Joy Taylor
Joy Taylor | Last Updated: Jun. 9, 2026
Dialga is one of the most powerful Legendary Pokémon in Pokémon GO, but many players still struggle to get it during limited-time Tier 5 raid rotations. Since Dialga only returns during specific events, missing an active raid window can make it difficult to add this Master League powerhouse to your collection.
This guide explains exactly how to get Dialga in Pokémon GO, including how to join remote raids, the best Dialga raid counters, how to improve your catch rate, and whether shiny Dialga is currently available.
Catch Dialga in Pokémon GO
How to Get Dialga in Pokémon Go
The main way to get Dialga in Pokémon GO is through limited-time Tier 5 legendary raids. Because Dialga does not spawn in the wild, players must wait for an active raid rotation before encountering it.
To get Dialga quickly, follow these steps:
  • Wait for an active Dialga raid event in Pokémon GO.
  • Purchase or save Remote Raid Passes.
  • Use apps like PokeGenie or Campfire to join global Dialga raid lobbies.
  • Build a team of strong Ground and Fighting-type counters.
  • Defeat Dialga in the raid battle.
  • Use Golden Razz Berries and Excellent Curveballs to improve your catch rate.
Remote raids are currently the easiest way to get Dialga, especially for players living in areas with inactive local gyms.
There are currently three main ways to get Dialga in Pokémon GO:
Join Remote Dialga Raids
Remote raids are the easiest and most reliable method for most players. Apps like PokeGenie and Campfire allow trainers to join global Dialga raid lobbies without relying on active local gyms.
Participate in Local Tier 5 Raids
Players can also battle Dialga through local in-person raids during active legendary raid rotations. This option works best in areas with large Pokémon GO communities.
Trade With Other Players
If Dialga is no longer available in raids, trading with a friend is another option. However, unregistered Legendary trades can require a very large amount of Stardust.
Best Dialga Raid Counters in Pokémon GO
Dialga is a Steel and Dragon-type Legendary Pokémon, making Fighting and Ground-type attackers the best raid counters.
Top Dialga counters include:
  • Terrakion — Double Kick + Sacred Sword
  • Lucario — Counter + Aura Sphere
  • Groudon — Mud Shot + Precipice Blades
  • Excadrill — Mud-Slap + Drill Run
  • Conkeldurr — Counter + Dynamic Punch
For smoother raid battles, try joining lobbies with at least four to five high-level trainers.
How to Catch Dialga After a Raid
After successfully defeating the boss, the final obstacle is the actual capture phase. Failing to catch Dialga Pokémon Go after investing in premium items and waiting in app queues is a costly outcome. You must approach this phase carefully to ensure you secure your target without wasting multiple paid passes.
The base capture rate for legendary Pokémon is a mere 2%. To address this critically low probability, you must execute a systematic throwing procedure known as the “circle-lock” technique combined with precise timing:
1. Apply a Golden Razz Berry: Always feed the boss a Golden Razz Berry before every single throw. This increases the capture multiplier by 2.5x.
Apply a Golden Berry
2. Set the Target Circle: Press and hold the Poke Ball until the colored target ring shrinks to the “Excellent” size, then release your finger without throwing. This establishes the circle lock.
3. Wait for the Specific Attack Animation: Do not throw the ball when the Pokémon is idle. Dialga has a very distinct rear-back and head-thrust attack animation.
4. Execute the Curveball with Exact Timing: Dialga’s head snaps back into place much faster than other legendaries, meaning the vulnerability window closes quickly. You must spin the ball and throw your Excellent Curveball exactly at the moment its head is still moving forward, not after it resets. The locked circle will remain exactly where you set it.
By combining Golden Razz Berries with consistent Excellent Curveballs timed to this specific head-thrust animation, you push your capture probability per throw up to roughly 15%. This strict discipline ensures you secure your target efficiently.
imobie tips
If you encounter a Shiny Dialga after the raid, you have won the jackpot! Shiny legendary Pokémon from raids feature a guaranteed 100% catch rate on the first successful Poké Ball hit. Do not waste a Golden Razz Berry on a shiny encounter. Always use a Pinap Berry or Silver Pinap Berry to double your Candy rewards, as the capture is guaranteed the moment the ball makes contact.
Can Dialga Be Shiny in Pokémon GO?
Yes. Shiny Dialga is available during specific Pokémon GO raid events when Dialga appears as an active Tier 5 boss.
The shiny encounter rate is estimated to be around 1 in 20 during active raid periods. If you encounter a shiny Dialga, the capture is guaranteed once your Poké Ball successfully hits the target.
Using a Pinap Berry during shiny encounters is recommended because the guaranteed catch allows you to earn extra Dialga Candy.
Dialga Raid Schedule & Availability
Players frequently ask: Can you still get Dialga in Pokémon Go right now? The answer depends entirely on the game’s current server schedule. Unlike common wild spawns, a specific Pokémon Go Dialga location does not exist on the standard world map.
Historically, Dialga frequently appears during major global summer events, such as Pokémon Go Fest, or regional celebrations like the Sinnoh Tour in February. Niantic typically cycles major box legendaries into the Tier 5 raid rotation every eight to twelve months. If the Temporal Dragon is not currently listed as the active boss for the month, you cannot find it in local gyms.
To track these specific dates, you should monitor the monthly content update infographics released on the official Pokémon Go social media channels or the in-game news feed. These updates provide the exact dates and times for upcoming legendary rotations.
These limited event windows are often the only time you can encounter a Pokémon Go shiny Dialga. The shiny variant is never guaranteed, featuring an estimated encounter rate of roughly 1 in 20 during active raid periods. Remember to apply the Pinap Berry rule mentioned earlier if you are lucky enough to find one.
Pokemon Go Raid Schedule
Is Dialga Good in PvP?
Yes. Dialga remains one of the strongest Master League Pokémon because of its powerful Steel and Dragon typing.
Its best PvP moveset includes:
  • Dragon Breath
  • Iron Head
  • Draco Meteor
Dialga performs especially well against Dragonite, Lugia, and Togekiss, but struggles against strong Ground-type Pokémon like Groudon and Excadrill.
A Useful Tool for Location-Based Gameplay Exploration
In Pokémon GO, legendary Pokémon like Dialga are often tied to special events, raids, or region-based availability, meaning gameplay can be influenced by real-world location factors. For players who want to better understand or simulate how these mechanics work, a location control tool may be useful in certain scenarios.
FoneLora Location Changer is a GPS simulation tool that allows users to change their device location instantly using a simple map interface. It supports both iOS and Android devices and enables switching between different global locations or simulating movement routes.
To resolve any remaining questions about locating and battling this legendary Pokémon, review these direct answers to the most common community inquiries.
How do you get Dialga in Pokémon GO?
You can get Dialga by defeating it in a Tier 5 legendary raid during active event rotations.
Can Dialga be shiny in Pokémon GO?
Yes. Shiny Dialga is available during specific raid events.
What is Dialga weak against?
Dialga is weak against Fighting and Ground-type attacks.
Can you get Dialga without remote raids?
Yes, but local raid participation depends on active gyms and nearby players.
How often does Dialga return to Pokémon GO?
Dialga usually returns during major annual events and legendary raid rotations.
Is Dialga good in PvP?
Yes, it is incredibly powerful in the Master League. Its unique Steel and Dragon typing provides excellent defensive resistances, making it a top-tier choice for competitive battling. For optimal results, seek an IV spread of at least 15/14/12 to hit necessary damage breakpoints.
To sum up, Dialga remains one of the most iconic Legendary Pokémon in Pokémon GO, often featured in raids and special events that require strategic preparation and participation.
Because many Pokémon GO mechanics are tied to real-world positioning and regional activity, some players also explore tools that help them better understand how location affects gameplay. In this context, FoneLora Location ChangerFoneLora Location Changer can be used as an optional utility for simulating GPS locations and testing different in-game scenarios.
Overall, it offers an additional perspective on how location-based gameplay systems are structured and experienced.
Related Articles
How to Fake Location on Life360 Without Alerts (2026 Guide)
Soundmap Hacks 2026: The Truth About Cheats, Glitches, and Safe Strategies
How to Hide IP Address: Privacy & Security Guaranteed (2026)
