Joy Taylor
Joy Taylor | Last Updated: Jul. 15, 2026
Quick Answer: To fake Snapchat location, you need to change the GPS location reported by your phone. A VPN usually changes only your IP address, so it will not reliably move your Bitmoji on Snap Map. For iPhone and Android users, the most practical options are a desktop GPS location tool such as Fonelora Location Changer, or Android mock-location apps for Android-only setups.
If you want to fake Snapchat location, change where you appear on Snap Map, or test how Snapchat reads your phone location, it is important to understand the difference between hiding your location and changing your device GPS. Ghost Mode hides you from Snap Map, but it does not make you appear somewhere else. A VPN may change your internet region, but Snapchat location features usually rely on device location data.
This guide explains what actually works on iPhone and Android, why VPNs usually fail, how to use Fonelora Location Changer as a device-level GPS tool, and what to check if your fake location does not update correctly.
Can You Fake Snapchat Location?
Yes, you can make Snapchat read a different device location, but the method matters. Snap Map depends on the location data your phone provides. If your phone reports a selected GPS location, Snapchat may show that location on Snap Map when location sharing is enabled.
There are three common approaches:
So if your goal is to appear in a selected city, address, landmark, or region on Snap Map, you need a GPS-level method rather than a basic VPN.
Tips
Important: Faking Snapchat location is different from pausing or hiding your location. If your goal is only privacy, use Snapchat location privacy settings such as Ghost Mode instead.
Ghost Mode vs VPN vs GPS Location Changer
Before choosing a method, decide what you want Snapchat to show. The wrong method can make the process confusing, especially if you expect a VPN to move your Snap Map location.
Method What It Does Can It Change Snap Map Location? Best For
Ghost Mode Hides your location from friends on Snap Map. No. You disappear instead of appearing somewhere else. Privacy and hiding location sharing.
VPN Changes your IP address and internet region. Usually no. It does not change phone GPS. Browser privacy or region-based web access.
Desktop GPS Location Tool Changes the GPS location reported by your device. Yes, when the setup works with your device and app settings. iPhone and Android users who need a selected GPS location.
Android Fake GPS App Uses Android mock location settings to simulate GPS. Yes, but setup can be unstable on some devices. Android-only users comfortable with Developer Options.
For most iPhone users, a desktop GPS location tool is more practical than mobile-only fake GPS apps. For Android users, mock location apps can work, but they often require more manual setup and may conflict with Wi-Fi or location accuracy settings.
Ghost Mode on Snapchat
Ghost Mode hides your location but does not fake a new Snap Map location.
Method 1: Fake Snapchat Location with Fonelora Location Changer
For iPhone and Android users who want to set a selected Snap Map location, a desktop-based GPS location tool is usually more stable than a VPN or a random mobile fake GPS app. Fonelora Location Changer lets you change the GPS location reported by your device from a Windows or Mac computer.
This method is useful when you want to choose a city, address, landmark, or route before opening Snapchat. It changes the device-level location that location-based apps may read, instead of only changing your IP address like a VPN.
Fonelora Location Changer is especially useful if you want to:
Snapchat GPS location changer
A GPS location changer can set the device location read by location-based apps.
Step 1. Download and Install Fonelora Location Changer
Download Fonelora Location Changer on your Windows PC or Mac, then complete the installation. Use the official product page rather than unofficial installers or cracked versions.
Download and install Fonelora Location Changer.
Step 2. Connect Your iPhone or Android Device
Launch the program and connect your phone to the computer. For the first setup, a USB connection is usually the most stable option. Keep your phone unlocked during setup so you can approve connection prompts.
Connect phone to Fonelora Location Changer
Connect your phone to the computer.
Step 3. Trust the Computer
If your iPhone shows a “Trust This Computer?” prompt, tap Trust and enter your passcode. On Android, follow the on-screen instructions if the program asks for connection permission or USB debugging setup.
Trust this computer on iPhone
Trust the computer when your phone asks for permission.
Step 4. Choose a Location Mode
Select a mode based on your goal. Use a fixed-location mode if you want to appear in one selected place, or choose route mode if you want to simulate movement between points.
Choose a location mode in Fonelora
Choose a location-changing mode.
Step 5. Pick a New Location
Search for a city, address, landmark, or coordinate on the map. For example, you can choose a coffee shop, airport, public square, or another place where you want your phone location to appear.
Step 6. Apply the Location
Apply the selected location in Fonelora Location Changer. The device GPS location should change to the point you selected. Wait a few seconds before opening Snapchat so your phone has time to report the new location.
Step 7. Open Snapchat and Check Snap Map
Open Snapchat and check Snap Map. Your Bitmoji should reflect the location your phone is reporting. If it does not update immediately, close Snapchat completely and open it again after confirming the selected location is active on your device.
Step 8. Restore Your Real Location
When finished, reset the location in Fonelora Location Changer or restart your phone to return to your actual GPS location. Then reopen Snapchat after your real location is restored.
Note
A GPS location tool changes the device location that apps may read. It does not change Snapchat account settings, friend visibility settings, or Snap Map privacy rules. Review your own privacy settings before sharing location with others.
Method 2: Use Android Fake GPS and Mock Location
Android users can also use a fake GPS app with Android mock location settings. This method is usually free, but it takes more manual setup and may be less stable depending on your Android version, phone brand, location accuracy settings, and the fake GPS app you choose.
Step 1. Install a Fake GPS App
Open Google Play and choose a fake GPS app with clear reviews and recent updates. Avoid unknown APK files from random websites, because they may contain malware or unstable components.
Step 2. Enable Developer Options
Open Settings > About Phone, then tap Build Number several times until Developer Options are enabled. The exact path may vary by Android device.
Enable Android Developer Options
Enable Developer Options on Android.
Step 3. Select the Mock Location App
Go to Settings > Developer Options, find Select mock location app, and choose the fake GPS app you installed.
Step 4. Choose a Location in the Fake GPS App
Open the fake GPS app, drop a pin on the location you want, and start the mock location. Keep the fake GPS app running while you test Snapchat.
Step 5. Open Snapchat and Check Snap Map
Open Snapchat and check whether Snap Map reflects the mock location. If your location keeps snapping back, check the troubleshooting section below.
Note
Android limitation: Mock location behavior can vary by device, Android version, and location accuracy settings. Some phones may use Wi-Fi and cellular signals that conflict with the mock GPS location.
Why VPNs Do Not Change Snap Map Location
A VPN changes your IP address, not your phone’s GPS coordinates. This is why many users turn on a VPN, choose another country, open Snapchat, and still see their Bitmoji in the real location.
Snap Map is based on location sharing and device location data, while a VPN mainly affects internet routing. If your VPN says you are in Germany but your phone GPS still says you are in Chicago, Snap Map may still use the phone’s location data.
VPN does not usually change Snap Map GPS location
A VPN changes IP location, but Snap Map usually needs device location data.
Use a VPN only if you need IP-based privacy or web browsing privacy. For Snap Map location, use a GPS-level method.
Troubleshooting: Fake Location Not Updating or Snapping Back
If your fake Snapchat location does not update, or if it briefly changes and then snaps back to your real place, check the following issues.
1. Close Snapchat Before Changing Location
Close Snapchat completely before applying a new GPS location. Then reopen Snapchat after the location has been changed on your device.
2. Check Device Location Permission
Make sure Snapchat has location permission if you expect Snap Map to read the selected device location. If location permission is blocked, Snap Map may not update as expected.
3. Check Wi-Fi and Location Accuracy Settings
On some Android devices, Wi-Fi scanning and high-accuracy settings may conflict with mock location apps. If your location keeps snapping back, review Android location accuracy settings and test again.
4. Avoid Switching Locations Too Quickly
Jumping repeatedly between distant locations can make app behavior inconsistent. Choose one selected location, apply it, and keep the setup stable while testing.
5. Restart the App or Device
If Snapchat still shows the old location, force-close Snapchat and reopen it. If the phone keeps reporting the wrong location, reset the tool or restart your device.
6. Restore Real Location When Finished
When you are done, restore your real location before using other location-based apps. This prevents maps, delivery apps, weather apps, or other services from reading an unintended location.
If the problem is not fake GPS setup but Snap Map itself showing an outdated or incorrect location, use the guide to fix Snap Map wrong location.
Risks and Limitations of Fake Snapchat Location
Fake GPS tools can be useful, but they are not Snapchat’s native privacy feature. Use them carefully and understand the limitations before relying on them.
Tips
Best practice: Decide whether you need privacy or a selected location. For privacy, use Ghost Mode or friend visibility settings. For a selected location, use a GPS location tool and restore your real location when finished.
Frequently Asked Questions About Fake Snapchat Location
How do I fake Snapchat location?
To fake Snapchat location, change the GPS location reported by your phone, then open Snapchat and check Snap Map. On iPhone and Android, a desktop tool such as Fonelora Location Changer can help set a selected device location. On Android, mock location apps are another option.
Can I fake Snapchat location with a VPN?
Usually no. A VPN changes your IP address, but Snap Map generally depends on device location data. If your phone GPS still reports your real location, a VPN alone is unlikely to move your Bitmoji on Snap Map.
What is the best way to fake location on Snapchat for iPhone?
For iPhone users, a desktop GPS location tool is usually more practical than mobile-only fake GPS apps, because iOS does not offer the same mock location app workflow as Android.
How do I use fake GPS on Android for Snapchat?
Install a fake GPS app, enable Developer Options, select the fake GPS app as your mock location app, choose a location, start the mock location, and then open Snapchat to check Snap Map.
Why is my fake Snapchat location not updating?
Snapchat may still be reading old GPS data, the fake GPS setup may not be active, Wi-Fi or location accuracy settings may conflict with the selected location, or Snapchat may need to be restarted after applying the new location.
Why does my Snapchat location snap back to my real location?
This can happen when your phone combines GPS, Wi-Fi, cellular, and location accuracy signals. On Android, check mock location settings and location accuracy options. With desktop tools, make sure the connection remains stable until the selected location is applied.
Can I fake Snapchat location without a computer?
Android users may be able to use fake GPS apps and mock location settings without a computer. For iPhone users, a computer-based location tool is usually the more reliable option.
Does Ghost Mode fake my location?
No. Ghost Mode hides your location from friends on Snap Map. It does not make your Bitmoji appear somewhere else.
Can I use fake location for Snapchat filters?
Some Snapchat filters and map-based features may depend on device location. If your device location changes successfully, location-based features may reflect the selected place, but availability can vary by Snapchat version and feature.
How do I restore my real location after using a location changer?
Use the reset option in the location tool or restart your phone. After your real location is restored, reopen Snapchat and other location-based apps.
To fake Snapchat location, you need to change the GPS location your phone reports. Ghost Mode is useful for hiding your location, and VPNs can change your IP region, but neither one reliably changes where your Bitmoji appears on Snap Map.
For iPhone and Android users who want a selected Snap Map location, Fonelora Location Changer is a practical desktop-based option. Android users can also try fake GPS apps through mock location settings, though results can vary by device and setup.
Use location tools carefully, keep your setup simple, and restore your real location when you are done. If you only want privacy rather than a selected location, use Snapchat’s built-in Ghost Mode or friend visibility settings instead.
More Related Articles
Change GPS Location Easily
Free Download Free Download
