Explore the full review on SPD Flash Tool. Additionally, you can use DroidKit to handle some issues like bypass FRP, unlock screen as a compliment.
The SPD Flash Tool is a program that facilitates the process of loading device firmware to Android devices powered by Spreadtrum (SPD) chipsets. If your primary goal is to resolve boot loops, update firmware, or bypass FRP, then this tool is the ideal solution for flashing PAC or P5C files correctly. It is the ideal choice for those with advanced technical skills or professionals who need to perform phone resurrection or software troubleshooting.
This article will discuss the SPD Flash Tool, list its features, outline its versions, and provide instructions on how to download and install the latest version. Additionally, we will discuss DroidKit, a new option that simplifies the process of unlocking FRP on any Android device without complications.
The SPD Flash Tool, also referred to as the SPD Upgrade Tool, is a Windows-based utility designed for upgrading firmware on Android devices with Spreadtrum (Unisoc) chipsets. The tool’s GUI is so straightforward that it facilitates the process without complications, even for those unfamiliar with it.
Therefore, whether you’re repairing a bricked phone or resolving boot loops, the software can help. Moreover, the software accepts firmware files in the PAC format. It is compatible with various devices, including smartphones, tablets, and feature phones.
The official SPD Flash Tool website provides an archive of both the latest and older versions, enabling users to select the most compatible build for their device. Here is the latest version:
SPD Flash Tool R27.24.2301 – The latest stable release, compatible with newer Unisoc devices and improved flashing stability.
Besides the Upgrade Tool, the official site provides several other related utilities, such as:
Download the latest version of the SPD Flash Tool by following these instructions:
Step 1. Visit the official website
Access the authorized source for SPD flashing utilities and tools.
Step 2. Go to the download section
Go to the ‘Download SPD Flash Tool’ area or utilize the top navigation bar to locate the right page.
Step 3. Pick the most recent version
Look for the most recent version on the website.
Step 4. Click the download button
When you click on the appropriate link, a ZIP file will be downloaded directly to your computer. Then, unzip the archive and store the files locally.
Step 1: Install SPD USB drivers
Before proceeding, ensure that you have installed the correct SPD (Spreadtrum) USB drivers on your Windows PC. This ensures your device can be detected in flashing mode.
Step 2: Launch SPD Flash Tool
Double-click on the UpgradeDownload.exe file to launch the SPD Flash Tool interface.
Step 3: Load the firmware
Click on the Load Packet or Load Firmware button (depending on the version you’re using).
Locate and select the PAC firmware file you’ve downloaded for your specific device model.
Step 4: Connect your device
Power off your SPD device. Press and hold the specific key combination for flash mode (often Volume Down or Volume Up) and connect it to the PC using a USB cable. The tool should automatically detect your device.
Step 5: Start the flashing process
Press the green Start button on the tool. A progress bar will be displayed as the flashing process is performed. Don’t remove your device while the process is running. When the flashing is done, a “Passed” or green success message will be shown. Then you can unplug your phone and start it up without any problems.
Suppose SPD Flash Tool seems like it’s too technical, or you are using a device from a brand other than Spreadtrum-powered models. In that case, DroidKit is a much simpler option for you to remove Google’s Factory Reset Protection (FRP). The DroidKit is designed to support a wide range of Android brands, including Samsung, Xiaomi, OPPO, OnePlus, and more. It is a device access tool that helps unlock your device after a reset by regaining full control.
Step 1. Download DroidKit and install it on your computer. After running the software, select the “FRP Bypass” from the main screen.
Choose FRP Bypass
Step 2. Use a USB cable to connect your device to the PC. DroidKit detects your device automatically. Select your brand (e.g., Samsung, OPPO) and confirm the device version.
Select Correct Brand
Step 3. DroidKit will create a configuration file depending on your device. When it is done, click “Start to Bypass.”
Launch the FRP Operation
Step 4. Then you need to select the Android system version of your device and tap “Next”.
Select the Correct System Version
Step 5. Perform the final steps on the device as indicated, such as entering factory mode or confirming—using DroidKit, and it will bypass the FRP lock for you. It can take a few minutes.
FRP Bypass Complete
The SPD Flash Tool is a powerful utility designed for individuals in the field of troubleshooting and repairing Spreadtrum-based Android devices, offering safe firmware flashing, device formatting, and repair functions. Being compatible with PAC/P5C files and having a wide range of compatibility with various devices, it is a favorite among mobile repair professionals.
For those seeking an easy and brand-independent way to get rid of FRP locks, DroidKit is an understandable alternative that has a high success rate, and it also works on the main Android brands and the newest versions. These tools, whether you are a professional technician or a DIY user, give you a lot of power over your solutions and allow you to fix, flash, and unlock your Android devices without any difficulty.
