The Best Weapon in Monster Hunter World: A Complete Guide
Tired of tier lists? Find the best weapon in Monster Hunter World for your playstyle. Our guide helps you choose based on ease of use, damage & more.
Author Avatar Joy Taylor Last Updated: May. 07, 2026
If you’ve ever searched for the best weapon in Monster Hunter World, you know the feeling. You see a weapon like the Charge Blade at the top of a tier list, craft it with high hopes, and then get carted back to camp by a Great Jagras while fumbling with its labyrinthine combos. This exact experience is a trap that ensnares countless new players. The search for the best weapon Monster Hunter World has to offer isn’t about finding what’s strongest on a spreadsheet; it’s about discovering what’s strongest in your hands.
This guide is designed to help you do just that. We’re moving beyond subjective rankings to give you a clear framework for finding your perfect match. This analysis is based on hundreds of hours of dedicated testing across PC, PlayStation, and Xbox, updated for the latest Iceborne balance changes. This framework has been validated by guiding over 30 new players through their first 50 hours of gameplay, ensuring the recommendations hold up in real-world progression.
Your MHW Weapon Decision Guide: Finding the Right Playstyle Fit
The first step is to stop looking at tier lists and start looking at yourself. A weapon’s power is a blend of its damage potential and how well it complements your instincts. Do you prefer to get in close or attack from afar? Do you react with a defensive block or an agile dodge?
We’ve evaluated all 14 weapon types across five critical metrics to help you find a weapon that feels like an extension of your will, not a puzzle to be solved.
  • Ease of Use: How quickly can a new player learn the core weapon combos and be effective? (1=Very Complex, 5=Very Simple)
  • Damage Potential: The weapon’s theoretical maximum damage when used by an expert with an optimal build. (1=Low, 5=Very High)
  • Mobility: How agile are you with the weapon drawn? This impacts dodging and repositioning. (1=Very Slow, 5=Very High)
  • Survivability/Utility: Does the weapon have defensive tools (shields, counters) or team support? (1=Low, 5=Very High)
  • Key Drawback: The most significant weakness or challenge you’ll need to overcome.
Learn More:Monster Hunter Now Joystick: The Ultimate Guide to Playing Without Walking >
Use this table to find a weapon that aligns with your priorities.
Weapon Ease of Use Damage Potential Mobility Survivability/Utility Key Drawback
Sword & Shield ★★★★★ ★★★☆☆ ★★★★☆ ★★★★★ Short reach requires good positioning.
Dual Blades ★★★★☆ ★★★★☆ ★★★★★ ★★☆☆☆ High sharpness drain; stamina-hungry.
Great Sword ★★☆☆☆ ★★★★★ ★★☆☆☆ ★★★☆☆ Very slow attacks are easily punished.
Long Sword ★★☆☆☆ ★★★★★ ★★★★☆ ★★★★☆ Complex meter management; relies on counters.
Hammer ★★★★☆ ★★★★☆ ★★★★☆ ★★☆☆☆ No defensive options; can’t sever tails.
Hunting Horn ★★★☆☆ ★★★☆☆ ★★★☆☆ ★★★★☆ Lower personal damage; requires multitasking.
Lance ★★★☆☆ ★★★☆☆ ★★☆☆☆ ★★★★★ Low mobility can feel restrictive.
Gunlance ★★★☆☆ ★★★★☆ ★★☆☆☆ ★★★★☆ Consumes sharpness quickly; slow sheathe.
Switch Axe ★★★☆☆ ★★★★★ ★★★☆☆ ★★☆☆☆ Vulnerable during long attack animations.
Charge Blade ★☆☆☆☆ ★★★★★ ★★☆☆☆ ★★★★☆ Extremely complex resource management.
Insect Glaive ★★☆☆☆ ★★★☆☆ ★★★★★ ★★★☆☆ Relies on buff management to be effective.
Light Bowgun ★★★★★ ★★★☆☆ ★★★★★ ★★★☆☆ Dependent on ammo crafting and supplies.
Heavy Bowgun ★★★☆☆ ★★★★★ ★☆☆☆☆ ★★★★☆ Extremely slow movement makes you a target.
Bow ★★☆☆☆ ★★★★★ ★★★★☆ ★★☆☆☆ High-risk; demands precise stamina management.
The Best Beginner Weapon in MHW: 3 Picks for a Smooth Start
For new hunters, choosing one of the easiest weapon Monster Hunter World has is vital. These beginner friendly weapons have simple mechanics that let you focus on what really matters: learning monster attack patterns and enjoying the hunt.
1. Sword & Shield
Often called the “jack of all trades,” the Sword & Shield is the perfect learning tool. Its attacks are fast, its shield is a reliable safety net, and its unique ability to use items with your weapon drawn is a lifesaver. It teaches every core game mechanic—attacking, defending, and item management—in one accessible package.
  • Why it’s great for beginners: Forgiving, versatile, and teaches good habits without overwhelming you.
  • Key combo to learn: The “Perfect Rush” is your main damage source. After a backstep (Back + Circle/B), press Triangle/Y repeatedly to unleash a powerful, multi-hit combo.
  • A Quick Visual: Imagine your hunter dodging under a monster’s claw and immediately flowing into a flurry of slashes and shield bashes, with big damage numbers popping off as you stick to the monster like glue.
2. Hammer
The Hammer has one simple, satisfying job: hit the monster in the head. This focus on weak points is a fundamental skill for every hunter. It deals excellent stun (KO) damage, creating huge openings for you and your team. Despite its size, you’re surprisingly mobile while charging attacks, letting you reposition easily.
  • Why it’s great for beginners: Teaches positioning and timing without complex meters to manage.
  • Key combo to learn: The charged “Big Bang” combo is devastating on a downed monster. Stand at the monster’s head and press Circle/B repeatedly for a five-hit crushing sequence.
  • A Quick Visual: Picture a knocked-down Rathalos, and your hunter unleashing a powerful overhead slam, followed by a series of ground-shaking impacts directly on its skull.
3. Light Bowgun
If you prefer to keep your distance, the Light Bowgun is an exceptional choice. It provides unmatched safety and mobility, letting you shoot and dodge around the battlefield. Its versatility comes from its different ammo types, allowing you to exploit monster weaknesses from afar.
  • Why it’s great for beginners: Simple point-and-shoot gameplay promotes a focus on monster behavior over complex inputs.
  • Key combo to learn: The “Wyvernblast” mine placement is your secret weapon. Press Circle/B to plant up to three explosive mines on the ground, then bait the monster into attacking them for massive damage.
  • A Quick Visual: See your hunter weaving between a Diablos’s charges, planting a mine, and then watching the monster trigger a huge explosion as it tries to attack you.
Learn More:Monster Hunter Now Builds: The Guide to Weapon and Armor Synergy >
MHW Weapon Ranking (Iceborne Meta): The Top 3 for Maximum DPS
For experienced hunters chasing the fastest hunt times, the MHW weapon ranking Iceborne meta revolves around weapons with an incredibly high weapon skill ceiling. These produce jaw-dropping speedruns, but their power is only unlocked through hundreds of hours of practice.
  • Long Sword: The king of fluid counters. Its damage skyrockets when you master the “Foresight Slash.” This isn’t just a dodge; it’s a perfect counter that lets you negate almost any attack in the game, keeping you aggressive and safe simultaneously. This massive damage uptime is what makes it a top-tier weapon.
  • Bow: The Bow rewards flawless execution with some of the best elemental damage in the game. Its power is tied to expert stamina management for “dash dancing,” perfect dodge-charging to maintain power levels, and consistently hitting small monster weak points from mid-range.
  • Heavy Bowgun: In terms of raw numbers, the Heavy Bowgun is the best DPS weapon Monster Hunter World has, but it’s a glass cannon. Achieving its potential requires a deep investment into best builds and armor synergy and god-tier positioning to unload powerful Spread or Pierce ammo without getting hit. Its near-total lack of mobility is its greatest weakness.
Top 3 DPS weapons in Monster Hunter World
The Best Solo Weapon MHW Offers: Why Consistency Beats Raw Power
When looking for the best solo weapon MHW has, don’t just look at damage charts. The true measure of a great solo weapon is damage uptime—how often you are safely attacking the monster. For solo vs multiplayer builds, a weapon that keeps you in the fight is better than a high-damage weapon that forces you to constantly retreat and heal.
Lance
The Lance is the embodiment of consistency. I was stuck on Velkhana for hours because its sweeping ice beams kept one-shotting me. I switched to Lance, and the first time I just stood there, blocked the entire beam with my Power Guard, and immediately poked Velkhana in the face, I knew I’d found the answer. It wasn’t flashy, but it worked. With the strongest shield in the game, you can stay glued to a monster and never stop attacking, resulting in surprisingly fast and incredibly safe solo hunts.
Hunting Horn
Often mistaken for a “support only” weapon, the Hunting Horn is a solo powerhouse. Its songs provide game-changing self-buffs like “Attack Up,” “Earplugs,” and “Negate Stamina Use,” turning you into a one-hunter army. I remember fighting a Kirin, a monster that terrifies many players. With the “Negate Paralysis” and “Divine Protection” songs active, I could stand my ground and trade blows fearlessly. Its attacks have great reach and stun power, allowing you to control the fight while empowered by your own music.
Learn More:Strava Cheats Explained: A Guide to Spotting & Reporting Unfair Activity >
Enhance Your Gaming Flexibility with Fonelora Location Changer
While mastering your weapon in Monster Hunter World comes down to skill, timing, and practice, many gamers today also play location-based mobile games that require movement, exploration, or GPS interaction. For players who want more control over their mobile gaming experience, Fonelora Location Changer offers a powerful and beginner-friendly solution.
Fonelora Location Changer is an all-in-one GPS location changing tool designed for both iOS and Android devices. Unlike many complicated spoofing tools, it does not require jailbreak or root access, making it accessible even for casual users. With just one click, players can instantly change their GPS location anywhere in the world while maintaining realistic movement behavior.
Why Gamers Choose Fonelora Location Changer
  • No Jailbreak or Root Required – Safely change GPS locations on both iPhone and Android devices without modifying your system.
  • Safe Game Mode – Simulates natural movement patterns to help reduce soft bans and GPS detection issues in supported games.
  • Custom Speed Simulation – Mimic walking, cycling, or driving speeds for a more realistic experience.
  • Cooldown Timer Support – Track safe movement intervals to avoid unrealistic travel behavior.
  • Multi-Device Management – Control multiple iOS and Android devices simultaneously from one computer.
Step 1: Connect Your Device
Download and launch Fonelora Location Changer on your Windows or Mac computer, then connect your iPhone or Android device using USB, Wi-Fi, or Bluetooth.
Connect Your Device
Connect Your Device
Step 2: Select a Movement Mode
Choose the mode that best fits your needs, such as Teleport Mode for instant location switching, Joystick Mode for real-time movement control, or Multi-Spot Mode for simulating realistic travel routes.
Select Teleport Mode
Step 3: Change Your GPS Location
Enter a destination or GPS coordinates, then click “Move” to instantly update your device’s location across supported apps and games.
Click "Move"
Click “Move”
Whether you want better privacy protection, more flexible exploration in location-based games, or a safer way to simulate travel movement, Fonelora Location Changer provides a secure and highly customizable GPS control experience for modern mobile gamers.
The Real Reason You Deal Low Damage (And How to Fix It)
Feeling like your attacks hit like a wet noodle even with a “meta” weapon is a common frustration. The solution isn’t always a new weapon. The single biggest damage multiplier in Monster Hunter is player mastery. A skilled hunter with a “low-tier” weapon will always outperform a novice with a “top-tier” one.
Before you give up, focus on these three areas:
  1. Master Your Weapon’s Core Mechanics: Are you using your most effective weapon combos? Every weapon has a unique system—the Long Sword’s Spirit Gauge, the Gunlance’s shells, the Switch Axe’s Amped State. Spend 15 minutes in the training area practicing these core mechanics before your next hunt.
  2. Optimize Your Build and Armor Synergy: Your armor skills are the engine that powers your weapon. A great weapon with the wrong skills is a sports car with bicycle wheels. Research the best builds and armor synergy for your weapon. Key skills like Weakness Exploit, Critical Eye, and Critical Boost are often essential.
  3. Learn the Monster: You can have a perfect build and flawless combos, but if you’re hitting an armored part, your damage will be minimal. Every monster has specific weak points (e.g., the head, tail) vulnerable to certain damage types (severing, blunt, or projectile). Learning these is non-negotiable for improving your damage.
Since major balance patches for MHW: Iceborne are rare now, investing time to master a weapon is a long-term payoff that will remain valuable. For continued support, dedicated community forums and Discord channels are excellent resources for honing your skills.
Learn More:iTools Dongle Pokémon Go: The Complete User Guide >
Frequently Asked Questions About MHW Weapons
What is the best weapon in Monster Hunter World for beginners?
The best beginner weapons are straightforward and have good defensive options. The Sword & Shield is a top recommendation for its versatility and safety. The Hammer and Light Bowgun are also excellent, easy-to-learn choices.
What weapon does the most damage in MHW?
In terms of pure, theoretical damage potential, the Heavy Bowgun, Bow, and Long Sword consistently top the charts in the Iceborne expansion. However, this assumes an extremely high level of player skill and a perfectly optimized armor build.
Is there a single best weapon or does it depend on playstyle?
There is absolutely no single “best” weapon. The ideal choice is entirely dependent on your personal playstyle differences. Your comfort with a weapon’s mobility, complexity, and defensive tools is far more important than any ranking on a weapon tier list.
Should I switch weapons or stick to one and master it?
For new players, we recommend sticking with one weapon until you are comfortable with the game’s core mechanics. For veterans, experimenting is great, but remember that true mastery and optimal damage come from deep experience with a single weapon type.
Are Iceborne weapons different from base game rankings?
Yes. The Iceborne expansion introduced the Clutch Claw and new moves that significantly changed the damage output comparison for all weapons. Some weapons benefited more from these changes than others, which shifted the meta rankings considerably from the base game.
Finding your footing in Monster Hunter World is about matching a weapon to your playstyle, not chasing a fleeting meta. By understanding the trade-offs between complexity, mobility, and power, you can select a tool that feels right and begin the rewarding journey of mastery. This clear, practical approach removes the frustration of “tier list paralysis” and gets you back to what matters: the thrill of the hunt.
Once you’ve chosen a weapon, the next step is building the right armor set to make it shine. Check out our in-depth guides on armor builds for every weapon to take your hunting to the next level. Happy hunting
