Most Pokémon GO players waste Stardust on the wrong Pokémon. A high CP number does not automatically mean a Pokémon is strong. Many beginners invest hundreds of thousands of Stardust into bad raid attackers or weak PvP builds before realizing that IVs, move sets, and league caps matter far more.
I made the same mistake when I maxed out an Aggron that looked powerful on paper but collapsed instantly in five-star raids.
After years of testing raid teams, PvP builds, IV spreads, and meta attackers across multiple Pokémon GO seasons, I discovered a much more efficient system for evaluating which Pokémon are actually worth upgrading.
In this guide, you will learn:
Table of ContentsHide
When tackling high-tier raids, using the correct attackers is the difference between comfortably clearing a boss and constantly running out of time. The Pokémon GO raid meta changes every season, but several elite attackers consistently dominate because of their raw DPS, typing, and move pools.
| Pokémon | Best Role | Why It Dominates |
| Shadow Mewtwo | Psychic Attacker | Highest raw DPS in the game |
| Mega Rayquaza | Dragon/Flying | Incredible damage plus Mega boost |
| Primal Groudon | Ground | Elite survivability and massive Ground damage |
| Primal Kyogre | Water | One of the strongest Water attackers ever released |
| Necrozma (Dusk Mane) | Steel | Extremely powerful against Fairy and Ice raid bosses |
These Pokémon are slightly more accessible but still dominate in most raid environments.
| Pokémon | Key Move | Main Strength |
| Metagross | Meteor Mash | Best Steel-type non-Mega attacker |
| Lucario | Aura Sphere | Elite Fighting-type DPS |
| Tyranitar (Shadow/Mega) | Brutal Swing | Excellent Dark-type raid option |
| Garchomp | Earth Power | Reliable Ground attacker |
| Reshiram | Fusion Flare | Extremely strong Fire damage |
Shadow Pokémon receive a 20% attack bonus, making many of them stronger than their regular versions in raids. This is why Shadow Mewtwo and Shadow Tyranitar remain top-tier choices even years after release.
However, Shadow Pokémon are more expensive to power up, so Stardust management becomes extremely important.
Find Better Raid Spawns Without Wasting Time
Building a stronger Pokémon GO team is not only about IVs and Stardust. Location also matters because rare spawns, raids, nests, and event Pokémon are not distributed equally in every area. Rural players often have fewer raid lobbies and fewer high-value catches nearby.
If you want to explore Pokémon GO locations more flexibly, Fonelora Location Changer can help you change GPS location on iPhone and Android without jailbreak or root. It supports teleport mode, route simulation, joystick movement, and adjustable speed, making it useful for exploring raid-heavy areas or testing different Pokémon GO routes.
Raids are only half the game. If you want to succeed in Go Battle League, your team needs a completely different strategy.
In PvP, bulk and energy efficiency are often more important than raw attack power.
| Pokémon | Why It’s Strong |
| Azumarill | Incredible bulk and resistances |
| Galarian Stunfisk | Elite typing and shield pressure |
| Medicham (XL) | Excellent Counter pressure |
| Lanturn | Flexible Electric/Water coverage |
| Skarmory | Strong defensive typing |
| Cresselia | Extremely bulky and versatile |
| Giratina (Altered) | Dominates neutral matchups |
| Talonflame | Massive closing power |
| Registeel | Incredible defensive stats |
| Poliwrath | Excellent anti-meta coverage |
One of the biggest beginner mistakes in Pokémon GO is assuming that CP determines strength. It does not. Two Pokémon with identical CP can perform completely differently depending on:
This is one of the most misunderstood mechanics in Pokémon GO. For raids and Master League, you usually want perfect IVs:
Because the Attack stat increases CP much faster than Defense or HP, having low Attack allows a Pokémon to reach a higher overall level before hitting the league CP cap. That means: more total stats, higher survivability, and better PvP performance. This is why many “perfect” Pokémon are actually bad for Great League.
Before transferring any Pokémon, you should evaluate four key things:
Use the in-game appraisal feature:
Ask:
The ideal IV spread changes depending on the role.
Many Pokémon are only strong with specific legacy or Community Day moves.
Examples:
Without these moves, their performance drops dramatically.
Avoid investing huge resources into Pokémon that are:
Stardust is the most valuable resource in the game. Most players waste it far too quickly.
Even average PvP performance provides massive Stardust payouts over time.
Always prioritize:
These Pokémon give significantly more Stardust per catch.
Activate Star Pieces during:
Weather boosts increase Stardust gains by 25%.
Always evolve first before investing Stardust. Otherwise, you may waste resources on weak move pools.
Many Pokémon become top-tier only after learning exclusive moves.
Examples:
Purifying often reduces raid effectiveness because Shadows lose their attack bonus.
High CP does not equal long-term value. Always check IVs first.
Elite TMs are extremely rare. Save them for meta-defining Pokémon only.
The appraisal system is the foundation of efficient team building. Here is the fastest evaluation process:
4* for perfect IVs3* for strong raid attackers0attack for PvP candidatesThis system prevents accidental Stardust waste and keeps your storage organized.
The biggest mistake Pokémon GO players make is assuming high CP automatically means high value. The best raid attackers and PvP Pokémon are determined by IV spreads, move sets, typings, league caps, and Stardust efficiency. Once you understand the difference between raid IVs and PvP IVs, you stop wasting resources and start building teams that actually win consistently.
Before transferring your next catch:
If your local area has limited raids, weak spawns, or very few active routes, improving your Pokémon GO experience may also require better location flexibility. For that, Fonelora Location Changer is worth considering. It lets you change GPS location on iPhone and Android, simulate custom routes, use joystick movement, and control walking speed without jailbreak or root.
Use Fonelora Location Changer as a support tool to explore more areas, then combine it with smart IV checking, move evaluation, and Stardust planning to build Pokémon that are actually worth keeping.
Hot Topics
