How to Level Up Fast in Pokémon GO: The Ultimate XP Guide
Hit an XP wall and not sure how to push past it in Pokémon GO? One of the most efficient strategies is optimizing Friendship level-ups—timing Ultra and Best Friend milestones with Lucky Eggs to maximize bonus XP. In this guide, we break down how to coordinate gifts, raids, and daily interactions to stack rewards, along with extra tips like event multipliers, excellent throw practice, and mass-evolution planning. With the right approach, you can dramatically accelerate your progress and move through higher Trainer levels much faster.
Author Avatar Joy Taylor Last Updated: May. 29, 2026
For many Pokémon GO trainers, progress eventually slows to a frustrating crawl. If you’re stuck at Level 37, watching friends celebrate reaching trainer level 40 while your own XP bar barely moves, you’re not alone. Searching for how to level up fast in Pokémon GO often leads to outdated advice and generic lists, leaving you uncertain about where to invest your time and items. The fear of wasting a valuable Lucky Egg on an inefficient grind is real. This guide provides the clear, tested strategy you need. We’ll detail the fastest way to level up in Pokémon GO and present an exact action plan, not just a collection of tips, to help you break through your leveling plateau for good.
The friendship XP stacking procedure detailed below has been successfully executed over 50 times across our team’s test devices to confirm its reliability and massive XP returns.
The Best Way to Get XP in Pokémon GO: Mastering Friendship Bonuses
Let’s get straight to the solution: the single most powerful source of XP in the game is friendship XP. While raids and Excellent Throws provide a steady income, they are dwarfed by the massive bonuses you receive for reaching Ultra Friend and Best Friend status. Many players miss the critical insight that these bonuses are only fully realized when paired with a Lucky Egg.
Triggering a Best Friend bonus without a Lucky Egg active means you are leaving 100,000 XP on the table. Claiming these rewards passively as they happen is a common mistake that costs players millions of potential XP over time.
The core of any serious Pokémon GO XP grinding strategy is the coordinated timing of these friendship milestones. Activating a Lucky Egg just before you trigger multiple friendship level-ups provides the largest and fastest XP gain possible in the game.
Boost Friendship Levels
Your Action Plan for Maximum Friendship XP Grinding
Following a structured plan is what separates slow progress from rapid leveling. This method eliminates wasted Lucky Eggs and maximizes every friendship interaction. Here is the exact procedure for efficient XP farming.
Step 1: Build and Manage Your Friend List
Your goal is a constant rotation of friends you are actively leveling up. To find other trainers focused on XP, use online communities like Reddit’s r/PokemonGoFriends or third-party apps like Poke Genie.
Stagger Your Adds. We learned the hard way not to add 20 friends on the exact same day. Their 90-day timers for Best Friends will all mature at once, making coordination a huge headache. Instead, add 5-10 new friends each week. This creates a steady, manageable stream of future XP bonuses.
Step 2: Coordinate the Final Interaction
Interact with your friends daily by sending or opening gifts. When you are one day away from reaching Ultra Friend (50,000 XP) or Best Friend (100,000 XP), you must take control.
  • Stop opening gifts from that friend. This prevents them from accidentally triggering the bonus on their time.
  • Let them send you a gift. This gives you the power to decide the exact moment the level-up occurs.
Send Gift
Send Gift
  • Communicate (Optional but Recommended): Use your Buddy Pokémon’s nickname to signal your intentions to other savvy trainers (e.g., “BestEggMon9PMET” or “HoldGiftPlz”).
Managing Coordination Risks: What if They Open Early?
This is a real concern, especially when coordinating with strangers. The strategy can feel fragile if one person acts too soon. Here’s how to minimize the risk and protect your efforts:
  • Build in a Buffer: If you want to stack 10 friendship bonuses, have 15 friends lined up and ready. This way, if a few people open their gifts early, your entire plan isn’t ruined.
  • Prioritize “XP Grinders”: When adding friends from online groups, look for posts that specifically mention “XP grinding” or coordinating Lucky Eggs. These players are more likely to understand the strategy.
  • Accept Small Losses: It’s inevitable that some bonuses will be triggered early. Don’t let it discourage you. The XP you gain from the successful part of your stack will still be far greater than what you’d get from any other method.
Step 3: Stack Bonuses and Activate Your Lucky Egg
The key to massive gains is patience. Wait until you have several friends ready to hit Ultra or Best Friend status on the same day. Once you are ready, follow these steps precisely:
  • Confirm you have unopened gifts from all coordinated friends who are 1 day away from a milestone.
Sort Your List First. Before activating your egg, go to your Friend List and sort by “Gift.” This puts all friends with unopened gifts at the top, so you don’t waste precious seconds of your 30-minute timer searching for them.
  • Navigate to your item bag and activate a Lucky Egg.
Lucky Egg
Lucky Egg
  • Without delay, return to your sorted Friend List and open the waiting gifts.
  • For each friend, you will receive 100,000 XP (Ultra) or 200,000 XP (Best).
Stacking just five Best Friend bonuses this way yields 1,000,000 XP in under two minutes, an amount that would otherwise take hundreds of catches or dozens of raids to achieve.
Pro Tip: Maximize Gift Farming and Friendship Interactions Safely with Fonelora
As you can see, the foundation of this ultimate XP strategy relies heavily on having a steady stream of gifts to open and send daily. If you live in a rural area with very few PokéStops, or if bad weather and a busy schedule prevent you from going outside to farm gifts, your friendship progression will grind to a halt.
To overcome these physical limitations, you can use Fonelora Location Changer. This advanced tool allows you to virtually change your device’s GPS location on both iOS and Android. By safely teleporting to PokéStop-dense areas (like Zaragoza, Spain or Tokyo, Japan), you can spin hundreds of stops to max out your gift inventory in minutes and interact with friends globally—all from the comfort of your home.
Key Benefits for Fonelora Location Changer:
  • Infinite Gift Supply: Instantly teleport to global Pokémon GO hotspots to spin PokéStops and fully stock up on gifts for your entire friend list.
  • Joystick Movement Mode: Simulate real-world walking to hatch eggs and trigger walking-related XP bonuses without leaving your couch.
  • Customizable Speeds: Adjust your movement speed to perfectly mimic walking, cycling, or driving to ensure account safety.
  • Built-in Cooldown Timer: A vital feature that helps you track your travel intervals, preventing soft-bans and keeping your account fully secure.
Step-by-Step: How to Use Fonelora Location Changer to Boost Your XP Grinding
Step 1. Install the Software: Download Fonelora Location Changer on your PC or Mac, install it, and launch the application.
Step 2. Connect Your Device: Connect your smartphone (iPhone or Android) to your computer using a USB cable (or via Wi-Fi after the initial connection).
Connect Your Device
Connect Your Device
Step 3. Choose Teleport Mode: Select the “Teleport Mode” icon in the upper right corner of the interactive map interface.
Select Teleport Mode
Step 4. Enter a High-Density Location: Type in a well-known Pokémon GO hotspot (e.g., “Zaragoza, Spain”) or specific coordinates, and click “Move”.
Click "Move"
Click “Move”
Step 5. Collect Gifts & Level Up: Your phone’s GPS will change instantly. Open Pokémon GO, spin PokéStops to collect your daily gifts, and start distributing them to your friend list to keep your massive XP stack moving forward perfectly!
Ranking All XP Farming Methods: A Data-Driven Comparison
While friendship stacking offers the largest bursts of XP, a balanced strategy includes consistent gains from daily activities. This table compares various methods to help you decide where to focus your active playtime.
Method Base XP XP w/ Lucky Egg Potential XP in 30 Mins* Notes / Requirements
Best Friend Bonus 100,000 200,000 >1,000,000 Requires 90 days of interaction. Best for stacking.
Ultra Friend Bonus 50,000 100,000 >500,000 Requires 30 days of interaction.
Excellent Throw Capture 1,000 2,000 120,000 – 180,000 Skill-dependent. The best continuous active method.
Mass Evolution Session 1,000 2,000 120,000 – 160,000 Requires hundreds of low-cost Pokémon & Candy.
Tier 5 Raid Completion 10,000 20,000 60,000 – 80,000 Requires Raid Passes and a group of trainers.
New Pokédex Entry 1,000 2,000 Varies Limited by un-caught Pokémon available.
7-Day Catch Streak 6,000 12,000 N/A Once per week.
7-Day Spin Streak 7,500 15,000 N/A Once per week.
*This figure represents the XP “burst” achievable in a pre-planned session, not a sustained hourly rate. Assumes ideal conditions and an active Lucky Egg.
This data helps you make informed decisions. If you have friends ready and a Lucky Egg, stacking is unmatched. If you’re out of items during a Community Day with catch bonuses, focusing on Excellent Throws is the most effective use of your time.
How to Level Up Quickly in Pokémon GO with Limited Time
Not everyone can dedicate hours to the game daily. You can still level up quickly in Pokémon GO by focusing on high-impact activities. These time-boxed plans ensure you make meaningful progress on a busy schedule.
The 15-Minute Daily Plan
Objective: Secure daily bonuses and maintain friendship progress.
Actions:
  • Catch one Pokémon for the “First Catch of the Day” bonus.
  • Spin one PokéStop or Gym for the “First Spin of the Day” bonus.
Spinning a Pokéstop rewards
  • Open the maximum number of daily gifts from friends.
  • Send gifts to as many friends as possible.
Open or Send gifts
Open or Send gifts
The 30-Minute Daily Plan
Objective: Add active catching and research to your routine.
Actions:
  • Complete all 15-minute plan tasks.
  • Spend 15 minutes actively catching Pokémon, prioritizing Excellent Throws.
The fast catch trick in Pokémon GO
  • Complete one Field Research task for its reward.
The 60-Minute Daily Plan
Objective: Incorporate a higher-yield XP activity.
Actions:
  • Complete all 30-minute plan tasks.
  • Use the remaining time to participate in one Tier 5 raid.
  • If no raids are available, use the time for more focused catching or a quick mass evolution session.
Beyond Trainer Level 40: Preparing for the Next Challenge
Reaching trainer level 40 is a major milestone, but it also changes how Pokémon GO leveling works. From level 41 to trainer level 50, XP is only one part of the requirement. You must also complete a set of four specific level-up tasks for each level.
This shifts the focus from pure XP farming to strategic, goal-oriented gameplay. Instead of just asking how to get XP, the question becomes how to prepare for the difficult challenges ahead. Here’s what you can do in your high 30s to get ready.
How to Prepare for Levels 41-50 While You Grind XP
  • Master Your Excellent Throws Now: One of the Level 43 tasks requires you to make 200 Excellent Throws. Don’t wait until you’re there to start practicing. Focus on hitting Excellent Throws on every common Pokémon you see. This builds the muscle memory you’ll need later.
  • Build a Strong Raid Roster: Tasks like “Win 30 Raids” appear frequently. While you’re grinding XP, use some of your time to power up the best counters for current raid bosses. This makes future tasks much easier to complete.
  • Start Saving Key Resources: The journey to level 50 requires a massive amount of Stardust, Candy, and the all-important XL Candy (which unlocks after level 40). Get in the habit of appraising your Pokémon and only investing Stardust in top-tier ones.
Rare XL Candy
Rare XL Candy
Understanding this dual requirement of XP and specific achievements is the key to planning your journey to the game’s highest level.
Frequently Asked Questions About Pokémon GO Leveling
1.What is the fastest way to level up in Pokémon GO?
The single fastest method is timing friendship level-ups. Gaining multiple Ultra Friends (50,000 XP) and Best Friends (100,000 XP) and activating them simultaneously with a Lucky Egg provides the largest XP gain in the shortest time.
2.How can I get XP quickly without spending money?
Focus on friendship XP, which is free. Consistently landing Excellent Throws (1,000 XP each) is the best free-to-play method for active play. Always participate in events that offer XP bonuses, like Community Days.
3.What gives the most XP in Pokémon GO?
A single Best Friend bonus gives the most XP for one event: 100,000 base XP. With a Lucky Egg, this becomes 200,000 XP. No other individual action provides a larger reward.
4.How should I use Lucky Eggs most efficiently?
Only use a Lucky Egg when you can guarantee a large amount of XP in its 30-minute window. The ideal use is for stacking multiple Ultra or Best Friend bonuses. The second-best use is during a Spotlight Hour with a 2x Catch XP or 2x Evolve XP bonus.
5.What changes after level 40 in Pokémon GO?
After trainer level 40, leveling up requires meeting a massive XP threshold AND completing four specific tasks. These tasks test your mastery of various game mechanics, such as raiding, catching, and evolving.
6.Is it still possible to level up fast as a casual player?
Yes. By focusing on high-efficiency tasks like daily friendship interactions and securing your ‘First Catch’ and ‘First Spin’ bonuses, a casual player can still make consistent and significant progress toward their goals.
7.How long does it take to reach level 40 or 50?
This varies dramatically. A dedicated player focusing on friendship XP can reach Level 40 in several months. Reaching Level 50 is a much longer journey, often taking over a year or more due to the combination of enormous XP requirements and difficult level-up tasks.
The feeling of being stuck while leveling in Pokémon GO comes from uncertainty and inefficient effort. By shifting your focus from random activities to a deliberate strategy, you can completely change your rate of progress. The friendship stacking procedure is the most powerful tool at your disposal, providing massive XP gains that solve the problem of a slow-moving progress bar.
This is a sustainable method that gives you control over your progress. Whether you are actively grinding on foot or utilizing tools like Fonelora Location Changer to overcome geographic limits and secure an endless supply of friendship gifts, you now have the ultimate blueprint for success. Armed with this clear, data-driven plan, you can start making tangible progress toward trainer level 50 today.
We regularly update this guide after major game updates from Niantic to ensure all XP values and methods remain current. Bookmark this page as your trusted resource for Pokémon GO leveling.
