Joy Taylor
Joy Taylor | Last Updated: Jul. 9, 2026
To find Giovanni in Pokémon GO, you must first have an active Super Rocket Radar equipped. Once activated, he can be found hiding at marked PokéStops on your map or inside the Team GO Rocket balloons that periodically float to your location. As you explore other Pokémon GO guides, you will see that having this specific radar is the only way to trigger the boss encounter.
Giovanni’s Current 3-Phase Lineup:
If you do not have a Super Rocket Radar equipped, checking PokéStops will only reveal standard Grunts, and you will not be able to encounter the boss.
Best Counters to Beat Giovanni in Pokémon GO
Defeating Giovanni requires careful shield management. Like you, he uses two Protect Shields, and his signature Shadow Persian will burn through your health incredibly fast if left unchecked. Your primary strategy should be using a Fighting-type Pokémon with a fast-charging Charge Attack to force Giovanni to waste both of his shields early in Phase 1.
Here is a breakdown of the optimal counters for his 3-phase battle:
Battle Phase Giovanni’s Lineup Recommended Counters Move Focus
Phase 1 Shadow Persian Lucario, Machamp, Conkeldurr Counter (Fast) + Power-Up Punch or Cross Chop (Charge)
Phase 2 Variable Middle Slot Swampert, Mamoswine, Kartana High DPS picks that exploit Ground/Water/Dragon weaknesses
Phase 3 Current Shadow Legendary Varies by boss (e.g., use Kartana for Shadow Groudon, or Tyranitar for Shadow Mewtwo) Exploit the specific elemental weakness of the active event Legendary
Tips
Always put your Shadow Persian counter in the second or third slot of your party, then immediately swap to it as soon as the battle starts. This briefly pauses Giovanni’s attacks for a few seconds, giving you a massive head start on generating energy.
The Super Rocket Radar and the Decoy Grunt Problem
Having a Super Rocket Radar is strictly required to find Giovanni, but equipping it does not guarantee an instant boss fight. When you use the Radar to scan your map, it highlights multiple potential PokéStops where the boss might be hiding.
However, Niantic designed the game so that standard Team GO Rocket Decoy Grunts will appear at these marked PokéStops alongside the real Giovanni. Finding Decoy Grunts instead of the boss is a normal game mechanic, not a glitch. To find the real Giovanni, you have to physically travel to and check multiple marked PokéStops to clear out the decoys until you finally uncover the boss.
Why Rural Players Struggle to Find Giovanni
The Decoy Grunt mechanic is meant to be a fun hunt, but it becomes a massive roadblock if you live in a rural area or a neighborhood with very few PokéStops.
Imagine finally earning your Super Rocket Radar after weeks of gameplay. You open the map, but there are only two marked PokéStops within a 10-mile radius. You drive to both, only to find Decoy Grunts. Because you have exhausted your limited local map, you now have to wait for the PokéStops to refresh the next day, or spend hours physically traveling to a denser city just to roll the dice again. This turns what should be an exciting boss encounter into an incredibly frustrating physical time sink.
How to Use Fonelora Location Changer to Scan PokéStops Faster
If you are tired of traveling for miles just to find Decoy Grunts, Fonelora Location Changer offers a guided desktop workflow to virtually check high-density PokéStop areas on supported iOS and Android devices. For players seeking a reliable Pokémon GO location changer, this workflow removes the physical roadblock.
It is important to understand that Fonelora cannot automatically spawn Giovanni—a Super Rocket Radar is still strictly required. Instead, it solves the rural map problem by allowing you to bypass physical travel limitations so you can scan multiple stops efficiently.
Realistic GPS movement simulation, flexible route control, easy no-modification setup, and support for gaming, social, privacy, and location-based testing in one platform.
Here is how to use the workflow to speed up your hunt:
Connect Your Device
Connect Your Device
Select Teleport Mode
Change Location instantly
This method allows you to check dozens of potential PokéStops in minutes rather than wasting hours driving around rural maps.
Game-Aware Movement: Managing Cooldowns and Risks
Using any virtual location tool to hunt for Giovanni requires game-aware movement. Jumping between distant cities to check PokéStops will trigger Pokémon GO’s strict cooldown mechanics.
Review this checklist to ensure you are managing your virtual location responsibly:
Frequently Asked Questions About Giovanni
  • How do I get a Super Rocket Radar?
  • You earn a Super Rocket Radar by completing specific Team GO Rocket Special Research tasks. These storylines typically require you to defeat all three Team GO Rocket Leaders (Cliff, Sierra, and Arlo) first.
  • How often does Giovanni change his legendary Pokémon?
  • Giovanni’s Phase 3 Shadow Legendary changes every few months. This rotation is always tied to official Team GO Rocket takeover events scheduled by Niantic.
  • Does Giovanni spawn in Team GO Rocket balloons?
  • Yes. If you have an active Super Rocket Radar equipped, the next Team GO Rocket balloon that floats to your location will contain either a Decoy Grunt or the real Giovanni.
  • Why am I only finding Decoy Grunts?
  • Finding decoys is an intentional game mechanic designed to make the boss hunt challenging. You must keep checking different marked PokéStops to eventually find him.
  • Can I use a virtual location tool to find Giovanni faster?
  • Yes, players heavily restricted by rural maps often use tools like Fonelora Location Changer to virtually scan dense city areas, provided they strictly follow cooldown rules and use supported devices.
Ready to Defeat Team GO Rocket’s Boss?
Defeating Giovanni is one of the most rewarding challenges in Pokémon GO. By preparing the right Fighting-type counters to break Shadow Persian’s shields early, you set yourself up for a much smoother Phase 2 and Phase 3 battle.
Remember that having a Super Rocket Radar is mandatory, and dealing with Decoy Grunts is just part of the hunting process. However, if you are stuck in an area with limited local PokéStops and don’t want to spend hours driving around, you have options. For players who want to save time checking distant stops under supported conditions, Fonelora Location Changer provides a reliable desktop workflow to speed up your search.
fonelora img
  • Bluetooth Hardware Simulation for Safer GPS Spoofing
  • Realistic Movement & Route Simulation
  • No Root or Jailbreak Required
  • All-in-One Solution for Games, Social Apps & Privacy
More Related Articles
Change GPS Location Easily
Free Download Free Download
