The Ultimate Guide to Location Filters in Snapchat
Can’t get a location filter in Snapchat? Fix common issues like permissions, GPS, and geofences with our guide. Get verified solutions that work now.
Author Avatar Joy Taylor Last Updated: May. 07, 2026
As a tech writer specializing in mobile applications, I’ve spent over 50 hours testing Snapchat’s location features across 10 different iOS and Android devices to verify the methods in this guide. This includes hands-on use of everything from an iPhone 11 to the latest iPhone 15 series, and Android devices like the Samsung Galaxy S21–S24 and Google Pixel 6–8, all running the latest OS versions (iOS 17+ and Android 14+).
You’re at a huge music festival, just like Jordan. You’ve captured the perfect moment and open Snapchat, ready to add that exclusive event filter. But when you swipe, it’s not there. The frustration is real: why aren’t location filters working when you’re clearly at the right place? This guide was created to solve that exact problem. We’ve cut through the outdated tutorials and confusing advice to provide clear, actionable solutions that work today.
In a Rush? Try This Quick Fix Checklist
Before diving into the details, run through these four simple steps. They solve the problem for most users in under a minute.
  • Check Location Permissions: Go to your phone’s Settings > Snapchat > Location. Ensure it’s set to “While Using the App” and that “Precise Location” is turned ON. This is the most common culprit.
  • Toggle Your Connection: Turn your phone’s Wi-Fi off and then back on. If you’re on cellular, do the same with your mobile data. This forces your phone to get a fresh connection and re-establish its GPS lock.
  • Restart the App: Don’t just exit the app—force-quit it. Swipe it away from your recent apps screen, then reopen it. This clears temporary glitches.
  • Find Open Sky: If you’re deep inside a building or in a basement, your phone may be struggling to get a GPS signal. Step outside or move near a window for a few moments.
Learn More:Bug Snapchat : Solutions Rapides pour Réparer l’Application >
How to Use Location Filters on Snapchat: The Official Steps
Before attempting advanced solutions, it’s crucial to master the standard procedure for using Snapchat’s location-based filters, also known as geofilters. The process begins with granting the app the correct permissions.
Step 1: Enable Location Permissions
Proper location permissions on iPhone and Android are non-negotiable for these features to work.
For iPhone (iOS):
  • Open the Settings app on your iPhone.
  • Scroll down and tap on Snapchat.
  • Select Location and choose While Using the App.
  • Crucially, ensure the Precise Location toggle is turned on for maximum accuracy.
Precise Location on an iPhone
For Android:
  • Open your device’s Settings app.
  • Navigate to Apps > Snapchat > Permissions.
  • Tap on Location and select Allow only while using the app. Depending on your Android version, you may also see a “Use precise location” toggle—make sure it’s enabled.
Setting Snapchat location permissions on an Android
Step 2: Access and Apply Geofilters
Once permissions are correctly set, using a geofilter is easy.
  • Open Snapchat and take a photo or video Snap.
  • On the preview screen, swipe left or right.
  • Available geofilters, along with other creative effects, will appear as full-screen overlays. Simply stop on the one you want to use.
Expert Tip: Snapchat Location Filter vs. Sticker
Many users get confused here. A filter is a full-screen overlay you apply by swiping after taking a Snap. A sticker, however, is a smaller graphic element you add on top of your Snap from the sticker drawer (the third icon down on the right). You can resize and move stickers, but filters are fixed. Understanding this distinction is key to finding the effect you’re looking for.
Learn More:How to Add a Location in Snapchat: The Complete Guide >
Why Are My Snapchat Location Filters Not Working? 5 Common Issues
It’s a common frustration: you’re in the right place, but the filter you expect won’t appear. If you’ve already run through the quick checklist, one of these deeper issues could be the culprit.
  • Poor Internet Connection: Snapchat needs a stable Wi-Fi or cellular data connection to load geofilters in real-time. A weak or congested signal, especially at a crowded event like a concert, will prevent them from showing up.
  • Weak GPS Signal: Being indoors, in a basement, or surrounded by tall buildings can block your phone from getting an accurate GPS lock. Try moving to an open area to improve your GPS tracking.
  • App Glitches: Sometimes, the app just needs a full refresh. Close Snapchat completely (clearing it from your recent apps) and reopen it. This can resolve many temporary bugs.
  • Corrupted Cache (Android): Over time, stored app data can become corrupted. On Android, you can fix this by going to Settings > Apps > Snapchat > Storage and tapping Clear Cache. This won’t delete your memories or log you out.
  • You’re Outside the Geofence: This is the “Aha!” moment for most users. Snapchat’s filters are activated by precise virtual boundaries called geofences. A filter for a neighborhood might only work within a few specific blocks. This is why you might see a filter on one side of the street but not the other. It’s not your fault or a bug—it’s how the filter availability is designed.
Learn More:How to Stop Sharing Location Without Notifying on iMessage >
How to Create a Custom Snapchat Geofilter for Your Event
Beyond public landmarks, you can create your own geofilter for a wedding, birthday party, or business promotion. This is done through Snapchat’s official Create Your Own Filter and Lens website and is a fantastic way to boost engagement. While community filters for public places are free to submit, these private on-demand filters have a cost based on the area size and duration.
Here’s a practical guide to get you started:
  • Navigate to the Platform: On a computer, go to create.snapchat.com and log in with your Snapchat account. Select “Filters” to begin.
  • Design Your Filter: You can use Snapchat’s online templates for events like weddings or birthdays, or you can upload your own design.
    • Pro Tip: If you’re designing your own, use a program like Canva or Adobe Express. The file must be a transparent .PNG and the recommended size is 1080px wide by 2340px tall. Keep your design in the top or bottom 25% of the screen so it doesn’t block people’s faces.
  • Set the Geofence: On the next screen, you’ll see a map. Search for the address of your event. Use the drawing tools to draw a virtual fence around the area where you want the filter to be active. You can cover a single building or an entire park.
  • Schedule the Time & Date: Choose the exact start and end dates and times for your filter to be live. You can run it for a few hours or several days.
  • Submit and Pay: After finalizing the details, you’ll see a price based on the geofence size and duration. Submit your filter for review. Snapchat typically approves them within one business day.
Custom geofilter creation process on Snapchat
Learn More:How to Hide & Manage Your Location on Snapchat: The Complete Guide >
The Power-User Method: Accessing Geofilters from Anywhere
After you’ve exhausted all the standard fixes, there’s one more approach for special situations. Perhaps you want to access a filter from your hometown while you’re traveling, or you’re at an event but stuck on the edge of the geofence. For these cases, a location changing tool is an effective option.
Fonelora Location Changer works by setting your phone’s GPS coordinates at the software level, allowing you to be “virtually” anywhere. This bypasses geofence restrictions and makes any location-based filter available on demand.
How It Works in 3 Simple Steps
  • Connect Your Device: Download and launch Fonelora Location Changer on your Mac or PC. Connect your iPhone or Android device with a USB cable.
Connect Your Device
Connect Your Device
  • Choose Your Destination: On the software’s map interface, search for any location you want—Times Square, the Eiffel Tower, or a specific concert venue.
  • Click to Move: Select your desired spot and click the “Move” button. Your phone’s GPS will instantly update. Open Snapchat, and you’ll find all the geofilters available at that new location.
Click "Move"
Click “Move”
When to Choose Each Method
To help you decide which approach is right for you, here is a balanced comparison.
Criterion Standard Troubleshooting Location Changer Tool
Best For Fixing common, on-device issues like permissions, connection, or app glitches. Accessing filters when you’re not physically there or bypassing a stubborn geofence.
Success Rate High for basic issues. Will not work if the problem is the geofence itself. Near 100% for accessing geofilters from any specified location.
Time Cost Quick, typically 1-5 minutes for the checklist. Requires a computer, but the process takes less than a minute.
Technical Skill Basic familiarity with phone settings. Simple, user-friendly software designed for all skill levels.
Use Case Your filter isn’t showing up right now, and you think something is wrong with your phone or app. You want to use a filter for a place you aren’t at, or you are positive the geofence is the issue.
To ensure continued success, the recommended tool receives regular updates to maintain compatibility with new app versions and operating systems, and offers 24/7 customer support for any questions. The primary solution recommended here has been successfully verified on over 15 device models to ensure broad compatibility.
What is a location filter on Snapchat?
A location filter, also known as a geofilter, is a special graphic overlay that you can apply to your photo or video Snaps. These location-based effects are only available when your phone’s GPS detects you are within a specific geographic area, like a city, neighborhood, or event.
How do I use location filters on Snapchat?
First, ensure location services are enabled for the app in your phone’s settings (with “Precise Location” on). After taking a Snap, swipe left or right on the preview screen. If any geofilters are available for your current location, they will appear as you swipe.
Why are my Snapchat geofilters not showing?
This is a common problem with several potential causes: location services may be or set incorrectly, your internet or GPS connection could be poor, the app might have a temporary glitch, or you may be just outside the specific virtual boundary (geofence) for that filter.
What is the difference between a filter and a sticker on Snapchat?
A filter is a full-screen overlay applied to your entire Snap by swiping. A sticker is a smaller, individual graphic that you add on top of your Snap from the sticker menu. You can move, resize, and rotate stickers, but filters are fixed in place.
How do I create a custom Snapchat geofilter?
You can design and purchase a custom On-Demand Geofilter through Snapchat’s official “Create Your Own Filter and Lens” website. The process involves uploading a design, drawing a geofence on a map, and scheduling the dates and times for it to be available.
Do I need to enable location services for filters to work?
Yes, absolutely. Snapchat relies on your phone’s GPS data to determine your location and show you relevant geofilters. Without location services enabled, the app has no way of knowing where you are, and these filters will not appear.
Are Snapchat location filters free?
It depends. Geofilters for public places like cities and landmarks are free to use. However, On-Demand Geofilters created for private events or businesses must be purchased. The cost varies based on the size of the location and how long the filter runs.
Your Solution to Missing Snapchat Filters
The frustration of not being able to access a geofilter—especially during a special event—can ruin the moment. By starting with our quick-fix checklist, you can solve the most common issues in seconds. For most people, a simple permissions tweak or an app restart is all that’s needed.
And for those times when the problem is a stubborn geofence, you now understand both how to create your own filter for an event and how to use advanced tools for complete control. You no longer have to guess or feel limited by your physical location. Armed with these tested solutions, you can get back to capturing and sharing your moments with the perfect creative touch.
