Combee Evolution in Pokémon GO: The Complete Guide
Struggling with Combee evolution in Pokémon GO? Learn the female-only rule that makes the evolve button appear. This guide shows how to find the right one.
Author Avatar Joy Taylor Last Updated: May. 07, 2026
It’s one of the most common frustrations in Pokémon GO: you’ve spent weeks catching Combee, used Pinap Berries to gather over 50 candy, and when you finally go to evolve it… the button is missing. You’re not alone in thinking your game is bugged or that you’ve wasted time and resources. We’ve been there, too.
The good news is that your game isn’t broken. The solution to the Combee evolution mystery is a specific, unchanging rule that the game itself doesn’t clearly explain. The missing ‘Evolve’ button is an intentional design choice rooted in Pokémon lore. This guide is here to end the confusion for good, explaining precisely why most Combee can’t evolve and how to guarantee you find one that can.
Common player issue
Common player issue
How to Evolve Combee into Vespiquen: The 2-Step Requirement
The entire process of evolving Combee boils down to meeting two absolute requirements. Once you know them, you’ll be able to instantly appraise any Combee you catch. Forget the guesswork; here is the exact checklist you need for a successful Combee evolution in Pokémon GO.
  1. Confirm Your Combee is Female (♀): This is the single most important rule. Only female Combee can evolve into Vespiquen. Male Combee can never evolve, no matter how much candy you have.
  2. Accumulate 50 Combee Candy: The second requirement is the standard evolution candy system in Pokémon GO. You must have 50 Combee Candies to power the evolution.
If both of these conditions are met, the ‘Evolve’ button will appear right where you expect it on the Pokémon’s summary screen, and you can finally add Vespiquen to your Pokédex. This gender-locked evolution is why you see the button for some Pokémon and not for others—the game’s interface only shows the evolution option when a Pokémon is eligible. Since males are ineligible by design, the button is permanently hidden for them.
Learn More:How to Get All Shiny Eevee Evolutions: The Definitive Pokémon GO Guide >
How to Instantly Identify a Female Combee
If you’re asking, “why my Combee won’t evolve,” it’s because you’ve encountered one of the game’s key gender-locked evolution mechanics. Luckily, there are two easy ways to check a Combee’s gender in seconds.
The Fastest Method: Check the Gender Symbol (♀/♂)
The quickest and most reliable way to identify a Combee’s gender is to look at the UI. On the Pokémon’s summary screen, look directly to the right of its name and CP. You will see either a female (♀) or a male (♂) symbol. If you see the ♀ symbol, your Combee can evolve. If you see the ♂ symbol, it cannot.
The In-Game Visual Cue: Look for the Red Mark
For a more thematic check, you can use the visual difference designed into the Pokémon itself. This is the secret clue that many trainers miss. Inspect the forehead of the lowest of the three faces that make up Combee’s body.
  • Female Combee: Has a distinct red/orange triangular mark on its forehead.
  • Male Combee: Has a plain, unmarked forehead.
Combee evolution gender difference
Once you know to look for the gender symbol or the small red mark, you can save yourself the frustration of investing resources into a Pokémon that has no evolution option available.
How to Find a Female Combee: The Patient Hunt vs. An Advanced Tool
Knowing the secret is one thing; finding an eligible female is the next major hurdle. The Combee spawn rate in Pokémon GO is heavily skewed, with only about 12.5% of all wild Combee being female. This makes completing this rare Pokémon evolution a true test of patience. There are two primary approaches to this hunt.
Learn More:The Truth About Pokémon GO Rare Candy Cheats >
Method 1: The Standard Hunt
This is the traditional and safest way to play. It involves physically exploring locations where Bug-type Pokémon appear more frequently, such as parks, nature reserves, and forests. To increase your chances:
  • Play in Rainy Weather: Rain boosts the spawn rate of all Bug-type Pokémon.
  • Watch for Events: In-game events like “Bug Out” dramatically increase your encounters.
  • Use Lures & Incense: These items increase the number of Pokémon that spawn directly around you, giving you more chances to find a female.
This method is 100% safe and within the game’s terms of service, but it can be time-consuming and relies heavily on luck.
Method 2: Using a Third-Party Location Tool (Advanced Method)
For trainers who find the 12.5% female Combee spawn rate to be a major roadblock, some turn to third-party software like Fonelora to explore different geographic areas from a computer. This allows a player to check known Combee nests and high-density spawn locations worldwide without leaving home.
Disclaimer: Using location spoofing software is a direct violation of Niantic’s Terms of Service. This method carries a significant risk, including potential warnings, suspensions, or a permanent ban on your Pokémon GO account. Proceed with caution and at your own risk.
To help you understand the trade-offs, here is a direct comparison:
Feature Standard Hunting Third-Party Tool (Fonelora)
Success Rate Luck-Dependent High (Targeted search)
Time Cost High Low
Effort Required High (Physical travel) Low (Clicks on a computer)
Risk None High (Potential account ban)
How a Location Changer Like Fonelora Works
A tool like Fonelora Location Changer works by giving you control over your device’s GPS signal, effectively changing your in-game location. Instead of being limited to your physical surroundings, you can use it to instantly “teleport” your character to community-verified Combee hotspots anywhere in the world. This can turn the hunt from a game of chance into a targeted search.
Tools like this often include features intended to reduce detection risk, such as cooldown timers to manage teleportation frequency. The general process is:
Step 1: Connect Your Device: Download and launch the software on your computer and connect your smartphone.
Connect Your Device
Connect Your Device
Step 2: Select a Destination: Use a Teleport Mode to search for a known Bug-type habitat or enter specific GPS coordinates.
Select Teleport Mode
Step 3: Move Instantly: Click to move. Your in-game avatar will appear at the new location.
Click "Move"
Click “Move”
Combee Evolution: Pokémon GO vs. Main Series Games
Trainers familiar with the main series games, such as Pokémon Sword & Shield or Brilliant Diamond & Shining Pearl, will recognize the core concept of Combee’s evolution, but the execution is different.
The fundamental rule of female Combee only evolution is consistent across the entire Pokémon franchise. This mechanic is based on Vespiquen’s “queen bee” lore, meaning a male Combee can never evolve, regardless of the game.
However, the evolution method changes based on each game’s progression system.
  • In Pokémon GO: You need to collect 50 Combee Candy to evolve an eligible female.
  • In the Main Series Games: You must raise a female Combee to Level 21. Upon reaching this level, the evolution into Vespiquen triggers automatically.
Learn More:How to Increase Shiny Odds in Pokémon GO: The Real Strategy >
Here is a simple breakdown of the Vespiquen evolution requirements by game type:
Game Evolution Method Gender Requirement
Pokémon GO 50 Combee Candy Female Only
Main Series Games Reach Level 21 Female Only
Frequently Asked Questions about Combee Evolution
Why can’t I evolve my Combee in Pokémon GO?
You can only evolve Combee if it is female, which you can confirm by the (♀) symbol next to its name. Male Combee, which are far more common, do not have the ability to evolve. This is an intentional game mechanic, not a bug.
What is the difference between male and female Combee evolution?
There is no “male Combee evolution.” The critical difference is that a female Combee can evolve into Vespiquen, while a male Combee cannot. A female is identifiable by the female symbol (♀) or the red/orange mark on its lowest face.
How do I evolve Combee into Vespiquen?
You need two things: 1) a female Combee (♀) and 2) 50 Combee Candies. When both conditions are met, the ‘Evolve’ button will be available on its summary screen.
Is Vespiquen a good Pokémon in Pokémon GO?
Vespiquen has niche uses, primarily in the Great League of the GO Battle League. Its Bug/Flying typing can be effective against certain opponents, but it is not considered a top-tier attacker for raids.
Where can I find female Combee?
Female Combee spawn in the same places as males—typically parks, forests, and natural areas. Spawns are boosted during rainy weather and Bug-type events. However, they are significantly rarer, with a spawn rate of only about 12.5%.
How much candy does Combee need to evolve?
Evolving a female Combee into Vespiquen requires 50 Combee Candy.
Is Combee evolution the same in all Pokémon games?
No. While the requirement of the Combee being female is universal, the method differs. Pokémon GO uses 50 candy, whereas the main series console games require raising a female Combee to Level 21.
Why does my Combee have no evolution option?
Your Combee has no evolution option because it is a male (♂). The Pokémon GO interface only shows the ‘Evolve’ button when a Pokémon is eligible. Since being female is a core requirement, the option is permanently hidden for all males.
Learn More:iTools Dongle Pokémon Go: The Complete User Guide >
Now that you understand the precise Combee evolution method and gender difference, the frustration can finally end. You no longer have to wonder if your game is broken or waste time on ineligible Pokémon. Knowing that the female spawn rate is only 12.5% sets a realistic expectation for the hunt. For those who choose to use third-party tools to overcome this scarcity, remember to be fully aware of the risks involved. Happy hunting
