helps you earn more buddy hearts in a day. If shiny Sylveon is your main target, plan the buddy heart requirement before using your candy.
Related Guide: How to Get Shiny Sylveon in Pokémon GO >
Shiny Eeveelution Color Comparison
Some shiny Eevee evolutions look dramatically different from their normal forms, while others are more subtle. Before choosing an evolution, compare the color changes so you know what you are getting.
All shiny Eeveelutions next to their normal-colored counterparts
Evolution Shiny Color Palette Visual Difference
Vaporeon Vibrant purple One of the most noticeable shiny changes among Eeveelutions.
Jolteon Bright green A clear and recognizable color change from yellow to green.
Flareon Muted tan / gold A subtle shiny that can look underwhelming compared with other forms.
Espeon Vivid green A dramatic color change and one of the easiest shiny forms to recognize.
Umbreon Blue rings and accents A fan-favorite shiny because the blue accents stand out against the black body.
Leafeon Darker green accents A subtle shiny with only modest color differences.
Glaceon Paler icy blue A cleaner, colder blue tone, but not as dramatic as Vaporeon or Espeon.
Sylveon Blue accents A strong color swap from pink to blue, making it one of the most popular choices.
Shiny Eeveelution color comparison table
If you care mostly about appearance, shiny Umbreon, shiny Sylveon, shiny Vaporeon, and shiny Espeon are usually the easiest to appreciate visually. If you want a complete shiny Eeveelution collection, save your one-time nicknames and plan each form carefully.
Which Shiny Eevee Evolution Should You Choose?
The best shiny Eevee evolution depends on your goal. Some players want the best-looking shiny, some want battle value, and others want to complete the full shiny Eeveelution collection.
Best for Visual Appeal
Best for Control
If you do not want to risk a random result, choose one of the controllable evolutions: Espeon, Umbreon, Leafeon, Glaceon, or Sylveon. Each has a repeatable method after the nickname trick.
Best for Collection Completion
If your goal is to collect all shiny Eevee evolutions, plan the Kanto trio carefully. Vaporeon, Jolteon, and Flareon are the hardest to target after their nicknames are used because normal Eevee evolution randomly selects one of the three.
Best for a High-IV Shiny Eevee
If your shiny Eevee has strong IVs, do not rush. Check whether you want a form with battle value or whether you want to wait for an event move. A rare shiny with good IVs is worth planning around.
Which Shiny Eeveelution Is the Rarest?
Mechanically, no shiny Eevee evolution is rarer than the others once you already have a shiny Eevee. The real rare part is finding the shiny Eevee itself. After that, rarity mainly depends on how easy the evolution is to control.
That said, some shiny Eeveelutions feel rarer to players because they take more effort or are harder to target:
In practical terms, the rarest shiny Eeveelution for your account may be the one you have not been able to control or roll yet. This is why planning nickname use matters.
When to Evolve Your Shiny Eevee
Sometimes the best move is to wait. A shiny Eevee is rare, and evolving it too quickly can lead to regret if you later catch a better IV version or if a special event offers an exclusive move.
Check IVs Before Evolving
Open your shiny Eevee and use the in-game Appraise feature before choosing an evolution.
In-game appraisal system for a Pokémon
Consider Waiting for Special Events
Pokémon GO events sometimes allow Eeveelutions to learn exclusive moves. If you have a high-IV shiny Eevee, waiting for a Community Day Classic or special evolution event may make the final evolution more useful.
Save Nicknames for the Right Eevee
The nickname trick is valuable because it is limited. If you only have one shiny Eevee and low IVs, consider using repeatable methods first and saving one-time nicknames for stronger shiny Eevee later.
Related Guide: How Much Stardust to Trade a Shiny in Pokémon GO? Cost Chart >
Here are quick answers to common questions about shiny Eevee evolutions in Pokémon GO.
What are all the shiny Eevee evolutions?
What are the shiny Eevee evolution names?
The nickname names are Rainer for Vaporeon, Sparky for Jolteon, Pyro for Flareon, Sakura for Espeon, Tamao for Umbreon, Linnea for Leafeon, Rea for Glaceon, and Kira for Sylveon.
Does the nickname trick work on shiny Eevee?
Yes. The nickname trick works on shiny Eevee, but each nickname only works once per account. Always check the evolution silhouette before tapping Evolve.
Can I control shiny Vaporeon, Jolteon, or Flareon?
You can control each one once with the nickname trick. After that, evolving Eevee normally will randomly produce Vaporeon, Jolteon, or Flareon.
How do I get shiny Sylveon in Pokémon GO?
Use the Kira nickname if you have not used it before, or set shiny Eevee as your buddy and earn 70 hearts. Once the requirement is complete, the Evolve button should show Sylveon.
Which shiny Eevee evolution is best?
For appearance, many players prefer shiny Umbreon, shiny Sylveon, shiny Vaporeon, or shiny Espeon. For collection planning, the best choice is the one you can control without wasting a limited nickname.
Which shiny Eeveelution is the rarest?
Mechanically, none is rarer once you have shiny Eevee. Perceived rarity comes from effort and control. Sylveon takes more buddy work, while Vaporeon, Jolteon, and Flareon become random after the nickname trick.
Conclusion: Choose Your Shiny Eevee Evolution Carefully
Getting a shiny Eevee is exciting, but the evolution choice should not be rushed. Pokémon GO gives you a one-time nickname trick for each shiny Eeveelution, and several repeatable methods for controlled evolutions after that.
If you want a specific form, always check the nickname, method, and silhouette before evolving. Use repeatable methods for Espeon, Umbreon, Leafeon, Glaceon, and Sylveon whenever possible, and be extra careful with Vaporeon, Jolteon, and Flareon because they become random after the nickname trick.
For the best result, compare shiny colors, check IVs, consider future events, and save your one-time nicknames for the Eevee you really want to evolve. With the right plan, you can build your shiny Eeveelution collection without wasting a rare shiny catch.
Change GPS Location Easily
Free Download Free Download
