Joy Taylor
Joy Taylor | Last Updated: Jul. 21, 2026
Quick Answer: Dialga’s unique Dragon and Steel typing completely neutralizes traditional Dragon-type weaknesses like Fairy and Ice. To defeat Dialga in Pokemon GO, it is weak ONLY to Ground and Fighting-type attacks.
The top overall counters to prioritize for your raid team are:
Focusing exclusively on STAB (Same Type Attack Bonus) Ground and Fighting moves is the only way to effectively take down this legendary raid boss.
Comprehensive Dialga Raid Guide: Counters, CP, and IVs
Building the ultimate team to beat Dialga requires knowing which Mega Evolutions, Shadow Pokemon, and Standard Pokemon yield the highest DPS (Damage Per Second). Because Dialga resists 10 different attack types, bringing the right counters is critical.
Top Dialga Raid Counters Comparison
Category Best Pokemon Optimal Fast Move Optimal Charged Move Type
Mega Evolution Primal Groudon Mud Shot Precipice Blades Ground/Fire
Mega Evolution Mega Garchomp Mud Shot Earth Power Dragon/Ground
Mega Evolution Mega Blaziken Counter Focus Blast Fire/Fighting
Shadow Shadow Machamp Counter Dynamic Punch Fighting
Shadow Shadow Excadrill Mud-Slap Scorching Sands Ground/Steel
Standard Terrakion Double Kick Sacred Sword Rock/Fighting
Standard Lucario Counter Aura Sphere Fighting/Steel
Standard Conkeldurr Counter Dynamic Punch Fighting
Pro Tip: Pay attention to the in-game weather to maximize your gameplay value! Sunny weather boosts Ground-type attacks, making Primal Groudon and Mega Garchomp even more devastating. Meanwhile, Cloudy weather boosts Fighting-type attacks, giving your Shadow Machamp, Terrakion, and Lucario a massive damage increase.
100% IV CP Chart for Dialga
When you reach the catch screen, knowing the perfect CP numbers will tell you instantly if you have encountered a 100% IV (perfect) Dialga.
Ideal Raid Party Size
Dialga is a massive defensive tank. You generally cannot solo a Dialga raid. To comfortably win within the time limit, you will need a lobby of 3 to 5 high-level trainers (Level 40+) utilizing optimal Ground and Fighting counters. If relying on lower-level players or less optimal teams, aim for 6 to 8 trainers.
The Real Challenge: Raid Scarcity and Remote Pass Limits
Having a maxed-out Primal Groudon or a perfect team of Shadow Machamps is satisfying, but it does not solve the most frustrating part of Pokemon GO: local raid scarcity.
For many trainers, especially those in rural areas or smaller towns, finding an active Dialga raid during limited-time events is a massive struggle. Even if you manage to find an egg hatching locally, coordinating enough players in person to defeat the boss is incredibly difficult.
The official workaround provided by Niantic is the Remote Raid Pass. However, this method comes with strict limitations. Remote Raid Passes are expensive to buy constantly, and the game enforces a strict daily limit on how many remote raids you can join. If you are grinding for a Shiny Dialga or hunting that elusive 100% IV, relying strictly on your immediate physical location or expensive remote passes will quickly burn out your resources and your chances.
How to Farm Global Raid Hours and Weather-Boosted Dialga
Because 100% IV and Shiny encounters are purely a numbers game, advanced players often farm international Raid Hours to maximize their attempts without blowing their budget on Remote Raid limits.
The Global Raid Hour Strategy:
Imagine it is Wednesday afternoon where you live, and your local Raid Hour hasn’t started. By virtually traveling across time zones, you can participate in New Zealand’s Raid Hour hours before yours begins, and then jump to Hawaii’s Raid Hour much later. This effectively extends a single, one-hour event into a multi-day farming opportunity.
The Weather-Boost Advantage:
Location flexibility also allows you to hunt in some of the best Pokémon GO locations currently experiencing Snowy or Windy weather. Catching a weather-boosted Dialga at Level 25 instead of Level 20 saves you significant amounts of Candy and Stardust when powering it up.
By accessing global raids virtually, you participate “in-person” using your standard Premium Battle Passes or daily free passes, rather than being capped by Niantic’s Remote Raid Pass limitations. But to do this, you need a way to change your device’s location securely.
Using Fonelora Location Changer for International Raids
If you are struggling with a lack of local raids or the high cost of Remote Raid Passes, a desktop-guided virtual location tool can help you safely access global events. Fonelora Location Changer allows players on supported iOS and Android devices to change location in Pokémon GO, making it possible to join international Raid Hours.
Here is how to safely jump to global raids using Fonelora’s Game Mode:
  • Connect Your Device: Open Fonelora Location Changer on your computer (PC or Mac) and connect your supported iPhone or Android device via USB or Wi-Fi.
Connect Your Device
Connect Your Device
  • Select Game Mode: Choose the game-oriented setup to ensure your movement is optimized for LBS game environments.
  • Use Teleport Mode: Enter the coordinates or city of an active global Raid Hour (such as Tokyo or New York) and click to change your location.
Select Teleport Mode
  • Check the Cooldown Timer: Once you teleport long distances, Fonelora’s built-in Cooldown Timer will display a suggested waiting time. Wait for this timer to reach zero before spinning PokeStops or interacting with the raid.
  • Join the Raid: Once the cooldown is clear, use your Premium Battle Pass or daily free pass to enter the local raid lobby with other players.
Using a guided workflow on your desktop offers a more controlled and stable experience compared to risky manual spoofing apps, helping you hunt for weather-boosted Dialga anywhere in the world.
Important Safety Guidelines and Cooldown Rules
While accessing global raids is highly effective, using any location changer carries account risks, including soft bans or strikes (like Error 12), if game rules are ignored. Managing your virtual location responsibly is critical.
Before you start hunting Dialga globally, keep these strict safety checks in mind:
Frequently Asked Questions About Dialga Raids
Q1: What is Dialga weak against in Pokemon GO?
Because of its Dragon/Steel typing, Dialga is uniquely weak ONLY to Ground and Fighting-type attacks. Fairy and Ice-type moves will deal neutral damage.
Q2: What are the best Pokemon to use against Dialga?
The absolute best counters are Primal Groudon, Terrakion, Mega Garchomp, and Shadow Machamp equipped with optimal STAB moves.
Q3: Can you solo a Dialga raid?
No, Dialga is an incredibly bulky Tier 5 raid boss. Even with a perfect team of maxed-out counters, you will need a minimum of 3 to 5 high-level trainers to defeat it within the time limit.
Q4: What is the 100% IV CP for Dialga?
A 100% perfect IV Dialga will have 2307 CP at Level 20. If it is weather-boosted by Snowy or Windy conditions, the 100% perfect IV is 2884 CP at Level 25.
Q5: How do I get more Dialga raids if none are nearby?
If you lack local raids, you can use official Remote Raid Passes (up to the daily limit) or participate in international Raid Hours by using a location tool to access global timezones.
Q6: Is there a safe way to play in international Raid Hours?
While no method is 100% risk-free, using a desktop-guided tool with a dedicated Game Mode and strictly adhering to Cooldown Timer rules is the safest way to minimize account flags and soft bans.
Final Thoughts: Maximizing Your Dialga Raid Attempts
Defeating Dialga comes down to preparation: assemble your best Ground and Fighting-types, look out for Snowy or Windy weather boosts, and keep an eye on the 2307 CP and 2884 CP thresholds for that perfect 100% IV catch.
However, having a great team means nothing if you are starved for local raids. Rural players and those limited by the daily caps and high costs of Remote Raid Passes do not have to be locked out of grinding limited-time events.
By taking advantage of international Raid Hours, you can maximize your encounters using standard passes. If you need a reliable way to overcome timezone barriers, consider trying Fonelora Location Changer. By combining its dedicated Game Mode with strict adherence to cooldown rules, you can safely access global lobbies, coordinate with international players, and finally catch the perfect Dialga for your collection.
fonelora img
  • Bluetooth Hardware Simulation for Safer GPS Spoofing
  • Realistic Movement & Route Simulation
  • No Root or Jailbreak Required
  • All-in-One Solution for Games, Social Apps & Privacy
Change GPS Location Easily
Free Download Free Download
