Not sure how to evolve Charcadet in Pokémon GO? This guide breaks down the evolution steps, highlights a quick low-CP PvP workaround, and covers efficient solo strategies. It also helps you decide whether Armarouge is the right choice for your team.
Hatching a rare Charcadet from a 10km egg after weeks of walking is a thrilling moment—until you realize you have no idea how to actually evolve it. Trainers quickly face deep frustration when trying to complete the specific battle tasks required to unlock its evolutions.
I know this from personal experience: I accidentally wasted a bunch of time battling in the GO Battle League, wondering why my screen showed zero progress, before realizing Charcadet wasn’t set as my active buddy. Evolving Charcadet in Pokémon GO completely differs from standard Candy-only evolutions, and the game does a poor job of explaining the rules.
Instead of a simple button press, you are met with vague requirements for evolving Charcadet into its two alternate forms. If you are struggling with scattered forum posts or outdated information, this tested guide is for you. We will break down exactly how to evolve Charcadet, reveal legitimate solo methods and clever PvP bypasses to skip the grind, and resolve your uncertainty about which evolution (Armarouge vs Ceruledge) is a better investment for your roster.
To understand how to evolve Charcadet in Pokémon GO, you must correctly interact with the game’s buddy system. Unlike standard evolutions, this procedure involves specific Charcadet Candy and battle requirements that must be tracked through a slightly hidden user interface.
Follow these sequential instructions to ensure your progress actually registers:
1.Set Your Active Buddy: Open your trainer profile in the bottom left corner, tap your current buddy, and swap it to Charcadet. It must be assigned as your active buddy for battles to count.
2.Accumulate Candy (The Map Rule): You must collect exactly 50 Charcadet Candies. You can gather these by hatching more eggs, using Rare Candies, or walking. Crucial Distinction: Charcadet must be fed berries and visibly walking on the map with you to earn the 5km walking candy. However, it does not need to be fed or on the map for your battle victories to count.
3.Choose Your Evolution Route: The system branches based on the specific types of Pokémon you defeat while Charcadet remains your active buddy.
4.Track Your Progress: Tap the tiny drop-down arrow directly under the standard “Evolve” button on Charcadet’s summary page. This drops down a specific 0/30 visual progress bar so you can track your battle wins.
5.Execute the Evolution: Once the specific battle counter reaches 30 and you possess the required 50 candies, the evolution button will highlight red. Tap it to complete the sequence.
Here is a critical tip that most other resources miss, and it will save you hours of walking around your neighborhood: Charcadet does not actually need to participate in the battles to gain progress.
The game logic only checks if Charcadet is currently your active buddy when a qualifying opponent is defeated. Any strong Pokémon in your current battle party can do the actual fighting.
PRO-TIP: The 10-CP PvP Bypass
Instead of searching the wild map for rare spawns, you can battle a friend in player-versus-player (PvP) combat to complete the requirements in minutes.
1.Set Charcadet as your active buddy.
2.Ask a friend to build a PvP team of three 10 CP Ghost-type or Psychic-type Pokémon.
3.Send them a battle invite in the Great League format.
4.Use your highest-level Pokémon to instantly one-shot their 10 CP team in seconds.
5.Rematch ten times. Defeating 3 Pokémon per match quickly equals your 30 total required defeats.
This specific PvP trick is an entirely legitimate, built-in mechanic and offers the perfect resolution to the initial hurdle of finding 30 correct typings.
What if you don’t have a friend online to PvP with? Relying on random wild spawns to find 30 specific Ghost or Psychic types locally can take weeks, especially depending on your geographic location and local weather patterns.
Fortunately, there are highly efficient, entirely legitimate solo methods to farm these specific typings in-game:
Team GO Rocket balloons and PokéStops are your best friends for this task. Grunts always use a specific typing based on their opening catchphrase. You can defeat their entire team of three, back out before the final catch screen, and immediately rematch them to farm defeats.
Keep an eye on the current raid rotation. If a Ghost-type (like Shuppet or Gengar) or a Psychic-type (like Ralts or Metagross) is currently a raid boss, you can enter the raid and battle. Remember, Charcadet just needs to be your buddy—use your strongest Dark or Bug types to clear the raids quickly.
While less predictable, the GBL is currently saturated with common Ghost and Psychic meta picks (such as Trevenant, Jellicent, Cresselia, and Medicham). As long as Charcadet is your buddy, every qualifying meta Pokémon you defeat in standard GBL matches counts toward your total.
Before you spend your 50 hard-earned candies, it is critical to evaluate which evolution is actually worth your investment. Resolving this uncertainty depends heavily on your primary gameplay focus: Player versus Environment (PvE) raids or Player versus Player (PvP) battle leagues.
Armarouge provides a sturdy, defensive option. In PvP, specifically the Ultra League, its dual typing and access to the Charged Attack ‘Psyshock’ allow it to apply consistent shield pressure against common fighting and poison-type opponents. However, its fast attacks generate energy relatively slowly. For PvE raids, it functions as a decent secondary Fire-type attacker but falls noticeably short of top-tier damage dealers like Reshiram or Darmanitan.
Ceruledge focuses heavily on high damage output. Its access to ‘Incinerate’ as a Fast Attack and ‘Shadow Ball’ makes it a highly threatening offensive option in the PvP Master League and Ultra League. In PvE, it serves as an excellent Ghost-type and Fire-type attacker, offering massive utility against frequent raid bosses like Metagross.
The Verdict: For the vast majority of players, Ceruledge is the superior choice. Its offensive typing and dual raid viability make it an immediate asset to your roster. Armarouge remains a valuable Pokédex entry, but requires a highly specific team composition to succeed in competitive formats.
For rural players who have absolutely no local spawns, no friends online, and no access to PokéStops for Rocket Grunts, finding 30 specific typed Pokémon locally is a massive obstacle. In these rare cases, some players turn to professional software tools like Fonelora Location Changer to instantly change their GPS coordinates to known global Ghost or Psychic-type nests.
If you understand the severe risks and still choose to use a paid location tool like Fonelora to bypass local spawning limitations, the procedure is straightforward:
1.Connect Your Device: Launch Fonelora Location Changer on a computer and connect your smartphone.
2.Select a Location: Enter the specific GPS coordinates of a verified global nest.
3.Execute the Method: Click “Move.” Your in-game location updates, allowing you to instantly encounter the required typings.
Again, while this saves immense time, it carries a heavy baseline risk of losing your Pokémon GO account entirely. Stick to the legitimate PvP friend trick or Rocket Grunt farming whenever possible.
What do I need to evolve Charcadet into Armarouge in Pokémon GO?
You need exactly 50 Charcadet Candies and must defeat 30 Psychic-type Pokémon while Charcadet is set as your active buddy.
How do I evolve Charcadet into Ceruledge instead?
The requirement is the exact same 50 Candies, but you must defeat 30 Ghost-type Pokémon instead of Psychic-types while Charcadet is your active buddy.
Does Charcadet have to be walking on the map with me to evolve?
No. Charcadet only needs to be assigned as your active buddy for battles to count. However, it does need to be fed and walking on the map if you want to earn the 5km walking candy.
Do I have to use Charcadet in battle for the buddy task?
No. Charcadet can remain completely outside of your battle party. Any other strong Pokémon in your roster can execute the attacks and defeat the required opponents.
Which evolution should I choose?
Ceruledge generally provides better offensive performance in both raid battles and PvP formats due to its high-damage Ghost and Fire moveset, making it the more universally useful investment.
Evolving Charcadet doesn’t have to be a multi-week grind shrouded in mystery. By understanding the distinct UI quirks—like checking the drop-down menu for your progress bar—and knowing that Charcadet doesn’t actually need to participate in the battles, you are already steps ahead of the average player.
Whether you choose to call up a friend for the rapid 10-CP PvP bypass, or you take the solo route of farming Team GO Rocket Grunts, you now have actionable, legitimate strategies to secure your Ceruledge or Armarouge today. Choose your evolution wisely, keep an eye on your buddy status, and enjoy adding one of the strongest new Fire-types to your battle roster.
