Rosé is a New Zealand singer and dancer of Korean descent who rose to fame as a member of the globally acclaimed K-pop girl group BLACKPINK. As BLACKPINK's main vocalist and lead dancer, Rosé is known for her unique and soulful voice, as well as her impressive stage presence. In addition, her sense of style has made her a sought-after figure at major fashion events and campaigns.
Original
Modified
Now you can make your voice sound like Rosé in Vozard. Try it! Embark on a remarkable way of expression and entertainment with the Vozard AI voice generator.
Ready to explore the possibilities of Vozard? Diverse and lifelike AI voices perfectly adapt to different scenarios, enhancing your voice-changing experience and letting your imagination run wild.
Choose the voice-changing mode
Check your microphone input
Choose the Rosé voice effect
Speak and you can hear your voice changing
With 180+ realistic voice effects, Vozard spices up your voice as you can transform it into any character you like. Break the limitation of your voice with Vozard’s AI voices!
Adopting AI-enhanced algorithms to change your voice to the target character, Vozard real-time voice changer, leads to a natural and lifelike voice change.
Vozard includes diverse voice effects, from celebrities to cartoon characters, from video game figures to movie roles, and it’s constantly updating its voice library.
It integrates seamlessly with popular gaming, live streaming, and online chat platforms, including Discord, Twitch, OBS, Zoom, Fortnite, Roblox, and more.
Vozard voice changer has an intuitive and user-friendly design. For beginners, it provides you with a built-in user manual. You can generate AI voice with Vozard quickly.
Vozard gives 3 voice-changing options - Real-time, Recorded, and Upload File. Change your voice for instant talking or content creation, Vozard can satisfy your needs.
Vozard AI voice changer lets you modify and customize the pitches and tones. Customize the AI voices, control the pitches of the voice effects, and change your voice.
Find more voice-changing tips and hot sound effects for ultimate fun.
To change your voice into Rosé on your PC, you can use AI voice changer software like Vozard. Download and install the application, adjust the settings, select and download the Rosé AI voice effect, and start voice-changing.
Yes, real-time voice changer such as Vozard provides you with many AI voice effects, helping you change your voice to different famous characters. Whether you want to change your voice in online chatting or online gaming, Vozard will help.
Vozard. Supported by cutting-edge AI algorithms, Vozard can keenly capture the essence and soul of each character’s voice to set the proper tone. As a result, you can change the voice with one click.
