4 Workable Ways to Fix Xiaomi/Redmi Stuck on Mi Logo
Is your Xiaomi/Redmi phone stuck on the Mi logo screen? If so, it’s nothing to stress yourself about, as we understand how annoying it could be. This post presents to you the 4 workable solutions to Xiaomi/Redmi stuck in the Mi logo.
Author Avatar Joy Taylor Last Updated: Mar. 12, 2025
DroidKit – Fix Xiaomi/Redmi Stuck on Mi Logo 1-Click
Your Mi phone stuck on Mi logo? Free download DroidKit to fix the Xiaomi stuck on Mi logo in clicks. No need to root your device and no technical skills are required.
Hi there,
My Xiaomi phone is stuck on the Mi logo screen and I don’t know the reason for that. How do I fix Xiaomi stuck on mi logo? Kindly help a friend please!
Mi also known as Mission impossible is the logo that comes up when you power on your Xiaomi phone. And by default, the logo should appear and disappear within a few seconds after popping up on your screen. But if you are stuck in the Mi logo screen after turning on the Xiaomi phone, then something must be wrong. In this post, we will discuss the reasons why your Xiaomi phone is stuck on the Mi logo screen and the various troubleshooting techniques you can follow to resolve it.
Why Is Xiaomi/Redmi Stuck on Mi Logo?
When your Xiaomi/Redmi phone is stuck on the Mi logo screen after booting it, then one of the following must be the reasons you experience such an issue:
  • Software Problem – Operating your Xiaomi/Redmi phone on an obsolete Android OS can cause a lot of issues, and one of them is the one you are currently faced with. The reason is that older Android OS is usually filled with bugs and errors after an extended period and that can disrupt the functionality of your device.
  • Insufficient Storage – When you run out of memory space, the corresponding device would definitely get stuck while operating it. With this in mind, we can attribute the Xiaomi/Redmi phone stuck in the Mi logo screen to this reason.
  • Filled Partition Cache – The partition cache is a temporary storage for keeping data on your Xiaomi device. If this storage section is filled up, a device can malfunction and display several issues including Xiaomi stuck on the Mi logo screen.
Having discussed the reasons for facing the underlying issue on your Xiaomi/Redmi phone, let’s proceed to explore the various troubleshooting solutions you can try out to fix it.
1-Click to Fix System Crash Causing Xiaomi Stuck on Mi Logo [Safe & Easy]
The ultimate way to fix Xiaomi/Redmi stuck on Mi logo is to repair the system using a reliable Android repair software like DroidKit – Android Phone Toolkit.
It doesn’t matter what the reason for the underlying issue is, DroidKit fixes your device and reinstates its operations back to optimal level. All of your data files are safe when using DroidKit. This intuitive Android repair solution features one of the most powerful algorithms which focuses on the required operation and doesn’t interact with your data files. Besides resolving Xiaomi/Redmi stuck on Mi logo screen, you can also employ the services of this software when faced with Android related issues such as frozen screen, unresponsive buttons, and 150+ more.
Key Features
  • Repairs Xiaomi/Redmi stuck in Mi logo screen issues and 150+ more within a few clicks.
  • Revive dead Android devices in a few simple steps.
  • 100% secure and stable, with no risk of being infected with viruses or malware.
  • It can also fix Samsung, Xiaomi, Redmi, and POCO devices with won’t charge, error reports, stuck in a certain mode, touch screen not working problems, etc.
  • Except for system repair, DroidKit also provides you the solutions on Android data recovery, Android lock screen removal, Samsung data extraction, FRP bypass, etc.
Free get the latest version of DroidKit, and take the following detailed instructions to fix system crash causing Xiaomi stuck on Mi logo:
Stepwise Guide to Fix System Crash Causing Xiaomi Stuck on Mi Logo
Step 1. Free install DroidKit and open the program on your computer > Click the System Fix mode.
Click System Fix Function
Step 2.  Once DroidKit detected your device, click the Start button to continue. And choose the Xiaomi brand.
Select Your Device Brand
Step 3. DroidKit will get the PAD code. Please click the Download Now button to get the firmware package. When the firmware is downloaded, please follow the instructions to put your Xiaomi phone in Download Mode. Tap on the Next button to continue.
Put Xiaomi in Recovery Mode
Step 4. Then, the device system will start to get repaired. Wait for a few minutes, your Xiaomi phone will get back to normal condition.
Completing the Repair Process
3 Common Ways to Fix Xiaomi Stuck on Mi Logo
Though the aforementioned solution fixes everything that could be responsible for Xiaomi stuck on the Mi logo screen, there are other basic solutions you could try out in case you don’t have access to a computer when the issue pops up. Find below, the 3 common ways recommended by Android experts to fix the underlying issue:
Way 1. Clear Cache Partition to Fix Xiaomi Stuck on Mi Logo
Too many cache partitions can cause a system to malfunction, leading to stuck on Mi logo screen issues. It’s best to clear the cache partition to resolve the issue and reinstate your Xiaomi device to optimal operation. This solution is often completed from the device itself via the settings panel.
Follow the simple illustrative guide down here to clear cache partition on your Xiaomi phone:
  • Turn off the faulty Xiaomi phone by long pressing the appropriate key combinations.
  • Next, press down the Volume + Power buttons simultaneously, until you see a menu of options appear on your screen.
  • After that, click on the Recovery icon and select your preferred language.
  • Using the Volume Up or Volume Down button, scroll through the options displayed on the subsequent screen. Once you get to the Wipe & Reset option, use the Power button to click on it.
  • Now, click on Clear Cache data to proceed with wiping cache partition on your Xiaomi phone.
After completing the guide above, restart the Xiaomi device and the stuck on Mi logo screen issues should be gone.
Way 2. Fix Xiaomi Stuck on Mi Logo Screen via Force Restart
Force restart is another wonderful solution to implement when faced with Xiaomi stuck on the Mi logo screen. This simple yet cost free solution aims to refresh your device so all the bugs and temporary glitches that are responsible for the problem you are faced with are cleared. Additionally, your Xiaomi temporary storage, RAM is also improved when you use this solution.
To force restart your Xiaomi phone, the simple guide below should do justice:
  • Hold down the Power button for approximately 10 seconds.
    Force Restart the Android Device
  • Your screen will turn off and on within a few seconds, then you can release the Power button.
  • Once done, the issue should be resolved and your Xiaomi phone will boot up without complications.
Way 3. Update Firmware to Fix Xiaomi Stuck on Mi Logo
Running your Xiaomi phone on a damaged firmware is one of the principal reasons why the device could display the issue you are faced with. It’s suggested that you update your firmware. However, to use this solution, you must have a computer at your disposal since you need a Mi Flash tool to download the firmware. Here’s the guide to follow:
  • Turn off your Xiaomi phone using the right set of keys, then press down the Volume + Power buttons to enter fastboot mode.
    Put the Phone in FASTBOOT Mode
  • Download the Mi Flash tool on your computer, launch it and download the most recent firmware for your device.
  • Once done, proceed to link the faulty Xiaomi phone to your computer using a certified USB cable.
  • Next, open the downloaded firmware and refresh the Mi Flash tool to detect your phone.
  • Afterwards, hit the Flash button to update the firmware on Xiaomi.
Note: Don’t interact with the connection while completing the solution above to avoid interruption. Once the process is over, then you can detect the Xiaomi phone from the computer.
FAQs on Xiaomi/Redmi Stuck on Mi Logo
Q1. Can factory reset fix Xiaomi stuck on Mi logo screen?
This question is quite tricky as we have to consider whether the underlying issue is OS related or not. In case the problem is OS related, then factory resetting your Xiaomi device won’t be helpful in resolving it. But if the Xiaomi stuck on Mi logo is caused by something else, then factory reset could be helpful.
Q2. How do I prevent Xiaomi stuck on the Mi logo screen?
To avoid Xiaomi stuck on the Mi logo screen issue in the future, it’s best you adhere to the following pro tips:
  • Keep your device away from viruses.
  • Ensure you have enough storage on your device from time to time.
  • Always update your Xiaomi phone when due.
There you go with the 4 workable ways to fix Xiaomi/Redmi stuck on Mi logo issues. We introduced 3 basic solutions and the ultimate one which involves DroidKit. Our most preferred solution is DroidKit. The software performs excellently when it comes to system repair operations and you don’t have to worry about OS compromise when using it. It works for all Android OS versions and is super easy to use.  Download it right now to experience it!
