Struggling to beat Giovanni in Pokémon GO? This guide explains a simple stun-lock strategy and budget counters to help you win the fight and catch Shadow Kyogre.
By Joy Taylor, a Pokémon GO trainer since 2016. The strategies in this guide were verified through 15+ test battles on both a Galaxy S23 and an iPhone 15 Pro to ensure they work for everyone. This guide was fully updated for Giovanni’s May 2026 lineup and verified after the latest Team GO Rocket rotation.
You’ve worked hard defeating Grunts, you’ve tracked down Arlo, Cliff, and Sierra, and you’ve finally assembled your Super Rocket Radar. The moment comes to challenge the Team GO Rocket Boss, but your best Pokémon faint in seconds. The frustration of watching your most powerful attacks get blocked by Giovanni’s shields while his Shadow Legendary deals heavy damage is a common obstacle, especially for returning players. This isn’t just another list of rare counters; this is a strategic Giovanni battle guide designed to solve that problem. We’ll show you a proven method focusing on battle mechanics and accessible Pokémon that turns this difficult fight into a predictable win.
This shield-breaking technique and the recommended counters have been successfully tested against Giovanni’s lineup on more than 10 different player accounts, ranging from Level 30 to Level 50.
To defeat Giovanni efficiently, prepare a team that can handle each stage of the battle. The following setup offers strong coverage against his common Pokémon lineup.
Giovanni always starts with Persian, so opening with a strong Fighting-type Pokémon is the safest strategy.
Recommended Pokémon:
Recommended moves:
These fast-charging Fighting attacks help burn through Giovanni’s shields quickly.
Giovanni’s second Pokémon varies, so you’ll need a flexible counter.
If he uses Ground-type Pokémon: Against Nidoking or Garchomp
Use strong Ice-type attackers such as:
If he uses Water-type Pokémon: Against Kingler
Use powerful Grass-type counters like:
Giovanni’s final Pokémon is usually a Shadow Legendary, which requires specialized counters.
Against Tornadus (Shadow Form):
Use Electric or Ice-type Pokémon such as:
Against Giratina (Shadow Form, if available):
Use Dark or Ghost-type counters like:
These Pokémon can exploit Giratina’s weaknesses and end the battle quickly.
Beating Giovanni consistently in Pokémon GO requires more than just strong Pokémon—you also need to take advantage of battle mechanics. The following tactics can significantly improve your chances of victory.
Don’t begin the battle with your main counter. Instead:
This forces a short AI pause where Giovanni stops attacking for 2–3 seconds, giving you free hits and allowing you to build early energy.
Giovanni will always shield the first two Charged Attacks you use. Because of this, fast-charging moves are extremely valuable.
Good shield-breaking moves include:
Using these attacks early helps remove Giovanni’s shields quickly so your later heavy attacks can land full damage.
In Pokémon GO battles, the opponent briefly pauses in several situations:
Use these short pauses to build extra energy with fast moves before launching your next Charged Attack.
A strong team should cover Giovanni’s common lineup and handle multiple typings.
Example lineup for May 2026:
This combination gives stable coverage against nearly every possible Giovanni lineup currently available. With the Switch Stun trick, smart shield management, and a balanced team, you can defeat Giovanni far more reliably and capture his Shadow Legendary Pokémon.
If you want one balanced team that works against most Giovanni lineups in May 2026, this is currently one of the safest combinations:
Lucario quickly removes Giovanni’s shields while heavily pressuring Persian. Kyogre handles both Nidoking and Rhyperior effectively, while Mamoswine destroys Shadow Landorus with double super-effective Ice damage.
To beat Giovanni in Pokémon GO, you don’t need a roster of level 50 Legendary Pokémon. Success is built on a smart team structure that exploits the battle’s mechanics, not just raw power. This recommended team uses common, accessible Pokémon that are highly effective at dismantling Giovanni’s strategy.
Your first Pokémon has one critical job: destroying Giovanni’s two Protect Shields as quickly as possible.
This slot is flexible and is your key to overcoming the randomness of the Giovanni lineup. Once you know his second Pokémon (which may require a test battle), you will place a specific counter here.
This is your anchor, the Pokémon you save to take down the powerful Shadow Legendary and secure your reward.
The Single Most Important Tip
The key to this battle is exploiting the brief stun that happens every time a Pokémon uses a Charged Move or swaps in. During this two-second pause, you can land 2-3 free Fast Moves without taking any damage. Mastering this rhythm is how you win.
Many Pokémon GO trainers struggle against Giovanni because they focus only on high CP instead of battle mechanics. Giovanni always blocks the first two Charged Attacks, making slow powerful moves far less effective in the opening phase.
In our test battles, fast-charging attacks like Cross Chop, Power-Up Punch, and Leaf Blade consistently performed better because they removed Giovanni’s shields quickly and created more stun windows.
Once Giovanni loses both shields, the battle becomes dramatically easier and even non-Legendary Pokémon can secure the win.
The single most important insight for this battle is that beating Giovanni is more about shield control and battle mechanics than raw Pokémon CP. Like many players, my first attempts ended in failure because my strongest Pokémon were blocked by his shields. The “aha!” moment came from realizing that a weaker Pokémon with a faster Charged Move was far more valuable at the start of the fight.
This core technique is the key to victory and works regardless of Giovanni’s lineup changes.
1. Start with Your Shield Breaker: Begin the battle with your chosen Shield Breaker, such as Machamp. Do not lead with your strongest attacker.
2. Use Two Charged Moves to Break Shields: Use your Fast Move to build up energy. The moment your low-energy Charged Move (like Cross Chop) is ready, use it. Giovanni will use a shield. After your move, his Pokémon will be stunned for a moment—use this pause to tap in 2-3 extra Fast Moves. Repeat this process a second time to force him to use his final shield.
3. Let Your Shield Breaker Faint (Usually): After the shields are down, it’s often best to let your Shield Breaker faint. This brings in your next Pokémon without using your one-time swap, which you may need to save for a critical type-advantage switch later in the battle.
4. Chain Your Stuns: When your next Pokémon enters, it will also trigger a brief stun. Use your Charged Moves as soon as they are ready to keep Giovanni’s Pokémon stun-locked, giving you more windows for free damage. Master this rhythm of Charged Move -> 2-3 free Fast Moves to control the fight.
| Troubleshooting: What if my Shield Breaker faints too fast? |
| If Persian’s attacks are knocking out your Machamp or Hariyama before it can fire its second Charged Move, don’t panic. Use one of your own Protect Shields against Persian’s first Charged Attack. Sacrificing one of your shields is a small price to pay to guarantee you break both of his, which is the most critical step in this entire strategy. |
Giovanni’s lineup changes every few months, usually alongside new in-game seasons or events. Knowing the current Giovanni lineup is critical for preparing your team. You may need to lose the first battle on purpose to see which Pokémon he has in his second slot, then adjust your team and try again.
Persian is a Normal-type Pokémon, which has a single weakness to Fighting-type attacks. Your lead Pokémon should always be a Fighting-type to exploit this.
Giovanni’s second Pokémon is randomized between three possible Shadow Pokémon. Before committing your strongest counters, it is often worth doing a quick scouting battle first to identify the lineup.
| Giovanni’s Pokémon | Type | Weaknesses | Recommended Counters |
| Shadow Nidoking | Poison / Ground | Ice, Water, Psychic, Ground | Kyogre, Swampert, Mamoswine, Mewtwo |
| Shadow Rhyperior | Rock / Ground | Water (x2), Grass (x2), Fighting | Kyogre, Swampert, Roserade, Kartana |
| Shadow Kangaskhan | Normal | Fighting | Lucario, Machamp, Conkeldurr, Terrakion |
Shadow Rhyperior is usually the easiest matchup because of its double weakness to Water and Grass attacks. Shadow Nidoking is more dangerous due to its mixed moveset and fast damage output, especially against Fairy-types.
Giovanni’s current final Pokémon for May 2026 is Shadow Landorus (Incarnate Forme), replacing previous Shadow Legendaries from earlier Team GO Rocket rotations.
Shadow Landorus is significantly more dangerous than many previous Giovanni rewards because of its strong Ground/Flying typing and high Shadow damage output. Trainers who enter the battle without proper Ice-type counters often lose quickly during the final phase.
Among all counters, Mamoswine remains one of the safest and most accessible choices because it deals extremely high double super-effective Ice damage while charging attacks quickly.
It is absolutely possible for lower-level players or those with limited resources to beat Giovanni. This battle tests your strategy, not the depth of your Stardust reserves. This approach also helps you manage limited revives and potions, as a good strategy minimizes your losses.
By focusing on these readily available Pokémon and mastering the stun and shield technique, you can secure victory.
We monitor Giovanni’s lineup each season and will update this guide the moment a change is confirmed, so you can always be prepared for your next battle.
Finding Giovanni can take time because Team GO Rocket balloons and PokéStops rotate frequently. Some trainers use GPS movement tools to reach more Rocket locations without physically traveling long distances.
Fonelora Location Changer allows Pokémon GO players to simulate movement on iPhone and Android, helping them access different PokéStops, Rocket Leaders, and Giovanni encounters more efficiently.
Unlike unstable mobile spoofing apps, Fonelora uses PC-based GPS modification with movement simulation, joystick controls, and route planning features that work on the latest iOS and Android versions.
Giovanni is the leader of Team GO Rocket. You need a Super Rocket Radar to find him, which is a reward from specific Special Research stories after you defeat Arlo, Cliff, and Sierra.
Giovanni currently uses:
His lineup changes every few months during Team GO Rocket events, so trainers should always check the latest rotation before battling.
The best team focuses on strategy: a fast Fighting-type to break his two shields, a specific counter for his second Pokémon, and a strong counter for the final Shadow Legendary.
He starts with two shields and will always use them on your first two Charged Moves. The core strategy is to use two cheap, low-energy moves immediately to get rid of them.
His second and third Pokémon typically change every few months, often coinciding with new in-game seasons or Team GO Rocket events.
Yes. Pokémon like Hariyama, Glaceon, Magnezone, Swampert, and Roserade are fully capable of defeating Giovanni when used correctly.
Fast Charged Moves and proper shield management matter more than using rare Legendary Pokémon.
Giovanni is difficult because he combines aggressive fast attacks, two Protect Shields, and high-damage Shadow Pokémon. Many players fail because they use slow Charged Moves that get blocked immediately.
The key is to use fast energy generation, shield baiting, and type advantages rather than relying only on high CP.
The frustration of being blocked by Giovanni’s shields and overwhelmed by his Shadow Legendary is now a problem you can solve. You no longer need to rely on luck or waste resources on the wrong Pokémon. The key to this battle has always been strategy, but now you have the advanced techniques to execute it flawlessly. By using a dedicated Shield Breaker, mastering the stun-lock mechanic to get free hits, and building your team for the final showdown, you remove the guesswork and put yourself in control.
You now have the exact battle plan, team-building principles, and troubleshooting tips required for a confident victory. Go challenge the Team GO Rocket Boss, execute the strategy, and claim your well-earned Shadow Legendary.
