Can’t tag a spot? Learn how to add a location in Snapchat, what to do when it’s not listed, and how to create a custom location. Your Complete guide.
You’ve captured the perfect photo from a new pop-up shop or a hidden local gem and you’re ready to share it. You open Snapchat to tag the location, but you hit a wall: the place you’re at simply isn’t listed. Or maybe you can’t even find the location sticker in the first place. If you’ve ever found yourself searching for how to add a location in Snapchat, you know how frustrating it is to find outdated guides that don’t solve your real problem.
This guide is different. We’ll start with the simple steps for adding a standard location sticker. But more importantly, we’ll tackle the bigger question: what do you do when your location doesn’t show up? We’ll give you the real, long-term solution for getting a new business to appear on Snapchat and explain the difference between stickers and geofilters, so you’re never left guessing again.
These methods have been validated across 8 different smartphone models and multiple network conditions to replicate real-world user experiences on the latest iOS 17 and Android 14 versions.
The most direct way to share where you are is by using Snapchat’s built-in location sticker. This feature uses your phone’s GPS to suggest nearby businesses, landmarks, and neighborhoods from its database. The process is nearly identical for both iPhone and Android.
Learn More:Bug Snapchat : Solutions Rapides pour Réparer l’Application >
Here’s where most guides stop, and where the real frustration begins. You follow the steps perfectly, but the coffee shop or new boutique you want to tag is missing from the list. This isn’t a bug—it’s by design.
A common misunderstanding is that Snapchat pulls location data live from a service like Google Maps. In reality, Snapchat’s location stickers are tied to data from its mapping partner, Mapbox, which gets its information from community-driven sources like Foursquare and OpenStreetMap. If a business or landmark doesn’t exist in those third-party systems, it will never appear as a sticker option, no matter how accurate your phone’s GPS is.
This is the core reason you can’t just type in a custom address. To get a place officially recognized, you have to add it to the source. Before we get to that solution, it’s crucial to understand the different location tools Snapchat offers.
Confusing these three features is a common headache. They all use your location but serve completely different purposes.
If you want to get a new location, like your friend’s pop-up shop or your own small business, to appear as a sticker option, you need to add it to the databases that Snapchat relies on. This is the official, long-term fix.
While it’s not instant, it’s the only permanent way to solve the problem. The most effective place to start is Foursquare, a primary source for location data used by Mapbox and, by extension, Snapchat.
This method requires patience, but it ensures your location becomes a permanent, selectable option for everyone on the platform.
Learn More:How to Stop Sharing Location Without Notifying on iMessage >
Sometimes the issue isn’t a missing place, but a technical problem preventing the feature from working. If the location sticker is grayed out, missing, or the list is empty, work through this checklist.
This is the number one cause. Snapchat cannot see where you are if you haven’t given it permission.
Snapchat needs a stable GPS signal to find you. If you’re deep inside a building or in an area with a poor cellular or Wi-Fi signal, it may fail to load nearby places.
Sometimes, the app just needs a refresh. A minor bug can prevent features from loading correctly.
Learn More:How to Hide & Manage Your Location on Snapchat: The Complete Guide >
After trying the official methods, you might still need a way to tag a very specific or remote location for creative purposes, or perhaps you want to post about a trip after you’ve already left. For these scenarios, the only way to add a custom location on Snapchat is by using a third-party GPS modification tool.
A reliable desktop application like Fonelora Location Changer allows you to temporarily set your phone’s GPS coordinates to any point on the globe. This is a powerful tool for content creators, but it’s important to be transparent about how it works.
Note on Setup: These tools require a computer and are more involved than simply downloading a mobile app. On Android, you will typically need to enable “Developer Options” in your phone’s settings. On iPhone, the process is generally simpler but managed through the desktop software.
Here’s the basic process:
After taking a Snap, tap the Sticker icon on the right toolbar. Select “Location,” then choose a nearby place from the list that appears.
You can find it inside the main Snapchat stickers menu. After taking a Snap, tap the third icon from the top on the right-hand toolbar (the folded square) to open the menu, where you’ll see the “Location” option.
Yes, absolutely. Snapchat requires access to your phone’s GPS data to suggest nearby places for the location sticker. You must enable it in your phone’s privacy or app permission settings.
Not directly within the app. For a permanent solution, you must add the new location to a third-party database like Foursquare and wait for it to be added to Snapchat’s system. For an immediate but temporary workaround, you can use a desktop GPS tool like Fonelora to set your phone’s location to that spot. If you are experiencing other GPS-related issues, you might want to explore further troubleshooting steps.
The GPS accuracy depends on your phone’s signal. However, the available options for tagging are limited to what exists in Snapchat’s database, which may not include every single business or landmark around you.
You cannot create a standard location sticker yourself. However, you can design and submit your own geofilter—a graphic overlay—for a specific area through Snapchat’s website. This is a paid service perfect for events, weddings, and business promotions.
The Fonelora team provides regular software updates to ensure compatibility with the latest iOS and Android versions, along with dedicated customer support to address any user questions.
Being unable to tag the right location on Snapchat is a common roadblock, but it’s one you can now solve. For daily sharing, the built-in sticker is fast and easy. When it falls short, you no longer have to feel stuck.
You now have the expert knowledge to get a new business officially listed by adding it to the right databases. And for those moments when you need a creative or private solution, a tool like Fonelora Location Changer offers a powerful and immediate workaround. You are now equipped with a complete toolkit to manage your location tagging on social media, ensuring your Snaps always show up exactly where you want them to.
