Your Ultimate Hundo Pokémon GO Guide
Wondering what a hundo Pokémon GO is? This guide shows how to find 100% IVs with a 2-step method and increase your hundo odds from 1/4096 to 1/64.
Author Avatar Joy Taylor Last Updated: May. 07, 2026
You’ve just finished a raid, and someone in your group exclaims, “Yes, a hundo!” A moment of confusion hits, quickly followed by a nagging worry: have you been unknowingly transferring these “hundo” Pokémon all along? This frustration is common. The game doesn’t explicitly explain this critical aspect, leaving many trainers uncertain about the true potential of their catches. This guide is designed to eliminate that doubt. Here, we will provide a clear, step-by-step method to understand what is a hundo in Pokémon GO, how to identify one with 100% certainty, and the expert strategies to find them more efficiently. You’ll learn to distinguish a valuable perfect Pokémon from one that just has high CP, so you never have to worry about missing out again.
The appraisal methods and probability data presented here have been rigorously tested across hundreds of Pokémon encounters on both iOS and Android to confirm their reliability.
How to Check for a Hundo: The 2-Step Method
Before you can hunt for new hundos, let’s address that nagging fear: do you already have some without realizing it? This two-step process will first help you find every perfect Pokémon in your storage instantly, then show you how to check new catches on the fly.
Learn More:The Truth About Pokémon GO Rare Candy Cheats >
Step 1: Instantly Find Every Hundo You Already Own
The single most efficient way to check your entire collection is with a simple search filter. This is the first thing you should do if you’re worried about having overlooked a perfect Pokémon.
  • Open your Pokémon Storage.
  • Tap the search bar at the top.
  • Type 4* into the bar.
The game will immediately filter your storage to show you only 100% IV Pokémon. If anything appears, congratulations! You’re a hundo owner. This simple command is a massive time-saver and the best way to audit your collection.
How to use the 4 search filter
Step 2: Appraise New Catches in Seconds
For checking Pokémon as you catch them, the built-in IV appraisal system is your definitive tool. Follow this simple procedure to check any Pokémon in seconds.
  1. Select a Pokémon: From your Pokémon Storage, tap the Pokémon you wish to inspect.
  2. Appraise It: Tap the menu icon (three horizontal lines) in the bottom-right corner and choose “Appraise” from the list.
  3. Look for Two Key Signs: Your team leader will show you a stat summary. A hundo will always have both of these indicators:
    • A 3-star rating with a red stamp.
    • All three stat bars (Attack, Defense, and HP) are completely full and colored pink/red.
If you see both the red stamp and three full bars, it’s a confirmed hundo. If even one pixel is missing from a bar or the stamp is orange instead of red, it is not a perfect 100% IV Pokémon.
Learn More:How to Increase Shiny Odds in Pokémon GO: The Real Strategy >
The Secret to Better Hundo Odds: Understanding IV Floors
Now that you can identify a hundo, how do you find more of them? The key is to stop relying on luck from random wild spawns and start targeting encounters with better odds. This is where a critical, often-overlooked mechanic comes into play: the IV floor.
An IV floor is the minimum possible IV a Pokémon can have from a specific encounter type. A typical wild Pokémon can have IVs from 0 to 15 in each stat, making the odds of a perfect 15/15/15 a staggering 1 in 4,096. However, other methods guarantee higher minimum stats, drastically improving your chances.
Here is a breakdown of your hundo probabilities based on the encounter method:
Encounter Method IV Floor (Attack/Defense/Stamina) Hundo Odds Why It Matters
Wild Spawn 0 / 0 / 0 1 in 4,096 The baseline. This is pure luck and highly inefficient for hundo hunting.
Weather Boosted Wild Spawn 4 / 4 / 4 1 in 1,728 A decent improvement, but still a long shot. Always check weather-boosted spawns.
Raid / Egg / Research 10 / 10 / 10 1 in 216 This is the most reliable and accessible way to farm for hundos. Your efforts are 19x more effective here.
Lucky Trade 12 / 12 / 12 1 in 64 The absolute best odds in the game. The Lucky Pokémon IV boost makes trading with friends incredibly valuable.
Pro-Tip: To maximize your efficiency, prioritize your daily raid passes, hatch eggs consistently, and complete your field research tasks. This strategic focus on the raid IV floor in Pokémon GO is the foundation of any successful hundo hunting plan.
Advanced Hundo Hunting Strategies
As a trainer serious about finding hundos, you have several ways to approach the hunt. Choosing the right technique depends on your goals, time, and playstyle.
The Community Method: Playing Locally and Collaboratively
This is the standard, risk-free Pokémon GO experience elevated with teamwork. Rather than just walking alone, you engage with your local community.
  • Pros: It’s the intended way to play, completely safe for your account, and promotes exercise and social interaction. By joining local groups, you can achieve far more than you could alone.
  • How it Works: The most effective “manual” hunters don’t wander aimlessly; they use community tools. Local Discord groups or Niantic’s Campfire app are essential. Players in these groups will often report 100% IV Pokémon they find in the wild. If you’re quick, you can go to that location and catch the same perfect Pokémon before it despawns. This turns a game of pure luck into a collaborative, targeted hunt.
  • Best For: Players who enjoy the social and exploration aspects of the game and want a rewarding, 100% legitimate way to find hundos more efficiently.
The High-Risk Alternative: Using GPS Location Tools
This method involves using third-party software to change your device’s GPS location. It’s important to state this clearly: using GPS spoofing tools is a direct violation of Niantic’s Terms of Service and can result in warnings, suspensions, or a permanent ban on your Pokémon GO account.
  • Pros: This method offers unmatched efficiency for players who accept the risks. You can access global Pokémon GO hotspots, participate in raids 24/7, and check thousands of Pokémon from home.
  • Cons: It carries a significant and real risk to your account’s safety. It also removes the physical exploration and community aspects that are core to the game’s design. This path should only be considered by those who have weighed the consequences and decided the potential rewards outweigh the risk of losing their account.
Learn More:iTools Dongle Pokémon Go: The Complete User Guide >
A Tool for Global Access: Fonelora Location Changer
For trainers who have considered the risks and decided to explore tool-assisted gameplay, Fonelora Location Changer is a professional software designed to grant access to any location, raid, or Pokémon nest in the world.
This software can transform hundo hunting into a targeted activity, but its use must be approached with caution. You can virtually position yourself in hotspots like Zaragoza, Spain, or Tokyo, Japan, to check thousands of spawns. To help manage the risks associated with this method, Fonelora includes safety-oriented features:
  • Cooldown Timer: A built-in clock advises you on safe waiting periods after teleporting. Adhering to this is crucial to avoid triggering in-game flags that detect unnatural movement.
  • Realistic Movement: Simulate natural walking, cycling, or driving speeds along custom routes to mimic authentic gameplay when hatching eggs or traveling between hotspots.
Getting started is a simple, three-step procedure:
1.Connect Your Device: Launch Fonelora Location Changer on your PC or Mac and connect your iPhone or Android phone.
Connect Your Device
Connect Your Device
Choose Your Destination: Select Teleport Mode and enter the coordinates of a known hundo nest or a popular raid location.
Move & Hunt: Click “Move” to change your in-game GPS location. Always respect the cooldown timer before interacting with the game after a long-distance jump.
Click "Move"
Click “Move”
To ensure long-term usability, Fonelora Location Changer receives regular updates to maintain compatibility with the latest versions of Pokémon GO and operating systems, backed by a dedicated customer support team.
Hundo vs. Shiny vs. PvP IVs: A Guide to Smart Pokémon Prioritization
A common point of confusion for trainers is resource allocation. Should you power up a hundo, a shiny, or something else? The answer depends entirely on your goals, as each has a distinct purpose.
Priority When It’s the Best Choice Example
The Hundo (100% IVs) For PvE Raids & Master League PvP. A hundo has the highest possible stats when maxed out. In formats with no CP limit, it is objectively the strongest version of that Pokémon. A 15/15/15 IV Groudon is the ultimate choice for Master League and as a Ground-type raid attacker.
The PvP IV Pokémon For Great & Ultra League PvP. In CP-capped leagues, the ideal IV spread is usually low Attack and high Defense/HP. Because the Attack stat contributes more to the CP formula, a low Attack IV allows a Pokémon to be powered up to a higher level while staying under the cap, giving it more bulk and a winning edge. A 0/15/14 IV Lanturn is a top-tier choice for Great League, far outperforming a 15/15/15 hundo Lanturn.
The Shiny Pokémon For Collectors. A shiny is a rare cosmetic variant with no inherent stat advantage. Its value is in its rarity and visual appeal. It’s a trophy. A “shundo” (a shiny hundo) is one of the most coveted collector’s items in the game. A Shiny Charizard looks incredible, but its combat performance is determined by its IVs, not its color.
Your Hundo Hunt, Redefined
The feeling of uncertainty about whether you’ve missed a perfect Pokémon can take the fun out of the game. By using the 4* search filter, learning the simple appraisal check, and focusing on high-probability encounters like raids and lucky trades, you can hunt for hundos with confidence and strategy. Joining a local community can take your game to the next level, turning a solo grind into a team effort.
For those who choose to walk a different, high-risk path, tools like Fonelora Location Changer exist to break down geographical barriers, but this approach must be taken with a full understanding of the potential consequences. Stop letting pure luck dictate your success. Take command of your hundo hunt and turn frustrating searches into strategic victories.
What is a hundo in Pokémon GO?
A “hundo” is community slang for a Pokémon with 100% perfect Individual Values (IVs). This means it has a maximum score of 15 out of 15 for its three core stats: Attack, Defense, and Stamina (HP).
How do I know if my Pokémon is a hundo?
The fastest way is to type 4* into your Pokémon Storage search bar. For individual checks, use the “Appraise” feature. A hundo will display a 3-star rating with a red stamp, and all three stat bars will be completely full.
Are hundos rare in Pokémon GO?
Yes, they are very rare. The base odds for a wild Pokémon to be a hundo are 1 in 4,096. However, your odds improve dramatically with specific encounters. If you want to better manage your collection, you can learn more about how to manage your Pokémon storage.
Can I increase my chances of getting a hundo?
Absolutely. Focus on activities with a high IV floor. Your best chances are from Lucky Trades (1 in 64 odds), followed by Pokémon hatched from eggs, caught in raids, or received from Field Research rewards (all 1 in 216 odds).
Do hundos matter for PvP battles?
They are essential for the Master League, which has no CP cap. For the CP-capped Great and Ultra Leagues, however, Pokémon with low Attack and high Defense/HP IVs are generally superior because of how the CP formula works.
What is the difference between a hundo and a shiny Pokémon?
A hundo has perfect stats for optimal combat performance. A shiny Pokémon has a rare, alternative color scheme but provides no statistical advantage. Its value is purely for collectors. A “shundo” (shiny hundo) is one of the rarest and most prized catches in the game.
Should I power up every hundo I find?
No. Stardust is a valuable resource. Only invest in hundos that are meta-relevant for raids or Master League PvP, such as Mewtwo, Rayquaza, or Groudon. A perfect Pidgey is a great trophy, but not worth the investment. Having the right team is key.
