Quick Answer: The most popular Pokémon Fire Red cheats (like the Rare Candy and Master Ball codes) are GameShark/CodeBreaker codes designed for GBA emulators. However, entering these codes directly is the #1 reason emulators crash. You must enter and activate the Master Code first before any other cheat will work.
If you are replaying this classic GBA title on a modern mobile emulator, you probably want to skip the grind and get straight to the fun. We have the exact codes you are looking for below.
But before you copy and paste anything, there is a critical step that most cheat directories ignore. Without it, you are guaranteed to face immediate emulator crashes, white screens, or even corrupted save files. Let’s look at the mandatory Master Code and how to use it safely.
Before entering any item or Pokémon modifier cheat, you need to activate the Master Code. Think of it as a key that unlocks the game’s memory, allowing other GameShark or CodeBreaker codes to function without panicking the emulator.
Pokémon FireRed Master Code:
(Enter this as a GameShark v3 / Action Replay code and leave it enabled while using other cheats.)
Warning: The ‘Bad Egg’ Glitch
When using cheats, many players encounter a corrupted Pokémon known as a ‘Bad Egg.’ This happens when the game’s data becomes scrambled, usually from using too many codes at once or relying entirely on emulator ‘Save States’ rather than the game’s built-in saving system.
To protect your progress, always make a native in-game save (using the Start menu) before activating any new cheat. If a code causes a glitch, you can simply reset the game and reload your native save.
Below are the most requested GameShark codes for Pokémon FireRed. To keep your game stable, only activate one or two codes at a time, and remember to turn them off when you are done using them.
| Cheat Name | Cheat Code | Notes |
| Unlimited Rare Candies | 82025840 0044 |
Go to any PC. Withdraw the first item in your PC, which will now be an infinite stack of Rare Candies. |
| Unlimited Master Balls | 82025840 0001 |
Works the same as the Rare Candy cheat. Withdraw from the first slot of your PC. |
| Walk Through Walls | 509197D3 542975F478DA95DF 44018CB4 |
Enter both lines. Allows you to walk over water, trees, and buildings. Turn off before entering doors to avoid soft-locking. |
| Infinite Money | 82025838 104E8202583A 000F |
Maxes out your PokéDollars immediately. |
For mobile users, ensure you copy the spaces exactly as shown, or some emulators will reject the code format.
Most generic code lists don’t explain how to actually insert these cheats into modern mobile emulators. Here is exactly how to set them up on the two most popular apps.
How to use cheats on Delta Emulator (iOS):
How to use cheats on MyBoy Emulator (Android):
If you have entered the Master Code and your specific cheat code perfectly, but the game is still crashing or the cheat isn’t working, you are likely dealing with a version mismatch.
Symptom: Codes fail to activate, cause immediate white screens, or result in random game crashes.
Likely Cause (v1.0 vs v1.1): There are two main versions of the Pokémon FireRed ROM. Almost all of the popular GameShark codes found online were created for FireRed v1.0 (often called the “Squirrels” dump). If your emulator is running FireRed v1.1, the memory addresses are different, and v1.0 codes will crash your game.
How to Fix It:
In classic GBA games like FireRed, you use GameShark codes to skip the grind and walk through walls. But what about modern, location-based Pokémon games like Pokémon GO?
Modern AR games don’t use hex codes; they rely on physical GPS movement. For players who enjoy both retro and modern titles but want to bypass physical walking limits, the modern equivalent of a “cheat code” is a virtual location changer.
Fonelora Location Changer
Realistic GPS movement simulation, flexible route control, easy no-modification setup, and support for gaming, social, privacy, and location-based testing in one platform.
If you want to simulate movement or play from home on supported iOS and Android devices, you can change location in Pokémon GO using Fonelora Location Changer, which provides a guided desktop workflow to safely change your GPS location.
How to use Fonelora Location Changer for modern LBS games:
Fonelora Location Changer is for modern GPS-based apps and cannot be used to modify classic GBA ROMs like FireRed. Always check game rules and use virtual movement responsibly.
Using cheats in Pokémon FireRed is a fun way to experience a classic game without the tedious grinding, provided you take a few basic precautions. Always remember to enter the Master Code first, verify you are playing on a v1.0 ROM, and make native in-game saves to protect yourself from the dreaded Bad Egg glitch.
Gaming has evolved significantly since the Game Boy Advance era. If you are a fan of classic exploration but also play modern, location-based titles, you don’t have to be limited by physical travel. Whether you are walking through walls in Kanto or virtually exploring the globe with modern AR tools, the right setup puts you entirely in control of your adventure.
More Related Articles
