PGSharp Update Guide: Safely Install the Latest Version
This guide explains how to fix “App Not Installed” errors on Android by performing a clean installation, preserving configurations, choosing correct versions, and updating safely to avoid crashes or data loss.
Author Avatar Joy Taylor Last Updated: Jun. 01, 2026
Are you tired of downloading a new update file right before a big in-game event, only to be met with an infuriating “App Not Installed” error? Facing a frozen screen, losing your carefully saved GPX routes, or having your custom joystick setup wiped clean can ruin your gaming experience.
pgsharp pokemon go
pgsharp Update
Many players experience this exact struggle. The fear of losing saved configurations and the sheer confusion over which specific version to download from the official website causes unnecessary anxiety. Through meticulous testing across multiple Android devices, I discovered that relying on a proper clean installation completely resolves these issues. This guide is designed to remove the guesswork, showing you exactly how to update safely and get right back to playing.
Never simply long-press and tap “Uninstall” on your phone’s home screen or update directly over your existing app without preparing your data first. If you uninstall without backing up your current settings natively within the app, your saved coordinates, custom joystick configurations, and imported GPX files will be permanently deleted. Always export your settings before taking any other action.
PGSharp Manual Update Steps: Backup and Clean Installation Procedure
When handling Android app updates, choosing the right procedure is critical for your data’s safety. Overwriting existing files by simply downloading the new version and clicking “install” is the leading cause of installation failure. Instead, a clean installation—removing the old app entirely before installing the new one—significantly reduces system conflicts.
Here is the exact step-by-step procedure to perform a safe, clean upgrade without losing your data .
1. Export Your Current Settings
Open your current, working application. Tap the star icon to open your overlay menu, navigate to “Settings,” and scroll to the very bottom of the list. Tap the “Export” button. Your device will prompt you to save a file named config.json. Save this file to a secure, easy-to-remember location on your device, such as your “Downloads” folder.
2. Perform a Clean Uninstall
Once you have confirmed that your config.json file is safely saved in your Downloads folder, go to your main Android system settings. Navigate to “Apps” or “App Management,” find the game, and tap “Uninstall.”
3. Download the Correct New File
Navigate to the official website to download the newest APK. (See the section below on how to choose the correct download link for your specific phone).
4. Install and Grant Crucial Permissions
Tap the downloaded APK file to begin the installation. You will likely need to allow your browser or file manager permission to “Install unknown apps.” Once the installation finishes, open the game. Stop here: Before doing anything else, your phone will ask for permission to access photos, media, and files. You must grant this storage permission, or the app will not be able to read the configuration file you saved earlier.
5. Import Your Configuration
Finally, tap the overlay menu, go back to Settings, scroll to the bottom, and tap “Import.” Navigate to your Downloads folder, select your config.json file, and restart the app. Your custom joystick setups, walking speeds, and saved routes will be perfectly restored.
The Biggest Hurdle: Explaining the Download Options
The number one reason users encounter the dreaded “App Not Installed” error is downloading the wrong architecture version for their specific device. When you visit the official website, you are presented with multiple download links. Understanding the difference between them is vital before you begin the update installation process .
  • The Main Download Button (ARM64): The prominent, large blue download button is the 64-bit (ARM64) version. This is the standard version designed for modern Android smartphones (typically devices manufactured from 2018 onwards). If you are using a newer Samsung Galaxy, Google Pixel, or OnePlus, this is the button you need.
  • The “Alternative Download” Link (ARMv7): Located beneath the main button, this smaller link is for 32-bit (ARMv7) systems. You should only use this link if you are playing on an older budget smartphone, an aging Android tablet, or specific desktop Android emulators that require 32-bit architecture.
If you have a 64-bit phone and download the 32-bit version, or vice versa, the Android package installer will reject the file outright. If your update keeps failing immediately upon opening the downloaded file, try downloading the other version.
Release Highlights: What’s New in the Latest Version?
Instead of forcing you to hunt down software patch notes yourself, let’s look at the core improvements introduced in the current updates. Before downloading any new file, it is important to understand what changes and bug fixes are being implemented to see if the upgrade is worth your time right now.
Recent Update Features & Fixes:
Enhanced Virtual Go Plus Stability: The latest patches have significantly reduced the disconnection rate of the virtual auto-catcher, especially when the app is running in the background on devices with strict battery optimization.
Android 14 Security Compliance: Newer versions feature updated coding to prevent the app from crashing on devices running the latest Android 14 security patch levels, which previously blocked specific overlay permissions.
Cooldown Timer Overlay Fixes: A known bug where the visual cooldown timer would occasionally freeze or calculate the wrong duration based on local time zones has been corrected.
Encounter UI Updates: Streamlined menus during encounters make accessing your inventory items faster, reducing lag on mid-range phones.
Checking device compatibility before updating helps prevent performance issues. If you are running an older device on Android 9, ensure you monitor your available RAM, as these newer UI features slightly increase memory consumption.
Quick Update Troubleshooting Fixes
Even with a perfect backup and the correct download link, Android systems can sometimes act up. If your installation fails, apply these specific troubleshooting techniques to resolve the most common errors .
1. Fix “App Not Installed” (Conflicting Old Files)
As mentioned earlier, selecting the wrong ARM version is the primary culprit here. However, if you have the correct version and still see this error, it means remnant files from your previous version are blocking the install. Restart your phone, clear your device’s cache, and ensure the old app is entirely removed from your App Management settings before trying again.
2. Resolve “Parsing Error” (Corrupted Downloads)
If you receive a “Parsing Error” notification, the Android package installer has detected that your downloaded APK is incomplete or corrupted. This usually happens if your Wi-Fi drops for a split second during the download. Delete the broken APK from your Downloads folder, clear your web browser’s cache, and re-download the file over a stable connection.
3. Manage Beta Version Instability
Developers frequently release beta versions for testing new tools. While early access is fun, beta versions are notoriously unstable. Waiting for stable releases can reduce the risk of encountering bugs. If a beta version causes your game to crash repeatedly, export your settings, uninstall the beta, and revert to the most recent stable public release.
Alternative PC Method: Fonelora Location Changer
While mastering the manual mobile update process is highly beneficial, some users simply prefer to avoid downloading APKs, managing device storage permissions, and dealing with phone-based updates entirely. If you are looking for a different approach and prefer managing your gameplay from a desktop environment, Fonelora Location Changer serves as a viable alternative.
Rather than installing third-party apps directly onto your Android device, Fonelora functions as a desktop-based GPS location changer for iOS and Android. You connect your smartphone to your Windows or Mac computer via USB or Wi-Fi, and the software handles your location data externally.
Benefits for Desktop Users:
No Mobile App Updates Needed: Because the software runs on your computer, you use the official, un-modified game app on your phone, eliminating the need to constantly download new APK versions.
Zero Root Required: It operates seamlessly without requiring complex root access or developer mode tweaking on your primary device.
Large Screen Controls: Offers GPX file importing, a customizable joystick, and realistic movement simulation directly from your desktop monitor.
For players who spend a lot of time at their desks or those who find mobile file management frustrating, using a dedicated desktop tool provides a stable, user-friendly environment.
How to Use Fonelora to Change GPS Location on Uber
Follow these simple steps to get started:
Step 1: Download and Install
Download Fonelora Location Changer from the official website and install it on your computer.
Step 2: Connect Your Device
Connect your iPhone or Android device using a USB cable.
  • On iOS: Tap “Trust This Computer” when prompted
  • On Android: Enable USB Debugging
Change Your GPS Location
Step 3: Choose a Location
Open the map interface in the software:
  • Enter a specific location (such as an airport or busy area)
  • Or select a point directly on the map
Change Location instantly
Frequently Asked Questions About Safely Updating
Managing a new version update often generates questions regarding data retention. Below are clear, concise answers to the most common queries.
Where is the safest place to download the latest update?
Always obtain the APK directly from the official developer website. Downloading from third-party APK mirrors significantly increases your risk of accidentally installing modified or malicious files.
Do I absolutely have to uninstall before updating?
Yes. While simply overwriting the app by installing the new APK over the old one sometimes works, it is the leading cause of crashes, corrupted GPX routes, and infinite loading screens. Taking the extra two minutes to do a clean uninstall prevents hours of troubleshooting later.
How do I fix lag or erratic behavior after a successful update?
If the app installs perfectly but runs poorly, navigate to your Android settings, select “Apps,” find the game, and clear the application cache. Restart your smartphone to refresh your system’s RAM.
Managing your app updates does not have to be a stressful chore that puts your carefully saved configurations at risk. By understanding the critical difference between the ARM64 and ARMv7 download links, taking the time to export your settings to a config.json file, and performing a clean uninstall, you completely remove the uncertainty of the process.
You no longer have to worry about frustrating installation errors or waking up to find your custom setups erased. Whether you choose to follow the manual mobile steps to maintain your on-the-go freedom, or opt for a desktop software solution like Fonelora to bypass phone installations entirely, you now have the exact knowledge required to protect your data. Take a moment to export your settings today, grab the correct download link for your device, and enjoy an uninterrupted, highly optimized gaming session.
