If your iPhone update failed, the right fix depends on where the process stopped. Your iPhone might be unable to find an update, download it, verify it, or finish installing iOS. If you are trying to install iOS 27, first confirm that your iPhone model supports it; then identify the stage where the update failed.
Start with the least disruptive checks before considering a restore. Check compatibility, the network, and available storage, and note the exact message on screen. If wireless updating keeps failing, try updating through a Mac or Windows PC before considering another installation method.
An iOS update may fail for several reasons:
The most useful first step is to match the error message to the stage where the update failed.
| What You See | What to Check First |
| No update appears in Settings | Check device compatibility, update availability, and the network connection. |
| Unable to Check for Update | Check the internet connection and Apple service status; try another reliable network. |
| Unable to Download Update | Check Wi-Fi and available storage, then retry the download. |
| Unable to Verify Update | Try another network and, if the error persists, remove and download the update again. This specific error may need more targeted troubleshooting. |
| Preparing Update or installing appears slow | Connect the iPhone to power and allow the process to finish. Do not interrupt an installation just because it is slow. |
| An error code appears on a computer | Record the exact code and follow the matching Apple update or restore instructions. |
Not every iPhone supports every iOS release. If your device is not compatible with the version you are trying to install, changing Wi-Fi networks or downloading the same update again will not solve the problem.
Apple's current compatibility list includes the iPhone 11 family and newer supported models, as well as iPhone SE (2nd generation and later). The listed models span the iPhone 11, 12, 13, 14, 15, 16, and 17 families; iPhone Air; iPhone 18 Pro and iPhone 18 Pro Max; and iPhone SE (2nd and 3rd generations). Support is model-specific, so check the exact model rather than relying only on the phone's age.
For Apple's official troubleshooting steps when an iPhone or iPad will not update, see If your iPhone or iPad won't update.
If your iPhone is not on the compatibility list, a computer or third-party tool cannot make an unsupported model install iOS 27. If your model is supported but the update still does not appear, continue with the network and storage checks below, then try a computer-based update if needed.
A network problem can prevent your iPhone from checking for, downloading, or verifying an update. A website opening successfully does not always mean that every connection needed for a software update is working correctly.
If the same alert returns on more than one network, stop repeating the network test and move to Step 5 to download the update again or Step 6 to update through a computer.
An iOS update needs enough available storage to download and install its files. The amount required varies by update, so there is no single free-space figure that applies to every iPhone.
Once installation starts, keep the iPhone connected to power and allow the progress bar to finish. It can move slowly depending on the update size and the files on the device.
Restart only if the update has failed and the iPhone has returned to its normal lock screen or Home Screen. Do not interrupt an installation that is still showing a progress bar.
A restart can clear a temporary software state, but it will not resolve compatibility, storage, or server issues. If the phone is frozen or shows an Apple logo without returning to the Lock Screen, follow guidance for that specific symptom instead.
If the update still will not install or the same connection or verification alert returns after testing more than one network, try downloading the update again.
This removes the downloaded update package, not your photos, apps, or other iPhone content. If the update entry is not listed, or the same issue returns after a fresh download, stop repeating this step and try a computer-based update.
If the iPhone repeatedly fails to update wirelessly, a computer gives you another way to install iOS. Back up your iPhone first if possible. Before connecting, update the computer and use a cable that can transfer data, not just charge the device.
If the computer cannot detect the iPhone or shows an error, do not immediately choose Restore. First use the error-code checks in the next section. Update is the option intended to reinstall iOS without intentionally erasing personal data; Restore erases the device.
If a Mac or PC displays an error while updating or restoring the iPhone, write down the exact error number and message before trying another step. Different codes can indicate different problems, so choose the next step based on the specific code instead of repeating every general fix.
| Error Code or Message | What It May Indicate | What to Try First |
| 17, 1638, 3000–3020, 3100–3999, or “device isn't eligible for the requested build” | The computer may be unable to communicate with Apple's software update servers, or the requested build may not be eligible for the device. | Update macOS, Apple Devices, or iTunes; check the computer's internet connection; then check whether a firewall or security tool is blocking the connection. If needed, try another network or computer. |
| 13, 1600–1604, 1611, 1643–1650, 2000, 2001, 2002, 2005, 2006, 2009, or “Invalid response” | The error may involve the USB connection, cable, port, or communication between the device and computer. | Connect the iPhone directly to the computer, try another Apple-certified cable and USB port, and retry. Avoid USB hubs and keyboard ports. |
| 4037 | The iPhone is locked and the computer cannot update it in that state. | Unlock the iPhone and tap Trust if prompted, then try again. |
| 4005, 4013, or 4014 | The update or restore process was interrupted or the computer could not complete communication with the device. The code alone does not prove a hardware failure. | Retry the update, restart the iPhone and computer, check the cable and USB port, and make sure the computer's Apple software is up to date. If the error persists, seek further support. |
| 10 | The iOS software on the device may be too new for the computer's current software. | Update macOS, or install the latest Apple Devices app or iTunes on Windows, reconnect the iPhone, and try again. |
These groups are troubleshooting clues, not definitive diagnoses. If your code is not listed above, or the suggested first step does not resolve it, use these general checks in order:
Do not disable security protection indiscriminately. If security software may be blocking the connection, review its settings carefully or ask your IT administrator for help.
If the iPhone no longer starts normally, shows the recovery screen, or displays the Apple logo for several minutes without a progress bar, stop repeating routine update checks. See our guide to an iPhone stuck on the Apple logo for symptom-specific guidance. If the device still cannot be updated, seek help before choosing Restore. In recovery mode, choose Update first if that option is offered and your goal is to reinstall iOS without erasing data. If Update is unavailable or fails, Restore may be required; it erases the device. If a computer downloads the software for more than 15 minutes and the iPhone exits the recovery screen, let the download finish, then reconnect the iPhone and enter recovery mode again.
If your iPhone supports iOS 27 but wireless updating and the computer's built-in update method still fail, AnyFix offers an alternative way to download and install a supported iOS firmware package. Use this method only if the target version is listed for your exact iPhone model.
Important: AnyFix cannot make an unsupported iPhone compatible with iOS 27 or bypass Apple's firmware-signing restrictions. If the upgrade option is unavailable or the process returns an error, stop and follow the error message rather than repeatedly retrying the same operation. Some AnyFix features may require a paid license.
Want to Update to iOS 27 but Can't Update Wirelessly?
Upgrade or downgrade your iPhone to a supported iOS/iPadOS version, including iOS 27 when compatible firmware is available and still signed by Apple.
Fix 150+ iOS/iPadOS/tvOS system issues, including an iPhone stuck on the Apple logo or in a boot loop.
Enter or exit Recovery Mode on iOS devices in one click, without a passcode.
Fix 200+ iTunes errors that can interrupt iPhone updates or restores.
Repeated failures can result from device incompatibility, insufficient storage, network problems, a problematic downloaded update, or an installation error. Identify the stage where the failure occurs and change your troubleshooting approach if the same fix does not work.
First confirm that your exact iPhone model supports iOS 27. Then connect to a reliable network, make sure enough storage is available, and check Software Update again. If iOS 27 still does not appear or the wireless update repeatedly fails, try updating through a Mac or Windows PC. Install an earlier update first only if your device explicitly prompts you to do so. A computer-based method cannot bypass device compatibility or Apple's firmware-signing requirements.
Deleting the downloaded update file from iPhone Storage is not the same as erasing the device. However, deleting other content to free up space can remove personal data, so check what you are deleting and make sure important information is backed up.
Wireless updating may require Wi-Fi, depending on the device and update. If wireless updating is unavailable or repeatedly fails, you can try updating through a compatible Mac or Windows computer.
There is no fixed duration; it depends on the update size, connection speed, and installation stage. Keep your iPhone connected to power and do not interrupt a visible progress bar just because it moves slowly. If the phone becomes unresponsive or stays on the Apple logo, follow guidance for that specific symptom rather than repeating routine update steps.
No. A factory reset should not be the first response to a failed update. Check compatibility, network access, storage, and the downloaded update file first. If necessary, try a computer-based update before considering a restore that may erase your data.
Record the exact alert or error code, then choose the next step based on that code rather than repeating every general fix. If the iPhone cannot start normally, the buttons needed for recovery do not work, or an update and recovery attempt both fail, contact Apple Support or an Apple Authorized Service Provider.
An iPhone update failure does not automatically mean your device is damaged or needs to be erased. Identify the failed stage, try the relevant low-risk checks, and move to a computer-based update or official recovery guidance only when necessary.
