How to Get an AT&T Network Unlock Code
AT&T does not publish one universal network unlock code for every phone. Eligible devices may unlock automatically, while other devices require an approved AT&T request and model-specific instructions. This guide explains the current requirements, application process, request status, and common code prompts.
Author Avatar Joy Taylor Last Updated: Jun. 22, 2026
Quick Answer: AT&T does not offer a public code that works on every locked phone. Eligible Apple, Google, and some Samsung devices may unlock automatically. If the phone is still locked, submit an official AT&T device-unlock request. The device must meet the applicable Wireless, Business, or Prepaid requirements before AT&T approves the request or provides device-specific instructions.
What Is an AT&T Network Lock?
An AT&T network lock restricts a phone or connected device to AT&T's network until the device becomes eligible and is unlocked. Network unlocking allows the device to accept a compatible SIM or eSIM from another carrier. It does not remove the phone's screen PIN, password, pattern, Apple ID, Google Account, or other ownership protection. Unlocking does not guarantee that the phone supports every band, SIM, eSIM, or feature on the new carrier.
Prompt or Lock Type What It Protects Correct Next Step
Network lock or carrier lock Restricts the device to a carrier network Check AT&T eligibility and submit an official unlock request
SIM PIN Protects the SIM card from unauthorized use Enter the correct SIM PIN; this is not a carrier-unlock code
PUK or PUK2 Unlocks a SIM after too many incorrect PIN entries Get the PUK from AT&T. Too many incorrect PUK attempts can block the SIM and require a replacement.
MCK or defreeze prompt Can appear after failed network-unlock attempts on some devices Stop guessing and contact AT&T or the device manufacturer
Screen PIN, pattern, or password Protects access to the phone and its data Use the device maker's account or screen-lock recovery process
For a broader explanation of the term, see the guide to a master unlock code . Do not treat a master code, MCK, PUK, or screen password as the same thing as AT&T carrier unlocking.
Do You Need an AT&T Unlock Code?
Not every eligible AT&T device requires a manually entered code. AT&T says eligible Apple, Google, and some Samsung devices on an AT&T Wireless plan may unlock automatically after all requirements are met. Apple Watch is unlocked by default.
How to Check Whether the Device Is Already Unlocked
Device or Account Where to Check
AT&T Wireless account Sign in, select the device, and look for Device unlocked in Device info
iPhone Open Settings > General > About and check Carrier Lock
Samsung released before September 1, 2025 Open Settings > About phone > Software information and review the Service provider software version
Samsung released after September 1, 2025 Open Settings > Connections > More connection settings and check Network lock status
AT&T Prepaid device with a physical SIM Insert a non-AT&T SIM. An incompatibility message indicates that the device is still locked
If the device remains locked or its status is unclear, use the AT&T device-unlock request . Do not assume the phone needs a universal 16-digit code.
AT&T Device Unlock Requirements
The applicable rules depend on whether the device is on AT&T Wireless, AT&T Business, or AT&T Prepaid.
Account Type Main Requirements
AT&T Wireless The device was purchased more than 60 days ago, is paid in full, is not active on another AT&T account, has not been reported lost, stolen, or involved in fraud, and the current customer's bill is not past due
AT&T Prepaid The device has six months of paid AT&T service, is not active on another AT&T account, and has not been reported lost, stolen, or involved in fraud
AT&T Business The device meets the age, payment, account, contract, and fraud-status rules, and the controlling company permits the unlock
Deployed active-duty military AT&T states that deployed military personnel do not have to pay off the device before requesting an unlock; select the military option during the request
The 30-day waiting rule applies to an AT&T Business device that was on a two-year contract and was upgraded early. It is not a general rule for every personal AT&T Wireless customer.
You do not need to be a current AT&T customer to request an unlock, but the device must still meet all applicable requirements.
How to Submit an AT&T Unlock Request
Have the device IMEI ready. You can usually display it by dialing *#06# or by checking the device's About or Status settings.
For an AT&T Wireless Device
  1. Check whether the device already shows as unlocked in the AT&T account or device settings.
  2. Open the AT&T unlock request page .
  3. Enter the requested account or device information and follow every prompt.
  4. Check the email or text message AT&T sends about the request.
  5. Follow the model-specific instructions after approval.
For a Device Owned by a Non-AT&T Customer
  1. Submit the official request using the device information, including the IMEI when requested.
  2. Open AT&T's confirmation email.
  3. Select Confirm your request within 24 hours.
  4. If the confirmation window expires, submit a new request.
For an AT&T Prepaid Device
  • Prepaid Android: Use the AT&T Device Unlock app . AT&T directs Prepaid Android users to this app, but the app listing says it works only with supported AT&T Prepaid devices. Do not sideload an unverified copy if the app is unavailable or incompatible.
  • Prepaid iPhone: Use the online AT&T unlock-request page.
Use only the information requested by AT&T. A third-party generator cannot change the device's balance, fraud status, account association, or service history.
How to Check the AT&T Unlock Request Status
Open the link in the email or text message AT&T sent about the request. You can also use the AT&T unlock status portal with the request number and device IMEI.
AT&T says approval usually takes a few minutes, but it can take up to 48 hours. Check spam and junk folders as well as text messages before submitting a duplicate request.
What to Do After AT&T Approves the Request
Follow the instructions in AT&T's approval message for the exact device. Some devices unlock automatically, while others ask for a code after a non-AT&T SIM is inserted. AT&T's own device instructions show that the code length and entry path vary by model, so a universal 16-digit value cannot be assumed.
Before changing service, ask the new carrier to verify the device IMEI, network-band support, SIM or eSIM support, and feature compatibility. A successful AT&T unlock removes the carrier restriction but does not make an incompatible device compatible.
  • Do not enter guessed codes repeatedly. Some devices limit the number of attempts.
  • Use a compatible SIM or eSIM from the new carrier.
  • Restart the device after following the approval instructions.
  • For an iPhone 13 or earlier, AT&T says a factory reset may be required in some cases; follow the AT&T or Apple instructions provided for the device.
  • If the approval message does not match the phone's prompt, contact AT&T before entering another code.
AT&T also publishes device-specific unlock-code instructions for supported phones and mobile hotspots.
Why Was the AT&T Unlock Request Denied?
Reason What to Check
The device is not paid off Confirm that the installment balance is zero
The device was purchased fewer than 60 days ago Wait until the applicable Wireless or Business age requirement is met
The account is past due Bring the current AT&T account up to date
The device is active on another AT&T account Remove or transfer the device correctly before requesting the unlock
The device was reported lost, stolen, or involved in fraud Resolve the status with the account owner and AT&T; do not use a code generator
A non-customer request was not confirmed Submit a new request and confirm the email within 24 hours
The Prepaid service period is too short AT&T Prepaid generally requires six months of paid service
The device came from another carrier Contact the original carrier rather than AT&T
Are Free 16-Digit AT&T Unlock Codes or Generators Real?
There is no public 16-digit AT&T code that works on every phone. Current AT&T instructions include automatic unlocking for some eligible devices and device-specific code procedures for others. Official instructions show that some devices use different code lengths and entry methods.
A website that promises a shared, hacked, or generated code without checking the IMEI, device model, account status, and eligibility cannot verify that the code matches the phone. Repeated incorrect entries may block further network-unlock attempts on some devices.
Before using any third-party SIM unlock tool or service, confirm that it addresses carrier network locking rather than a screen password, SIM PIN, or FRP. The safest first step is the official AT&T request.
FAQs About AT&T Network Unlock Codes
Does AT&T use a 16-digit network unlock code?
Not for every device. Eligible Apple, Google, and some Samsung devices may unlock automatically. Other devices receive model-specific instructions after AT&T approves the request. The required code length and entry method can vary by device.
Can I get an AT&T network unlock code for free?
Use AT&T's official device-unlock process. AT&T does not publish one universal code for every phone. The device must meet the current eligibility requirements before AT&T approves an unlock or provides device-specific instructions.
What are the current AT&T Wireless unlock requirements?
For most AT&T Wireless devices, the device must have been purchased more than 60 days ago, be paid in full, not be active on another AT&T account, and not be reported lost, stolen, or involved in fraud. A current customer's account cannot be past due.
Can a non-AT&T customer unlock an AT&T phone?
Yes, when the device meets AT&T's eligibility requirements. Submit an unlock request and select the confirmation link in the email within 24 hours. Otherwise, AT&T requires a new request.
How long does an AT&T unlock request take?
AT&T says approval usually takes a few minutes, but it can take up to 48 hours. Check email, text messages, spam folders, and the request-status portal for updates.
How do I unlock an AT&T Prepaid phone?
An AT&T Prepaid device generally needs six months of paid service and must meet the other eligibility rules. AT&T directs Prepaid Android users to the Device Unlock app, but app compatibility is limited to supported devices. Prepaid iPhones use the online unlock-request process.
Is an MCK the same as an AT&T network unlock code?
No. An MCK or defreeze prompt, SIM PIN, PUK, screen lock, and carrier network lock are different. Stop entering random codes if the phone reports that network unlocking is blocked, and contact AT&T or the device manufacturer.
Why was my AT&T unlock request denied?
Common reasons include an unpaid device balance, a device purchased fewer than 60 days ago, a past-due account, active use on another AT&T account, a lost or stolen report, or failure to confirm a non-customer request within 24 hours.
The correct way to unlock an AT&T phone is to verify the device status, meet the applicable eligibility rules, and use AT&T's official request or Prepaid app. Do not rely on a universal 16-digit code, random MCK values, or a screen-unlock product for a carrier network lock.
After AT&T approves the request, follow the exact instructions for the device and avoid repeated guesses if the phone displays a different prompt.
