Want to change or hide your location on Snapchat? Learn how to use Ghost Mode, manage custom friend lists, and stop Live Location sharing safely. Verified steps for iOS 19 and Android 16.
You may want to see what your friends are doing on Snap Map, but the idea of broadcasting your exact coordinates to every contact can be unsettling. Perhaps you’ve tried to “changer ville sur Snapchat” (change city) for fun, only to find the app doesn’t natively allow it.
The reality is simple: While you cannot “fake” your location without risking an account ban, you can take total control over who sees your movement. This guide breaks down the technical procedures for hiding your whereabouts, managing specific friend lists, and fixing inaccurate map pins.
When your primary goal is complete privacy, the most effective and secure tool is Snapchat’s built-in Ghost Mode. This feature is the official solution to hide your location from everyone on your friends list.
Many users search for external tools to appear offline, but the safest procedure is always the one provided within the app itself. For those looking to go a step further in protecting their digital footprint, using a dedicated iOS privacy manager can help clear location caches and sensitive data traces.
Enabling Ghost Mode is straightforward. Once active, you can still see the locations of friends who are sharing theirs with you, but they won’t be able to see you.
When you enable Ghost Mode, your Bitmoji vanishes completely from the Snap Map. It does not show your last known location; you are simply invisible. Consider telling close friends before you disappear so they don’t think you’ve unfriended them.
Once enabled, Snapchat prompts you to select a duration: 3 Hours, 24 Hours, or Until Turned Off. This flexibility allows you to go offline for a short meeting or stay hidden indefinitely, giving you complete control over your Snapchat friends location visibility.
Going completely invisible isn’t always the ideal solution. You might want to share your location with a close circle of friends while hiding it from others. This is where Snapchat’s granular sharing controls become incredibly useful for managing different friend groups.
Instead of enabling Ghost Mode, you can create custom visibility lists directly within your Snap Map settings.
If you add a new friend later, you must remember to manually add them to this exclusion list if you want to hide your location from them.
To access these settings, follow the same initial steps: navigate to your Profile > Settings > See My Location. Below the Ghost Mode toggle, you will see these options. Simply select the one that fits your needs and pick the friends from your list.
One of the biggest sources of confusion is the difference between your general location on Snap Map and the temporary Live Location you can share with an individual friend. They are two separate features.
If you are actively sharing your live location with a friend, enabling Ghost Mode will not stop it. You must stop it manually from your chat with that person.
Choosing the right location sharing setting depends entirely on your situation. To eliminate any confusion, here is a clear comparison of the legitimate options available within the app.
| Feature | Ghost Mode | My Friends, Except… | Only These Friends… | Live Location Sharing |
| Privacy Level | Maximum. You are completely invisible to everyone on the Snap Map. | High. Visible to most friends but you can exclude specific people. | Very High. Invisible by default, visible only to a hand-picked group. | Lowest. A specific friend can see you move in real-time. |
| What Friends See | Your Bitmoji is removed from the map. | Your static Bitmoji is visible on the map. | Your static Bitmoji is visible on the map. | Your Bitmoji moves in real-time on their map. |
| Flexibility | High. Set for 3 hours, 24 hours, or indefinitely. | Moderate. Requires manual updates when you add new friends. | High. The trusted list is usually stable and requires few updates. | High. Can be set for 15 min, 1 hour, or 8 hours. Must be stopped manually. |
| Best Use Case | When you want total privacy or a break from social location sharing. | Hiding from a small number of people (e.g., a boss or family member). | Sharing your location exclusively with a partner or best friends for coordination. | Meeting up with a friend in a crowded place or letting someone know you’re on your way. |
If friends report that your Snapchat Map location is wrong… the issue often lies in your phone’s system settings. If standard toggles don’t work, you might be facing a deeper system glitch that requires an iOS system repair solution to recalibrate your GPS modules.
This happens when your Actionmoji appears at a location you left hours ago. The solution is ensuring Snapchat has the correct permissions from your device.
The most common cause on an iPhone is the ‘Precise Location’ setting. When this is disabled, your phone only gives apps an approximate location to protect privacy, which can cause your Actionmoji to appear miles away.
For Android users, similar settings control location accuracy. The steps may vary slightly depending on your device (Samsung, Google Pixel, etc.), but the process is generally the same.
You will find many third-party apps claiming to “changer ville sur Snapchat.” Avoid these. Using unauthorized GPS spoofers violates Snapchat’s Terms of Service and carries severe risks:
If you want to hide your real location, the only safe and sanctioned answer is to use Ghost Mode. It achieves the goal of privacy without putting your account and personal data at risk.
As Snapchat and iOS update their privacy features, this guide will be refreshed to reflect the latest secure methods. We are committed to providing current, actionable advice to help you manage your digital footprint.
You now have the exact steps to go invisible with Ghost Mode, share your location with only your closest friends, stop a Live Location share, and fix an inaccurate map pin. Instead of feeling anxious about who can see your whereabouts or resorting to risky third-party apps, you can apply these secure methods in just a few taps. Take a moment to review your settings now and regain complete control over how you appear on the Snap Map.
If the methods above didn’t fix your “location not updating” issue, try our [location showing wrong] troubleshooting guide.
Here are concise answers to the most common questions about managing your location on Snapchat.
1. How do I change my location on Snap Map?
You cannot manually set your location to a different city. Snap Map reflects your device’s real-time GPS data. You can only control who sees that location by using Ghost Mode or custom friend lists in your Snap Map settings.
2. How is Live Location different from Snap Map?
Snap Map shows your general, static location to a group of friends whenever you open the app. Live Location is a separate feature that shares your real-time, moving location with just one person for a limited time from a chat window.
3. Can I set a custom location without friends knowing?
No. The only safe way to prevent friends from seeing your true location is to enable Ghost Mode, which makes you invisible. Using third-party GPS spoofing apps to appear in a fake location is a violation of Snapchat’s terms, is unsafe for your data, and can lead to your account being banned.
4. Why is Snapchat showing the wrong location?
An incorrect location is usually caused by your device’s settings. On an iPhone, ensure that ‘Precise Location’ is enabled for Snapchat in your iOS location services. On Android, confirm that ‘Google Location Accuracy’ is turned on in your phone’s main location settings.
5. How do I stop sharing my location temporarily?
For the Snap Map, enable Ghost Mode and select a temporary duration, such as ‘3 Hours’ or ’24 Hours’. If you are sharing your Live Location with a specific friend, you must stop it manually from the banner at the top of your chat with them.
6. Does changing my location settings affect my snaps or stories?
No. Your visibility settings for Snap Map and Live Location are separate from the content you create. You can still use location-based filters and post snaps regardless of whether you are in Ghost Mode.
Managing your digital footprint on Snapchat doesn’t require “hacks”—it requires mastering the app’s built-in mechanics. Whether you choose the total invisibility of Ghost Mode or the real-time utility of Live Location, the power is in your settings.
If your GPS modules continue to struggle with accuracy even after following these steps, you may be facing a deeper OS glitch. A professional iOS system repair tool can often recalibrate these hardware-software links to restore functionality. Review your settings today and ensure you’re only sharing what you intend to.
