MagFone iPhone Unlocker Review & Its Alternative
This is the full review on MagFone iPhone Unlocker: what it is, how to use it and its best alternative. If you are interested, please start reading.
Author Avatar Joy Taylor Last Updated: Aug. 29, 2025
Want to unlock your iOS device and looking for an efficient solution? You are not alone! Many users encounter issues such as forgotten passwords, disabled devices, or being locked out due to Apple ID restrictions.
This guide will dive deep into a full review of MagFone iPhone Unlocker. We will cover its key features, pros, and cons. We will also explore the best alternative to MagFone iPhone Unlocker, ensuring you have the most reliable option for your needs. Let’s get started!
Part1. What is MagFone iPhone Unlocker?
Overview of MagFone iPhone Unlocker
MagFone iPhone Unlocker helps you unlock your iPhone or other iOS devices. It is useful if you have forgotten your password or if your device is disabled due to too many incorrect attempts. The software is simple to use.
It can help you bypass passcodes, Face ID, or Touch ID on your iPhone. You can also remove an Apple ID from your device without needing the password.
Key features of MagFone iPhone Unlocker
Some of the key features of MagFone iPhone Unlocker are:
  • Removing Screen Locks: This feature helps you unlock your iOS device if you forget your screen passcode. It includes all types of screen passcodes as well as Face ID and Touch ID.
  • Removing Apple IDs: It enables you to regain full control of your iDevice if logged out of an Apple ID without a password.
  • Bypassing MDM Restrictions: It removes the Mobile Device Management restrictions without needing the administration’s credentials.
  • Supporting all iOS Versions: It claims to be compatible with all iOS versions.
  • Bypass Screen Time Passcode: The tool helps you remove the Screen Time passcode on your iPhone or iPad.
Pros and Cons of MagFone iPhone Unlocker
Pros Cons
Supports multiple unlock scenarios. Doesn’t guarantee a 100% success rate.
Works with the newest iPhone and iOS updates. You could lose all your iPhone data if you don’t back it up before unlocking it.
Offers multiple functions for unlocking different issues Compared to other iPhone unlocker tools, it feels a bit slower.
Part2. How to Unlock iPhone Using MagFone iPhone Unlocker
Step 1: Go to the MagFone iPhone Unlocker website, download, and install the software on your computer.
Step 2: Once installed, open the MagFone iPhone Unlocker software on your PC. Click on the “Unlock iOS Screen” option.
Click on the Unlock iOS Screen Option
Step 3: On the next screen, click on the “Start” button.
Click on the Start Button
Step 4: Plug your iOS device into your system using a USB cable. Ensure your computer recognizes your phone. Then, follow the on-screen guide to put your iDevice into DFU mode or Recovery mode.
Follow the On-Screen Instructions
Step 5: After successfully entering the recovery mode, you will see your device details. Check the details and click on the “Download” button to download the correct firmware for your iPhone.
Click on the Download Button
Step 6: After the firmware is downloaded and verified, click on the “Unlock” button.
Click on the Unlock Button
Step 7: A pop-up will then appear on the screen. Click on “Yes” to continue.
Click on Yes
Click on Yes
Step 8: Once the unlock is done, your iPhone will reset. The screen password will be removed. Tap on the “Done” button.
Part 3. Alternative to MagFone iPhone Unlocker – iOS 26 Supported
If you are looking for an alternative to MagFone iPhone Unlocker, AnyUnlock is an excellent choice. It is fully compatible with iOS 26. It is designed to unlock any iPhone password instantly. You can remove the passcodes in just a few easy steps. Using AnyUnlock does not require any technical skills.
AnyUnlock – iPhone Password Unlocker
  •  Support unlocking various iOS screen locks such as digital password, Face ID, fingerprint recognition, PIN, pattern, etc.
  • This tool allows you to bypass MDM lock, remove Apple ID,  bypass Screen Time passcode, etc.
  • It works quite well on all iOS versions, including the latest iOS 26.
Let’s explore these simple steps:
Step 1: Download and install AnyUnlock.  Connect your device to the computer with a USB cable.
Step 2:  Then, on the homepage, click on the “Unlock Screen Passcode” function.
Choose Unlock Screen Mode
Step 3: Then, on the next screen, tap on the “Start Now” button.
Click on Start Now Button
Step 4: Download the iOS firmware package page. When the firmware is downloaded, click the Unlock Now option. Then AnyUnlock will unlock the screen passcode automatically.
Tap on Unlock Now to Remove Screen Passcode
Step 5: The process of removing the screen passcode will start. Don’t disconnect your iOS device until the process is done.
Step 6: The screen passcode will be successfully removed from your iDevice. Now click on the “Done” button.
Successfully Remove Screen Time Passcode via AnyUnlock
Part4. FAQs
Q1. Can MagFone remove iCloud Activation Lock?
MagFone claims to bypass iCloud Activation Lock. But its success rate may vary depending on your device and iOS version.
Q2. Does MagFone iPhone Unlocker Really Work?
While MagFone can unlock some iPhones, it is not always the most efficient method. For a more reliable solution, consider AnyUnlock as the best alternative for unlocking iOS devices.
Q3. Does MagFone support the latest iPhone models?
MagFone supports a wide range of iPhone models, including the latest ones. But the compatibility with the latest versions should be confirmed before use.
Part5. Conclusion
In conclusion, the MagFone iPhone Unlocker helps to unlock iOS devices. We have explored the step-by-step guide to use it. Moreover, we have discussed its key features, pros, and cons. It comes with a few limitations.
We recommend trying AnyUnlock as an alternative solution. It has broader compatibility and efficient unlocking capabilities. It is a trusted solution to regain access to your iOS device quickly and effortlessly.
