Quick Answer:
As of the latest Team GO Rocket rotation, Leader Cliff’s lineup features high-damage Shadow Pokémon that require specific type counters to defeat. His team rotates based on current in-game events, but his current active lineup is:
Phase 1 (Always this Pokémon): Shadow Machop
Phase 2 (One of these three): Shadow Aerodactyl, Shadow Kingdra, or Shadow Gallade
Phase 3 (One of these three): Shadow Crobat, Shadow Tyranitar, or Shadow Cradily
Because Shadow Pokémon deal massive boosted damage, bringing general high-CP Pokémon is rarely enough. You must build a team that specifically exploits their weaknesses and resists their fast attacks.
Cliff will always send out his fixed first Pokémon to start the battle. Currently, this is Shadow Machop. Your primary goal in Phase 1 is not just to defeat Machop, but to employ a “shield-baiting” strategy.
Cliff has two Protect Shields and will always use them on your first two Charged Moves. To break his shields early, lead with a Pokémon that has a fast-charging Charged Move. Once his shields are gone, your remaining team can deal massive damage in phases 2 and 3 unhindered.
| Cliff’s Pokémon | Type | Weaknesses | Resistances | Top Counters |
| Machop | Fighting | Flying, Psychic, Fairy | Bug, Dark, Rock | Mewtwo (Confusion/Psystrike) Togekiss (Charm/Dazzling Gleam) Sylveon (Charm/Moonblast) Alakazam (Psycho Cut/Psychic) |
If your lead Pokémon charges attacks quickly, like Togekiss or Sylveon, fire them off immediately to burn Cliff’s shields. Even if the move does little damage, getting those shields out of the way is critical for the rest of the battle.
Phase 2 is where the battle becomes heavily RNG-dependent. Cliff will randomly send out one of three possible Pokémon, meaning your team needs flexibility. If your lead Pokémon from Phase 1 has a bad matchup against what appears, you need a versatile “safe swap” ready on your bench.
| Cliff’s Pokémon | Type | Weaknesses | Top Counters |
| Aerodactyl | Rock / Flying | Electric, Ice, Rock, Steel, Water | Metagross (Bullet Punch/Meteor Mash) Kyogre (Waterfall/Surf) Magnezone (Spark/Wild Charge) |
| Kingdra | Water / Dragon | Dragon, Fairy | Togekiss (Charm/Dazzling Gleam) Dialga (Dragon Breath/Draco Meteor) Sylveon (Charm/Play Rough) |
| Gallade | Psychic / Fighting | Flying, Ghost, Fairy | Giratina Origin (Shadow Claw/Shadow Ball) Gengar (Shadow Claw/Shadow Ball) Togekiss (Charm/Aerial Ace) |
Fairy-types like Togekiss and Sylveon are excellent versatile picks here, as they can confidently handle both Kingdra and Gallade while resisting their powerful attacks. If Aerodactyl spawns, immediately swap to a bulky Steel or Water-type.
Cliff reserves his strongest Shadow Pokémon for Phase 3. If you successfully broke his shields in Phase 1, you can use your stored energy to unleash heavy Charged Moves immediately as this final Pokémon enters the field.
| Crobat | Poison / Flying | Electric, Ice, Psychic, Rock | Mewtwo (Psycho Cut/Psystrike) Rhyperior (Smack Down/Rock Wrecker) Tyranitar (Smack Down/Stone Edge) |
| Tyranitar | Rock / Dark | Fighting (2x), Bug, Fairy, Grass, Ground, Steel, Water | Lucario (Counter/Aura Sphere) Machamp (Counter/Dynamic Punch) Conkeldurr (Counter/Dynamic Punch) |
| Cradily | Rock / Grass | Bug, Fighting, Ice, Steel | Metagross (Bullet Punch/Meteor Mash) Lucario (Counter/Aura Sphere) Mamoswine (Powder Snow/Avalanche) |
Try to farm a little extra energy at the end of Phase 2 before knocking out his second Pokémon. This allows you to fire off a Charged Move the instant Crobat, Tyranitar, or Cradily appears.
Remember, if you lose the battle, the lineup for that specific Pokéstop will not change for the rest of the day. You can simply rematch Cliff with a newly adjusted team tailored exactly to the three Pokémon he just showed you.
Knowing how to defeat Cliff is only half the battle; actually finding him can be a major source of frustration.
To encounter any Team GO Rocket Leader, you must first defeat six regular Grunts to collect Mysterious Components and assemble a Rocket Radar. Once equipped, the radar reveals Leader hideouts at local Pokéstops and triggers Leader balloons.
Here is the friction: the Leader that spawns is entirely random.
You might spend hours assembling a Rocket Radar because you specifically want Cliff’s Shadow Pokémon, only to tap a balloon or walk to a Pokéstop and find Arlo or Sierra instead. Because you cannot change which Leader is stationed at a specific stop, the only reliable method to find Cliff is to physically travel and check the best location for Pokémon GO with dense Pokéstop clusters until he appears.
For rural players, players with limited mobility, or those stuck at home with only one or two local Pokéstops, this RNG mechanic is highly frustrating. If the only Pokéstop near you spawns Sierra, you are completely stuck until the next day unless you have a way to check a wider radius of Pokéstops.
If you are stuck at home or in an area with few Pokéstops and keep running into Arlo or Sierra, finding Cliff requires expanding your search radius. Fonelora Location Changer provides a guided desktop workflow for supported iOS and Android devices, acting as a reliable Pokémon GO location changer that allows you to safely simulate movement and navigate to multiple Pokéstops virtually to hunt for Cliff.
Rather than walking miles just to check which Leader is at a stop, you can use Fonelora’s Game Mode and Teleport features to efficiently scan your wider neighborhood.
Realistic GPS movement simulation, flexible route control, easy no-modification setup, and support for gaming, social, privacy, and location-based testing in one platform.
Connect Your Device: Open Fonelora Location Changer on your PC or Mac and connect your supported iPhone or Android device.
Select Game Mode: Choose Game Mode from the interface. This mode is specifically designed for location-based games.
Navigate with Teleport or Joystick Mode: Use Teleport Mode to jump to different Pokéstop clusters in your city, or use Joystick Mode to smoothly walk down streets and check nearby stops for Cliff’s hideout.
Respect the Cooldown Timer: This is crucial for account safety. Game Mode features a built-in Cooldown Timer. If you teleport over a long distance, always wait for the timer to reach zero before you spin a stop, catch a Pokémon, or engage Cliff. Ignoring cooldown rules can result in soft bans where Pokémon flee and stops yield no items.
By using controlled, cooldown-aware virtual movement, you can efficiently skip unwanted Leaders and easily farm Cliff encounters under supported conditions.
Defeating Team GO Rocket Leader Cliff comes down to preparation. By bringing fast-charging counters to break his shields early in Phase 1, and maintaining flexible type coverage to handle his RNG-heavy Phase 2 and massive Shadow damage in Phase 3, you can consistently farm his encounters for a chance at a Shiny Shadow Pokémon.
However, finding him doesn’t have to be a frustrating chore of checking empty rural spots or running into Sierra five times in a row. If you lack local Pokéstops and want a practical way to expand your search radius safely, Fonelora Location Changer offers a reliable solution. By using Game Mode and following the built-in cooldown reminders, you can smoothly navigate to multiple stops virtually and battle Cliff on your own terms.
Check your device compatibility and try Fonelora Location Changer today to take the friction out of hunting Team GO Rocket Leaders.
More Related Articles
